[Ovmsdev] Ioniq 5 - Pushing up some prerequisite changes to components/vehicles
Michael Geddes
Sat Oct 29 22:25:07 HKT 2022
No problems at all, these were just thoughts.
So are those 2 PRs ok as they stand?
I have a couple more in the pipeline(as I previously described) before
the main I5 one.
Mihael
On Sat, 29 Oct 2022, 8:16 pm Michael Balzer, <dexter at expeedo.de> wrote:
> Michael,
> please don't change existing vehicle code for personal code style reasons.
> The existing data extraction methods have been working and will continue to
> work. By adding your utilities to the framework, we're giving everyone
> interested the opportunity to consider using these, we don't force them to
> do.
> Regarding your combined data extraction & metric setting utility, from my
> experience this won't be applicable in many (most) cases, or would need
> quite a lot of extra features exceeding a simple scaling. Applications
> often need or want to change metrics only indirectly after processing the
> raw data read from the bus, often in combination with other readings and/or
> delayed. Validity checks also need to be done in a broad variety, often
> with side conditions.
> A good approach is to first define & refine your generalized methods
> locally in your component. Keep an eye on the existing method signatures,
> so once you're happy with them it's easy to move them into the framework.
> That way you'll avoid having to break compatibility for other developers
> possibly already using an early release of your method.
> Am 27.10.22 um 09:36 schrieb Michael Geddes:
> While I'm still happy with the base data extraction tools, I'm wondering
> if some more direct tools would be better.
> For example some methods on the Base vehicle that takes a buffer, a byte
> index and template byte count a Metric object and a multiplier.. That will
> conditionally set the metric if the data is within bounds.
> Or methods on the metrics themselves that has similar results.
> I notice that index by 4 bit 'nibbles' is also a Thing That Is Done.
> I'm happy to implement that if there's appetite for it... And possibly
> look at a few Vehicles to switch to that
> On Mon, 24 Oct 2022, 1:26 pm Michael Geddes, <frog at bunyip.wheelycreek.net>
> wrote:
>> Ok - so I've pared down my requirements on the BMS module to the ability
>> to be able to cap the # of Voltages/Temperatures at a lower (only) value
>> than initialised at.
>> This means that the code to create the averages etc is just pulled out to
>> a private function here:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/753
>> This P/R request adds the buffer extraction tools (with 32bit length) to
>> ovms utils.
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/754
>> //.ichael
>> On Sun, 23 Oct 2022 at 17:38, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> Thanks Michael,
>>> I have taken it in, and I'll use std::string in poll once code. I guess
>>> it might make sense to convert everything else to std::string. It wouldn't
>>> be a big task.
>>> I had just taken out that commit and reworked anyway, and now that you
>>> say it's not the best way of doing things, I'm even happier I made that
>>> choice, as I had intended to possibly make more use of it and won't now.
>>> At the moment I'm using it to get the VIN (snipped) where I'll try a couple
>>> of times only, rather than continually poll for it.
>>> Hmm... yea - I guess I could do some dynamically created poll table.
>>> Will definitely consider that.
>>> Further comments inline below:
>>> On Sun, 23 Oct 2022 at 16:15, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Michael,
>>>> what I really dislike about your change is that it adds complexity to
>>>> the underlying function just to fulfill an -- in my eyes more academic --
>>>> type style choice: having to handle multiple buffer pointers just to
>>>> provide different typing approaches is bad. You could introduce a new
>>>> construct to provide a single polymorphic pointer, but that again adds
>>>> complexity.
>>>> Agreed, std::string is a bit type-sloppy in depending on char being
>>>> unsigned 8 bit, but that's all to consider, and can easily be enforced if
>>>> ever necessary.
>>>> On the plus side, std::string has far better library support, better
>>>> interoperability (see our use cases), and small string optimization, which
>>>> is especially useful for our platform, as most poll requests and responses
>>>> easily fit into the initial capacity, normally eliminating the need for
>>>> heap allocations.
>>>> So, besides the type independency, I think std::vector has no advantage
>>>> here.
>>>> There's another thing I'd like to address: it seems you're planning to
>>>> use single polls extensively?
>>>> If so, please don't, unless you're also going to do a full rewrite of
>>>> the poller towards a job/worker service task architecture (that's a very
>>>> old todo).
>>>> The single poll utility is really meant for sparse/manual polls outside
>>>> the normal polling scheme. See my comment on the method:
>>>> * PollSingleRequest: perform *prioritized synchronous* single
>>>> OBD2/UDS request
>>>> * Pass a full OBD2/UDS request (mode/type, PID, additional payload).
>>>> * The request is sent immediately, *aborting a running poll list
>>>> request*. The previous
>>>> * poller state is automatically restored after the request has been
>>>> performed, but
>>>> * *without any guarantee for repetition or omission of an aborted
>>>> poll*.
>>>> This was really meant more for user/script use than for standard
>>>> vehicle polls, though it's OK to use it, where applicable, with caution.
>>>> For all standard polling, install a PID list. You can vary a list by
>>>> the poll state, and you can switch lists if necessary. PID lists can easily
>>>> be generated dynamically, see the VWUP code for an example.
