[Ovmsdev] Active GPS power consumption
Fri Feb 3 22:47:57 HKT 2023
Mark,
in the thread with Patrick Stein I measured the GPS antenna at ~ 5 mA /
55 mW, and added that info to
https://docs.openvehicles.com/en/latest/userguide/warnings.html#average-power-usage
> *GPS*consumption includes the active GPS antenna, which accounts for ~
> 5 mA / 55 mW. Antenna power cannot be switched by the module.
> ESP32*deep sleep mode*(e.g. triggered by the power management module)
> reduces the consumption to ~ 15 mA / 165 mW with the active GPS
> antenna attached, or ~ 10 mA / 110 mW with the GPS antenna detached.
> The hardware isn’t capable to go any lower than this.
But maybe you can do a more precise measurement, I only have some basic
electronics tools here.
Am 31.01.23 um 01:53 schrieb Mark Webb-Johnson:
> Re: https://www.openvehicles.com/node/3545
> I think it worthwhile having this discussion here. Synopsis seems to be:
> 1. Our modem design uses the SIMCOM reference design to power the
> active GPS antenna from VBAT. This increases power consumption
> (powering the active antenna), even if the GPS is turned off in
> software.
> 2. There is an alternative approach using pin 44 and the AT+CVAUXV /
> AT+CVAUXS commands to enable/disable and/or adjust voltage.
> Would be interesting to see the exact power readings and impact this
> change would make. I will try to get these this weekend.
> Regards, Mark
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230203/b5969de6/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230203/b5969de6/attachment-0001.sig>
