[Ovmsdev] Android App beta
Fri Oct 21 21:37:06 HKT 2022
Everyone,
some new fixes & optimizations, and I've added a "latest" directory to
the hub, so the latest builds are easy to reach for anyone interested:
https://github.com/openvehicles/Open-Vehicle-Android/tree/master/latest
The builds are "officially" signed, so can be installed over an existing
play store release and vice versa.
Am 16.10.22 um 19:16 schrieb Chris van der Meijden:
> Hi Michael
> I compiled the new code without any troubles (again on the commandline
> with -x lint).
> Features and Parameters are working perfect now. My Fireplace app can
> send its "web intent" and my (simple) KWGT widget also does what it
> has to do.
> Everything seems fine for me. Many thanks, again.
> Regards
> Chris
> Am Sonntag, dem 16.10.2022 um 17:53 +0200 schrieb Michael Balzer:
>> New builds:
>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22101601-release.apk
>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22101601-debug.apk
>> This also fixes the feature & parameter bug, but major change is the
>> command activity & service rework.
>> Command shortcuts now also work without the service enabled, i.e.
>> start the service on demand. This even works reasonably fast.
>> I've removed all UI activities from the service, so this should now
>> basically work the same way on all Android versions.
>> The command activity now also supports queueing, multiple commands
>> can be sent to it at once. It will execute them in series, with each
>> result being shown for 5 seconds or according to user interaction. On
>> commands returning multiple rows, only the first 10-15 will be shown.
>> Command intent extras for action com.openvehicles.OVMS.action.COMMAND
>> are now:
>> * Intent extras expected/supported: * - vehicleid (optional) * -
>> apikey or (with vehicleid) password * - title (optional) * - command
>> (optional, no command means only change the car) * * Commands need to
>> be in user input syntax: * - MMI/USSD commands: prefix "*", example:
>> "*100#" * - Modem commands: prefix "@", example: "@ATI" * - MP MSG
>> commands: prefix "#", example: "#31" * - Text commands: everything
>> else, example: "stat"
>> Changes are on github, tests & feedback are welcome.
>> If you've added command bookmarks somewhere before, you may need to
>> delete and recreate them to see the title in the UI.
>> Am 09.10.22 um 22:11 schrieb Michael Balzer:
>> Am 09.10.22 um 20:40 schrieb van der Meijden, Chris:
>>> Features and Parameters are not showing. Clicking there brings me to
>>> Messages.
>> Oops, yes, confirmed.
>>> Starting in landscape and then turning to portrait is fixed :-)
>> Nothing changed with the old ScaleLayout, it's on my list, but with
>> low priority.
>> So I don't think it's fixed, was working sometimes before.
>>> Am 9. Oktober 2022 20:22:50 MESZ schrieb Chris van der Meijden
>>> <chris at arachnon.de>:
>>>> It compiled and runs without troubles, but I needed to build with
>>>> gradlew build -x lint
>>>> Am Sonntag, dem 09.10.2022 um 19:16 +0200 schrieb Michael Balzer:
>>>>> Chris, Michael, thanks for tests & feedback.
>>>>> Code changes so far are now in the hub:
>>>>> https://github.com/openvehicles/Open-Vehicle-Android/commit/c23b3dbd772bdae7e82601797cd3a71c2623a78c
>>>>> This has become a very large commit, and it mixes some version
>>>>> update changes that became necessary & deprecation fixes I should
>>>>> have kept separate, but cannot disentangle now.
>>>>> Some things still to do for the release, most notably removing UI
>>>>> interaction from the service. So if any other stuff shall be added
>>>>> to the next release, tell me & go ahead preparing that.
>>>>> Regards,
>>>>> Michael
>>>>> Am 09.10.22 um 17:09 schrieb Chris van der Meijden:
>>>>> I tested the new build. Everything is working fine for me.
>>>>> I think it is a good idea to restrict the respond to only
>>>>> action.COMMAND and leave SendCommand for background operation.
>>>>> Am Sonntag, dem 09.10.2022 um 16:05 +0200 schrieb Michael Balzer:
>>>>>> Chris, Michael,
>>>>>> new builds with the announced new security scheme:
>>>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-release.apk
>>>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-debug.apk
>>>>>> This adds a new API key authorization to both Intent interfaces.
>>>>>> The API key is automatically generated on App launch, and can be
>>>>>> viewed, copied and regenerated from the general options page.
