[Ovmsdev] Webserver Alert pop-up font size?
Charles B Cangialose chip at cangmag.com
Sun Oct 23 19:24:41 HKT 2022
Greg D.,
This may be a different, but acceptable hardware solution to your problem— when the Bluetooth went out on my original JVC head unit in my 2010 Roadster Sport (#879), I replaced it (although I have retained the original JVC unit) with a Sony XAVAX1000, which is a single-DIN unit with a double-DIN touch screen (w/ Android Auto & Apple CarPlay[!]).  The double-DIN screen overhangs the bottom of the single-DIN chassis (see 2nd photo, below).  It is a relatively simple install (if you’ve wired the Raspberry Pi, you can do this install)—just wire matching and the filing of two small notches into the single-DIN chassis to latch into the existing mounting bracket for the original JVC head unit.  The minor down side is that the larger double-DIN screen slightly obscures from view the HVAC controls at the bottom of the dash (fortunately, I have them memorized)—way better than the mission required to cut up the dash to install the Roadster 2.5 double-DIN surround in a pre-2.5 Roadster.  The larger screen also makes for a sensible installation of a rearview camera (which I have also done).
https://www.amazon.com/Sony-XAVAX1000-CarPlay-Receiver-Bluetooth/dp/B07JDFKQJ5 <https://www.amazon.com/Sony-XAVAX1000-CarPlay-Receiver-Bluetooth/dp/B07JDFKQJ5>
> On Oct 23, 2022, at 1:31 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Greg,
> add a web hook plugin to /dashboard hook body.pre containing:
> <style>
> .modal pre { font-size: 25px; }
> </style>
> …or whatever font size works for you, default is 13px. You might also give adding "font-weight: bold;" a try.
> Am 23.10.22 um 04:14 schrieb Greg D.:
>> Hi folks,
>> While I'm thinking of it, a quick question.
>> I have my OVMS v3's Web "Dashboard" being displayed by a Raspberry Pi in my car (a 2010 Tesla Roadster).  The Pi is keyboard-less; just a mouse pad to click around the display, which is the car's tiny in-dash Av/Nav radio (the single-DIN one).  VGA resolution and physically small, but surprisingly functional.  Sort of a HUD, but with all the gauges represented and appropriate to the car.
>> When the Roadster urps up an alert, a pop-up window gets displayed with the alert code.  That's great, but the font size is really tiny.  It's very hard to read, especially while driving.
>> My question:  Is there a way to increase the size of the font, preferably with some sort of persistent configuration command to the OVMSv3?  There's no keyboard, so zooming in with control-plus isn't available.
>> Thanks,
>> Greg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221023/a2d3dee6/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221023/a2d3dee6/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221023/a2d3dee6/attachment-0003.png>
