[Ovmsdev] Firmware release 3.3.003 to MAIN / 3.3.004 preparation
Mon Jan 16 19:23:38 HKT 2023
Ok. I will release 3.3.003 to main in an hour or so.
> On 16 Jan 2023, at 7:08 PM, Michael Balzer <dexter at expeedo.de> wrote:
> The issues were not directly related to 3.3.003. Quoting from thread "Re: [Ovmsdev] SIM7600 Registration Denied":
>>> Am 09.09.22 um 21:00 schrieb Michael Balzer:
>>> Regarding the UART frame errors:
>>> But I now don't think this is a new issue, and this also affects modules quite differently, no idea depending on what circumstances: on the current run, my car module has lots of FIFO overflows & quite some MUX framing errors, but not a single UART frame error.
>>> IOW, I don't think we should let that block the release.
> We later merged the status poll splitting, which according to Craig helps a bit with network registration losses.
> Btw: my latest observation was, the power usage of the module rises when it enters a UART error phase. I have no idea if that gives any clue to a possible solution or is just a side effect of the high interrupt frequency.
> 3.3.004 will need some testing on edge still (the PR is still unmerged), and then some time on eap, so we should release 3.3.003 to main first.
>> Am 16.01.23 um 11:47 schrieb Mark Webb-Johnson:
>> Weren’t there some issues with 3.3.003 regarding UART frame errors that were concerning and delayed the release?
>> Happy to release if you think those weren’t related, or we can just push 3.3.004 if ready?
>>>> On 16 Jan 2023, at 4:06 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Signed PGP part
>>> We missed releasing 3.3.003 to /main. It's been in /eap since 09/22, /main still has 3.3.002 (since 03/22).
>>> Mark, would you please go ahead on this with api.openvehicles.com? I'll follow with ovms.dexters-web.de.
>>> Regarding 3.3.004:
>>> Thanks to all contributors we have three new vehicles in the queue:
>>> - Renault Zoe Phase 2 initial support by Carsten Schmiemann → https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/732
>>> - Hyundai Ioniq 5 initial support by Michael Geddes → https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/762
>>> - Mini Cooper SE initial support by Vincent Barat → https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/789
>>> Michael Geddes has also done a lot of great work on implementing full user metrics unit support at the module. This already works very well and stable in the shell, and the web UI extension now is also ready for inclusion (Michael, unless you've got some open todo I missed?) → https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/795
>>> To get the new vehicle support into /main ASAP, I suggest heading for the 3.3.004 release now, including Michael's user unit support.
>>> Please report any open issues that need to be addressed for the 3.3.004 release.
>>> Thanks & regards
