[Ovmsdev] SCP help and Cellular problem
Tamás Kovács
kommykt at gmail.com
Tue Apr 25 01:59:37 HKT 2023
No ssh.keys configured.
scp version: OpenSSH_9.0p1
I use user+password, but now i found the problem. In the documentation I
miss the -O option: Use the legacy SCP protocol for file transfers instead
of the SFTP protocol.
Michael Geddes <frog at bunyip.wheelycreek.net> ezt írta (időpont: 2023. ápr.
24., H, 9:11):
> Tamás,
> Did you make sure you had the 'ssh.keys' configuration set?
> What version is your 'scp'?
> Is there anything notable from the output? (I note you had -v )
> Have you tried it without a key and just using admin+password ?
> On Sun, 23 Apr 2023 at 20:59, Tamás Kovács <kommykt at gmail.com> wrote:
>> My first problem is i want to download log files from sd card but i can't
>> do it.
>> 1.) i use the following command: scp -o HostkeyAlgorithms=+ssh-rsa -o
>> PubkeyAcceptedAlgorithms=+ssh-rsa -v admin at nnb635.local:/sd/cellular.20230422-232741
>> but no file downloaded
>> Files on sd card from ovms
>> [image: Screenshot 2023-04-23 at 14.43.07.png]
>> I use MacOs Ventura 13.3.1 and
>> 2) I create 2 simultaneous cellular command output:
>> [image: IMG_0120.PNG]
>> 1. works everything's fine
>> 2. no cellular connection
>> I use hologram sim card on Hungary.
>> Any suggestion to resolve this issue?
>> My OVMS Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
>> Hologram SIM
>> Firmware: 1.0.16-1-g133c1144/ota_0/main (build idf
>> v3.3.4-849-g6e214dc33-dirty Feb 19 2023 20:08:56)
>> Same as OVMS main ait febr 19
>> Best regards:
>> Tamás Kovács
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230424/df8c1e96/attachment-0001.htm>
Name: Screenshot 2023-04-23 at 14.43.07.png
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230424/df8c1e96/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230424/df8c1e96/attachment-0003.png>
