[Ovmsdev] Introduction - message replay and other topics
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Sat Oct 22 23:40:08 HKT 2022
Michael,
You're absolutely right, I did not have a look at the web UI (Config /
Wifi) while researching this feature, and have been only using the shell
for the configuration and the doc.
In order to complement the existing doc, please find here an update
proposal:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/746
Ludovic
Le 22/10/2022 à 15:30, Michael Balzer a écrit :
> Ludovic,
> you've possible mistaken the scan command for the scan mode. Scan mode
> is meant for that scenario. You can configure multiple APs via the web
> UI (Config→Wifi: client networks) or via shell using the config
> command. You can also configure the signal levels for dropping network
> associations.
> To configure from the shell, add a network like this: "config set
> wifi.ssid <ssid> <passphrase>"
> Am 22.10.22 um 14:25 schrieb Ludovic LANGE:
>> Hi Michael,
>> So if you don't mind, I'll be creating GitHub "issues" for following
>> those improvements, in order to describe, plan, document, follow the
>> progress on those ideas.
>> Regarding WiFi, the idea would be more like the "mesh" mode ; but
>> with different SSIDs.
>> Say you have a list of different SSIDs / password. The device should
>> try to connect to the first one in the config. If unable to connect,
>> or if the RSSI steadily falls below a certain minimum, it will try
>> the next in order in the config. Then when it reaches the end of the
>> list, it cycles back to the start. Or optionally it should try to
>> connect via modem connection (but I'd make this a config option also)
>> - and if this one drops also, back to wifi APs list.
>> (RSSI level should be a config item also).
>> Use-case is the following:
>> I have a vehicle under test ; it has a OVMS on-board. The test pilot
>> does some different journeys. Some starting from "home", ending at
>> "shop A". Then from "shop A" to "shop B". etc... and back to "home".
>> It's not possible (and not wanted) to have all these locations set up
>> with the same SSID / Password. So it could be interesting to have
>> OVMS able to connect to each different AP.
>> (Automatically - the test pilot is not expected to deal with OVMS
>> configuration)
>> Scanning mode seems (I have not fully tested all the configuration)
>> to be able to list the visible APs ; but it seems there is no
>> provision to configure passwords for multiple one ? Let me know if I
>> understood it incorrectly.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221022/ca797920/attachment.htm>