>>>> The place for general CAN utility methods is the
>>>> components/can/src/canutils module, general utility methods go into the
>>>> main/ovms_utils module.
>>> Ahh.. cool.
>>>> Regarding CAN buffer data extraction, there are currently probably as
>>>> many approaches as there are vehicle modules. Certainly would be nice to
>>>> have some standard way here, but won't be simple to rework the existing
>>>> vehicle adaptors.
>>>> The template approach is a nice one for a general solution, but keep in
>>>> mind not every vehicle will use big endian encoding, in some cases not even
>>>> consistently throughout the installed devices.
>>> I had already implemented little-endian and big-endian versions of the
>>> data extract. I will now explicitly mark all of them.
>>>> To be really general, your byte addressing needs to support more than
>>>> 256 bytes in the buffer.
>>> Consider that fixed.
>>>> Your templates also lack bit masking and shifting. Some devices use
>>>> packed structs with odd sized bit fields. The DBC engine has support for
>>>> all this, but not generalized. I remember Mark getting a headache from this…
>>> I have a get_bit<>() function and so I would propose it be implemented
>>> in a similar way... ie exract the byte first, then get the bits.
>>> Something like: extract_int<1,2>(byte) --> Extract bits len 2 starting
>>> from bit 1. We can easily sign-extend that too.
>>>> Regards,
>>>> Michael
>>>> Am 23.10.22 um 02:23 schrieb Michael Geddes:
>>>> Hi Michael,
>>>> Just wanted to say that if you override my objections on the
>>>> std::vector<unit8_t> in the single poll code then I'm fine with that, I
>>>> recognised that it's absolutely your call and that bit has a small impact
>>>> on my code so far. I can even add versions of the extraction functions
>>>> that use std::string if you want (they would just be inline
>>>> template wrappers around common code anyway so zero compiled cost).
>>>> Also: Is there a better place to put those templated functions? A
>>>> version of my sign_extend function is already being proposed being used
>>>> here:
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/736
>>>> - it would be good if both versions of this function were available in a
>>>> single place. (There's sign_extend<UINT, INT>(int_value, sign_bit) and
>>>> sign_extend<UINT, INT, SIGNBIT>(int_value) - so they should work fine as
>>>> overloaded template functions).
>>>> I would consider also whether I use std::string in my own code where
>>>> I'm extracting my data out of complete ISOTP poll results. Up to you. That
>>>> has slightly more impact, but the code change is pretty easy.
>>>> //.ichael
>>>> On Sat, 22 Oct 2022 at 07:56, Michael Geddes <
>>>> frog at bunyip.wheelycreek.net> wrote:
>>>>> Thanks Michael,
>>>>> I had already created my commits under the assumption that you would
>>>>> prefer the general changes separate from the vehicle-specific commits.
>>>>> I have created 3 pull requests so far.
>>>>> 1) the bug - that's a no-brainer.
>>>>> 2) 'finalisation' of temperatures and voltages. (Draft, see below)
>>>>> 3) vector poll. This is more a point of discussion (see below)
>>>>> A couple of the next bugs are kind of dependent on the second, so I'll
>>>>> wait until I get that sorted out.
>>>>> More comments below.
>>>>> On Fri, 21 Oct 2022 at 23:31, Michael Balzer <dexter at expeedo.de>
>>>>> wrote:
>>>>>> Michael,
>>>>>> Am 19.10.22 um 07:26 schrieb Michael Geddes:
>>>>>> > Hi all,
>>>>>> > I have 6 commits that I would _like_ to get pushed up that are
>>>>>> changes
>>>>>> > to components/vehicles required for my Ioniq 5 changes to work.
>>>>>> > I can push them all up in a single merge request for review, or
>>>>>> > separate them out into bits. Some of them I am expecting there to
>>>>>> be
>>>>>> > opinions on. I'm prepared to simplify some, and one in particular
>>>>>> has
>>>>>> > grounds for nixing. I think it's a good change, but I could manage
>>>>>> > without it.
>>>>>> Please keep PRs as small as possible, focusing on one specific
>>>>>> modification / addition at a time. That way, every merge commit can
>>>>>> easily be reverted if necessary, and changes can be followed and
>>>>>> referred to easily. Especially keep framework changes separate from
>>>>>> vehicle specific ones.
>>>>>> It's also OK to open the PRs tagged as drafts / work in progress,
>>>>>> that
>>>>>> helps in commenting on certain parts and tracing refinements. Create
>>>>>> one
>>>>>> branch for each PR, pushing new commits into the branch will
>>>>>> automatically update any open PR created from it.
>>>>> Ooh. That's useful. It's been a while since I've used github for
>>>>> collab. Switched the battery sensor P/R over to a draft.
>>>>>> > One is a simple bugfix - a literal one-character change:
>>>>>> > void OvmsVehicle::BmsRestartCellTemperatures()
>>>>>> > m_bms_bitset_t.clear();
>>>>>> > - m_bms_bitset_v.resize(m_bms_readings_t);
>>>>>> > + m_bms_bitset_t.resize(m_bms_readings_t);
>>>>>> > m_bms_bitset_ct = 0;
>>>>>> Obviously a copy & paste bug, nice find. I wonder how that could slip
>>>>>> through without causing crashes, as there are more voltages than
>>>>>> temperatures in most packs.
