[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Thu Jan 26 08:56:56 HKT 2023
Hi,
A quick note to share with you the progress on the ESP-IDFv4 + cmake
endeavour:
* The branch
https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/experimental-esp-idf-v4-rework-network
is now ready for greater review. Most of the warnings are gone, and
I'll need some help for the last ones.
* I created a draft PR
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/806
. Not that I want to merge it as-is nor soon, but it may help the
review process to have some central discussion point.
* I'll now switch to ESP-IDFv5 porting - on a new branch (based on the
v4) :
https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/experimental-esp-idf-v5
(empty at the moment).
Le 23/01/2023 à 22:19, Ludovic LANGE a écrit :
> Michael,
> Thanks for your help. FYI I've just pushed the last touches to the
> vehicle components which are now all converted to cmake and "should
> work". Still compiles under 3.3.x.
> A new things that need to be checked : in
> https://github.com/llange/Open-Vehicle-Monitoring-System-3/commit/f31117a48d4e293b2be01e8b48c1d580d0af834e
> i had to replace `INT` with another type. This time I choose `int32_t`
> but I'm not really sure because I could not find a way to see where
> and how INT was defined. I could only verify (by compilation tricks)
> that sizeof(INT) == sizeof(int32_t).
> Regarding cmake, I understand your concern with dependencies, and I
> did have the same reaction. There certainly is a way - I did not spend
> too much time on it. We will however have some "bugs" in the current
> state of things when disabling components in menuconfig where a
> dependency was implied and is now exposed. I'll let the cmake experts
> guide us :-)
> I'll now work on the compilation warnings.
> Btw, another thing that I need to mention is that from 3.3 to 5.x,
> many constants (used in sdkconfig) have been renamed etc... So our
> sdkconfig is upgraded by the build toolchain when we compile with 4.x
> or 5.x. I recommend doing a backup if it has been customized - in case of.
> Ludovic
> Le 23/01/2023 à 21:11, Michael Balzer a écrit :
>> Ludovic,
>> really great & appreciated you're going ahead on this. I second
>> skipping idf 4 and going directly for version 5. I'll try to get my
>> idf 5 build environment up ASAP.
>> I need to get into cmake myself as well. Needing to hard code
>> dependencies doesn't sound good though, I thought cmake is supposed
>> to be smart about this.
>> I'll have a look at porting the custom crash handler to idf 5. There
>> were some other additions that haven't been accepted by Espressif,
>> IIRC. I'll see if I can check them as well.
>> Am 23.01.23 um 11:04 schrieb Ludovic LANGE:
>>> Hi list,
>>> I am interested in upgrading our codebase to a latest ESP-IDF
>>> version (preferentially v5 which has just happened end of 2022 -
>>> Happy New Year ! :-)) - mostly to be able to use some components for
>>> which a backport seems difficult (for example :
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/752
>>> ), and as a matter of balance between stability vs latest bugfixes,
>>> security fixes, new features etc...
>>> In the past it seems that some endeavours already set the basis to
>>> make this happen
>>> (https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/263,
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/360
>>> I'm now trying to revive this effort, and after some work managed to
>>> have:
>>> * OVMS codebase building under v4.x using Makefile
>>> * OVMS codebase building under v4.x using cmake / idf.py (not 100%
>>> finished, multiple vehicle_* components are missing)
>>> (/*WARNING*: some important features of OVMS have been deactivated
>>> for the moment, see end of post)/
>>> The produced binaries seem to "work on my machine board", as they
>>> end with a "OVMS#" prompt and a few (very) basic tests look OK (to
>>> be honest, unfortunately no real tests have been done except to
>>> check that the binary does not crash during boot and a few seconds
>>> of run, checking that WiFi / web Interface is OK, sdcard is OK - but
>>> very basic)
>>> You'll find the changes here :
>>> (In the README.md, there is a short notice at the top with a few
>>> useful informations)
>>> I'm now reaching out here mostly for :
>>> * gathering feedback both around the effort (is it worth pursuing
>>> this goal ?) and the implementation (do my CMakeLists.txt look
>>> weird ? yes they do.)