>>>>>> It can be used for both command intents by passing in as extra
>>>>>> "apikey", allowing to omit the vehicle password. The vehicle id
>>>>>> is now also optional on both interfaces, if omitted the current
>>>>>> vehicle will be used. To change the car you can either pass the
>>>>>> vehicle password or the apikey along with the vehicle id.
>>>>>> So with am, you can now use:
>>>>>> * am broadcast -a com.openvehicles.OVMS.SendCommand -e apikey …
>>>>>> -e command "stat"
>>>>>> * am start -a com.openvehicles.OVMS.action.COMMAND -e apikey …
>>>>>> -e command "stat"
>>>>>> The second guarantees the activity is started, so the response
>>>>>> will be visible.
>>>>>> I'll probably restrict displaying the response to action.COMMAND
>>>>>> in the next build, so SendCommand will be for background
>>>>>> operations while action.COMMAND is for interactive uses.
>>>>>> Android 10 (API 29) has a new limitation for displaying results
>>>>>> (starting UI activities) from a service
>>>>>> (https://developer.android.com/guide/components/activities/background-starts),
>>>>>> so that works only by chance now anyway.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 09.10.22 um 12:45 schrieb Chris van der Meijden:
>>>>>> Hi Michael,
>>>>>> thank you for your response. As always of great help :-)
>>>>>> Good that you could find a possible security risc concerning the
>>>>>> credentials.
>>>>>> Regards
>>>>>> Chris
>>>>>> Am Sonntag, dem 09.10.2022 um 10:53 +0200 schrieb Michael Balzer:
>>>>>>> Chris,
>>>>>>> AFAIK you need to have an adb connection or a rooted Android to
>>>>>>> use "am", so not suitable as a general way to call OVMS commands.
>>>>>>> With your (rooted) Lineageos you should be able to use it like this:
>>>>>>> sel_vehicleid xxx -e sel_server_password xxx -e msg_command "7,stat"
>>>>>>> And I missed mentioning I also added support for user command
>>>>>>> syntax to "SendCommand", so you can now alternatively do
>>>>>>> sel_vehicleid xxx -e sel_server_password xxx -e command "stat"
>>>>>>> Playing with am, I found out…
>>>>>>> am start -n com.openvehicles.OVMS/.api.CommandActivity -a
>>>>>>> com.openvehicles.OVMS.action.COMMAND -e command "stat"
>>>>>>> …actually works to trigger the new command receiver. I thought
>>>>>>> restricting the new receiver to app-internal intents would be
>>>>>>> possible, but it apparently isn't. That bothers me, it means any
>>>>>>> App could issue a command without knowing the credentials or an
>>>>>>> auth key and without a previous explicit user interaction to
>>>>>>> allow this.
>>>>>>> So I need to add a credentials check to the new action, which
>>>>>>> means you will need to reinstall all bookmarks / shortcut
>>>>>>> assignments. Please wait with complex setups until I've added that.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 08.10.22 um 19:30 schrieb Chris van der Meijden:
>>>>>>> I have been playing with the "SH" function of KWGT and tried to
>>>>>>> send a broadcast over the shell, like adb:
>>>>>>> 'am broadcast -acom.whereismywifeserver.intent.TEST --essms_body
>>>>>>> "test fromadb"'
>>>>>>> That did not work, there where "rights" issues.
>>>>>>> I took a look at the commands documentation. I will play a bit
>>>>>>> with that.
>>>>>>> Thanx for explaining!
>>>>>>> Am Samstag, dem 08.10.2022 um 18:54 +0200 schrieb Michael Balzer:
>>>>>>>> Chris,
>>>>>>>> "com.openvehicles.OVMS.SendCommand" is the old command action,
>>>>>>>> it's still supported and should work the same way as before,
>>>>>>>> except there are some new extras in the response intent.
>>>>>>>> The "SendCommand" interface is raw MP function level, that's
>>>>>>>> why you need to prefix "7," for text commands (7 = execute text
>>>>>>>> command). Other MP commands work just the same way as raw
>>>>>>>> commands, e.g. "20,<pin>" will lock the car if supported.
