[Ovmsdev] SCP help and Cellular problem
Mon Apr 24 15:10:27 HKT 2023
Tamás,
Did you make sure you had the  'ssh.keys' configuration set?
What version is your 'scp'?
Is there anything notable from the output? (I note you had -v )
Have you tried it without a key and just using admin+password ?
On Sun, 23 Apr 2023 at 20:59, Tamás Kovács <kommykt at gmail.com> wrote:
> My first problem is i want to download log files from sd card but i can't
> do it.
> 1.) i use the following command: scp -o HostkeyAlgorithms=+ssh-rsa -o
> PubkeyAcceptedAlgorithms=+ssh-rsa -v admin at nnb635.local:/sd/cellular.20230422-232741
> but no file downloaded
> Files on sd card from ovms
> [image: Screenshot 2023-04-23 at 14.43.07.png]
> I use MacOs Ventura 13.3.1 and
> 2) I create 2 simultaneous cellular command output:
> [image: IMG_0120.PNG]
> 1. works everything's fine
> 2. no cellular connection
> I use hologram sim card on Hungary.
> Any suggestion to resolve this issue?
> My OVMS Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
> Hologram SIM
> Firmware: 1.0.16-1-g133c1144/ota_0/main (build idf
> v3.3.4-849-g6e214dc33-dirty Feb 19 2023 20:08:56)
> Same as OVMS main ait febr 19
> Best regards:
> Tamás Kovács
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230424/770fafa2/attachment-0001.htm>
Name: Screenshot 2023-04-23 at 14.43.07.png
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230424/770fafa2/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230424/770fafa2/attachment-0003.png>