>>>>>> Please don't hesitate with opening PRs even for single fixes like
>>>>>> this,
>>>>>> the sooner we include them, the better.
>>>>> Yep. Done and understood.
>>>>>> > On is a simple code readability change. Using an enum instead of
>>>>>> magic
>>>>>> > status values for m_bms_talerts. Simple enough, but I'm prepared
>>>>>> to
>>>>>> > simplify that to a standard enum or get rid of it.
>>>>>> The magic values are simply alert levels, but go ahead, readability
>>>>>> is a
>>>>>> good goal.
>>>>>> I'll include it once the Battery Cell code is finalised.
>>>>>> > There's some battery related ones where I want to be able to not
>>>>>> quite
>>>>>> > know the number of cells from the start and let the OBD responses
>>>>>> specify.
>>>>>> Dynamic pack layout reconfiguration is no issue, I've done that on
>>>>>> the
>>>>>> Twizy (look for comments "update pack layout" or calls to
>>>>>> BmsSetCellArrangement*).
>>>>>> BmsSetCellArrangement does clear all the values... which is probably
>>>>> the main thing I was trying to avoid. Ie- I get to the end and go 'ooh..
>>>>> only this number of cells were filled in'. More comments in the P/R about
>>>>> what I want to achieve and fall-back positions.
>>>>>> > There's also a battery one where the info for the cells have
>>>>>> different
>>>>>> > timings (because one has other info), so I want to be able to clear
>>>>>> a
>>>>>> > range of cells rather than just reset and start filling the info
>>>>>> again.
>>>>>> That may be a bad idea, maybe better to implement some
>>>>>> synchronization /
>>>>>> drop readings out of sync.
>>>>>> Reaching a consistent state, the BMS will calculate deviations etc..
>>>>>> Crucial on that part is an analysis of the consistency of the cell
>>>>>> readings to determine the reliability of deviations exceeding
>>>>>> thresholds.
>>>>>> See my comments in BmsSetCellVoltage() and list thread:
>>>>>> http://lists.openvehicles.com/pipermail/ovmsdev/2021-February/015079.html
>>>>>> I've skimmed the comments but will read properly and digest. Yeah
>>>>> it might be best if I just clear the values at the start of the more often
>>>>> running one and then once the other ones come in it will finalise once it
>>>>> gets to the end of those.. so they aren't too far apart.
>>>>>> > I've modified slightly the dump for the battery cell
>>>>>> > voltage/temperature, allowing for either or both columns to be
>>>>>> visible
>>>>>> > if available. It also copes with the above 'not set' scenario.
>>>>>> Sounds good.
>>>>> I'll push this once the FinaliseCellVoltage pull-request is finalised
>>>>> and accepted.
>>>>>> > Finally, the controversial one: I am using std::vector<uint8_t> as
>>>>>> a
>>>>>> > buffer in my ioniq5 code.. and I wanted to be able to use it for
>>>>>> the
>>>>>> > polling instead of std::string. I've not replaced the std::string
>>>>>> but
>>>>>> > added the ability to have either.
>>>>>> > If my aversion to using std::string for binary data is misplaced,
>>>>>> then
>>>>>> > I'm ok with the currently small modification to my code that would
>>>>>> use
>>>>>> > the std::string version.
>>>>>> The general use case of ISO-TP data is actually dynamic binary
>>>>>> strings.
>>>>>> They are meant to and need to be easily aggregated, cut, merged,
>>>>>> partially extracted etc., so they really are strings, not vectors
>>>>>> (type
>>>>>> wise).
>>>>> Hmm.. I'm not sure I entirely agree about needing to
>>>>> aggregate/cut/merge; we know the size of the buffer after the first packet
>>>>> comes in so we can pre-set the buffer internal size and append data as it
>>>>> comes in without casting from uint8_t* to char *. Even if the size is
>>>>> wrong, we can still very easily append to a vector.
>>>>> ON the extraction, I have efficient templated functions that extract
>>>>> the data from the std::vector<uint8_t> buffer.. including to a std::string
>>>>> if required, or to big-endian/little-endian signed/unsigned integers of
>>>>> 1..4 bytes with sign-extension now. These also check bounds so are quite
>>>>> safe - possibly safer than the macros. The bounds check has already proved
>>>>> itself useful.
>>>>> I have pushed up a draft request 'single poll to buffer' as it is the
>>>>> easiest way to describe what I want to do. The first commit is the meat of
>>>>> the change ... but the second is adding all the utility functions. They
>>>>> probably don't belong in vehicle.h/cpp, but that's easy enough to change.
>>>>> I had them in my ioniq 5 specific code - but have shoved them in there just
>>>>> for a point of discussion.
>>>>> The great thing about the template functions here is that they should
>>>>> expand inline at compile time to quite efficient code.
>>>>>> Regards,
>>>>>> Michael
>>>>> //.ichael
>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221029/7d4496ff/attachment-0001.htm>