>>>>>>>> (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html)
>>>>>>>> The newly added command intent action is
>>>>>>>> "com.openvehicles.OVMS.action.COMMAND", it just takes one extra
>>>>>>>> "command", which takes the command just as entered in the
>>>>>>>> notification page. See help there for the syntax, text commands
>>>>>>>> can be given as in the shell, to send the above MP lock
>>>>>>>> command, you'd enter "#20,<pin>". This action currently always
>>>>>>>> sends the command to the currently selected vehicle.
>>>>>>>> KWGT doesn't support sending intents, that's why I've done all
>>>>>>>> this.
>>>>>>>> To call a stored command from KWGT, set a suitable element's
>>>>>>>> touch handler to "start shortcut". After clicking on that
>>>>>>>> action, you can open a selector. It will show the list of
>>>>>>>> shortcut providers installed including the OVMS App now. Click
>>>>>>>> on the OVMS entry, then select the command from the list of
>>>>>>>> stored commands.
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 08.10.22 um 17:54 schrieb Chris van der Meijden:
>>>>>>>> Hi Michael
>>>>>>>> I just installed the release apk on my degoogled Lineageos 19.1.
>>>>>>>> Installation went without any troubles. I tested the broadcast
>>>>>>>> with my fireplace app via webinent:
>>>>>>>> action: 'com.openvehicles.OVMS.SendCommand',
>>>>>>>> extras: {
>>>>>>>> sel_vehicleid: vid,
>>>>>>>> sel_server_password: pwd,
>>>>>>>> msg_command: '7,climatecontrol on'
>>>>>>>> It works still fine and I can see the response dialog in the
>>>>>>>> OVMS app.
>>>>>>>> I don't understand the "MP function". Do you have an example
>>>>>>>> for for i.e. "climatecontrol on" via Buttons in KWGT? I'd love
>>>>>>>> to test that :-)
>>>>>>>> And do you know if there is a way to send intent broadcasts
>>>>>>>> with KWGT? I tried with a "GLOBALE", but I could not get that
>>>>>>>> to work.
>>>>>>>> Regards
>>>>>>>> Chris
>>>>>>>> Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael Balzer:
>>>>>>>>> New test build:
>>>>>>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk
>>>>>>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk
>>>>>>>>> This includes major extensions & code rewrites, I think I'll
>>>>>>>>> bump the version to 4.0 when releasing this to Google Play.
>>>>>>>>> Main goal & outcome of this effort: command bookmarks.
>>>>>>>>> The App now offers stored commands (see notifications tab).
>>>>>>>>> Stored commands can be pinned to the launcher and selected
>>>>>>>>> from third party Apps like KWGT as shortcuts to execute on
>>>>>>>>> triggers / actions.
>>>>>>>>> So this enabled custom widgets to include buttons triggering
>>>>>>>>> car commands.
>>>>>>>>> Commands are given using the user syntax, i.e. don't need the
>>>>>>>>> MP function prefix. You can still call an MP function by using
>>>>>>>>> the user syntax, i.e. "#…".
>>>>>>>>> Command responses are shown as a dialog with a timeoout of 5
>>>>>>>>> seconds unless you hold it by touching or begin scrolling a
>>>>>>>>> long response. If the App is paused it will be resumed and
>>>>>>>>> switch to the notifications page (which keeps a record of all
>>>>>>>>> commands & responses). If the App isn't running, only the
>>>>>>>>> response dialog is shown on the launcher.
>>>>>>>>> All this of course needs the service to be enabled & allow
>>>>>>>>> commands to be sent.
>>>>>>>>> Command responses are also broadcasted now, so KWGT et al can
>>>>>>>>> receive them -- but they will currently need to know the
>>>>>>>>> command sent previously and copy command responses if they
>>>>>>>>> need to keep them, I don't know if KWGT can do that (Automagic
>>>>>>>>> can). KWGT seems to only have a simple variable storage model.
>>>>>>>>> I think about extending the ApiService to keep a command queue
>>>>>>>>> so the broadcast can at least carry the command, the response
>>>>>>>>> is supposedly produced for. Unfortunately the MP API cannot
>>>>>>>>> guarantee this, as it doesn't currently return a copy of the
>>>>>>>>> original command or a command ID reference with the response,
>>>>>>>>> so this would at best be a guess. Not sure if users actually
>>>>>>>>> need this.