>>> * having volunteers using those builds on real-world workload
>>> (which I cannot do at the moment) and finding bugs
>>> * guidance and fixes regarding the CMakeLists.txt files
>>> My next steps could be (of course, subject to feedback) :
>>> 1. Have 100% of the cmake implementation finished (all the missing
>>> vehicle_* components) -> easy (only missing time)
>>> 2. Work on the warnings (currently disabled in the builds) and try
>>> to fix as much as possible
>>> 3. Iron out all the bugs, improve the dev documentation -> need
>>> help on finding them with real-world use
>>> 4. 1st goal is to propose this result as a merge request (either as
>>> a whole, or split depending on feedback - ideally I would like
>>> to have a first (big) MR accepted quickly so that people can
>>> play with it, and deliver incremental updates as expected)
>>> 5. then work on the v5 and do the same.
>>> (Please note that my cmake skills are inexistent - so be careful
>>> when opening those files to not hurt yourself.)
>>> # The guidelines I tried to follow:
>>> * Stay compatible with our 3.3.x branch which should still compile
>>> without any issue nor loss of functionality
>>> * Keep Makefiles running for 3.3.x (and 4.x if possible)
>>> * When possible, isolate differences (between 3.x, 4.x, 5.x) by
>>> testing the versions of ESP-IDF.
>>> * Focus on 5.x (if there are impossibilities, let's make it easier
>>> to build v5.x than v4.x)
>>> * https://docs.espressif.com/projects/esp-idf/en/release-v4.4/esp32/api-reference/network/tcpip_adapter_migration.html
>>> * https://docs.espressif.com/projects/esp-idf/en/release-v4.4/esp32/api-guides/build-system.html#migrating-from-esp-idf-gnu-make-system
>>> * https://docs.espressif.com/projects/esp-idf/en/latest/esp32/migration-guides/release-5.x/5.0/index.html
>>> * https://docs.espressif.com/projects/esp-idf/en/latest/esp32/migration-guides/release-5.x/5.1/index.html
>>> # Missing features:
>>> In the course of this work I had to make some decisions to speed up
>>> the work - that will need to be acted upon:
>>> * I disabled the crash handler (`xt_set_error_handler_callback`
>>> and `esp_task_wdt_get_trigger_tasknames`) for the moment, we
>>> need to decide whether we "fork" ESP-IDF again to port it ; or
>>> if the new APIs are enough to (partially ?) reimplement it
>>> * There is a crash in `OvmsConsole::Poll` which I did not analyse
>>> (yet) and which I worked around by declaring a variable static.
>>> * I decided to transform our local copies of `wolfssh` and
>>> `wolfssl` in submodules (and move them one level below in terms
>>> of directories) - mainly to be able to have a CMakeLists.txt
>>> different from the upstream one.
>>> In the process, I "lost" one of our patches :
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/51444539047daef7bd2accb23ef40d1bc14fdb20
>>> and we need to decide how to handle this.
>>> * A lot of dependencies are now explicitly (hard-)coded in the
>>> CMakeLists.txt - which may, or may not be a good thing. Let's
>>> discuss it.
>>> * I had to change a set of defines into a header generation (in
>>> ovms_webserver) because I was unable to implement those in a
>>> satisfying manner in cmake. If you manage to do it, it's a win !
>>> * Build warnings were disabled to keep the output clean and focus
>>> on the build issues - but now they need to be re-activated.
>>> * etc...
>>> * Even if there is experimental support for cmake / idf.py in
>>> ESP-IDF 3.3.x, I did not make any effort to be compatible with it:
>>> o Our own fork does not seem to include this build system
>>> o It was experimental, the component API changed and I did not
>>> want to have edge case for something not used at the moment.
>>> Let me know your comments and questions.
>>> Best regards,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230126/ec7d0a08/attachment-0001.htm>