>>>>>>>>> Note: I haven't pushed the code changes to github yet, I'd
>>>>>>>>> first like to get some test feedback. I've tested this on
>>>>>>>>> Android 6, 7, 11 & 13, but not on any degoogled Androids.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 26.09.22 um 17:26 schrieb Chris van der Meijden:
>>>>>>>>> For an includable example it would be nice if we could send
>>>>>>>>> the vehicle image from the OVMS app to KWGT.
>>>>>>>>> You can assign "Activities" to the "Touch" event on an image.
>>>>>>>>> Would be cool if that works, so we can start the remote
>>>>>>>>> climate control similar to how I do that with my
>>>>>>>>> OVMS-Fireplace app:
>>>>>>>>> https://github.com/devmarxx/OVMS-Fireplace
>>>>>>>>> Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb Michael Balzer:
>>>>>>>>>> Nice, please go ahead if you want to create an includable
>>>>>>>>>> example widget :-)
>>>>>>>>>> I've found out you can also use progress bars to display
>>>>>>>>>> values, enable formula input on the "step" & set the formular
>>>>>>>>>> to e.g. $br(ovms, car_soc)$.
>>>>>>>>>> Works, although I need to convert all car model values to
>>>>>>>>>> strings for KWGT. Btw, I also need to unroll the TPMS arrays,
>>>>>>>>>> they are split into a "_cnt" & "_<n>" variables. I need to
>>>>>>>>>> add an info on this to the wiki.
>>>>>>>>>> I haven't found out how to send a broadcast from KWGT yet, is
>>>>>>>>>> that possible? That would enable creating command shortcuts &
>>>>>>>>>> buttons as with Automagic.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 26.09.22 um 12:13 schrieb Chris van der Meijden:
>>>>>>>>>> Correction:
>>>>>>>>>> $br(ovms, sel_vehicle_label)$
>>>>>>>>>> Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van
>>>>>>>>>> der Meijden:
>>>>>>>>>>> I like the new KWGT Widget feature:
>>>>>>>>>>> Above is the Tesla Widget of our Model 3, beneath that my
>>>>>>>>>>> OVMS KWGT widget of our VW e-UP.
>>>>>>>>>>> I had to allow "Passing data to other apps". The syntax for
>>>>>>>>>>> getting the intent variables to text in KWGT is i.e.
>>>>>>>>>>> $br(ovms, car_sel_vehicle_label)$
>>>>>>>>>>> Other variables can be found here:
>>>>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-Intent-data
>>>>>>>>>>> The image is local on the filesystem of the phone and does
>>>>>>>>>>> not come by intent.
>>>>>>>>>>> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael
>>>>>>>>>>> Balzer:
>>>>>>>>>>> No, icon can only be 0 from the else branch, in that case it
>>>>>>>>>>> shall fall back to the default image.
>>>>>>>>>>> But I've meanwhile found (I think) your maps/track crash,
>>>>>>>>>>> commit is already in the hub. The checkbox handler didn't
>>>>>>>>>>> check if the map object is initialized.
>>>>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/FragMap.java#L319
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>>>>> Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
>>>>>>>>>>> Just guessing, but does
>>>>>>>>>>> int icon;
>>>>>>>>>>> in MyGcmListenerService.java
>>>>>>>>>>> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at
>>>>>>>>>>> line 132
>>>>>>>>>>> not need to be initialized like
>>>>>>>>>>> int icon = 0;
>>>>>>>>>>> now you use
>>>>>>>>>>> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default)
>>>>>>>>>>> at line 150 now?
>>>>>>>>>>> As the images and the Google stuff are related to that
>>>>>>>>>>> integer it made me thinking ...
>>>>>>>>>>> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael
>>>>>>>>>>> Balzer:
>>>>>>>>>>>> Chris,
>>>>>>>>>>>> that's not a crash log, that's just a warning.
>>>>>>>>>>>> On that warning: the App requests
>>>>>>>>>>>> android.permission.ACCESS_FINE_LOCATION by it's manifest.
>>>>>>>>>>>> Maybe with LineageOS you need to manually give it that
>>>>>>>>>>>> permission?
>>>>>>>>>>>> A crash log has class "E" (error) and includes an exception
>>>>>>>>>>>> and a backtrace, for an example see:
>>>>>>>>>>>> https://issuetracker.google.com/issues/201308676#comment4
>>>>>>>>>>>> On the crash: maybe it's because you don't have the Google
>>>>>>>>>>>> components, not sure if FragMap can handle that.
>>>>>>>>>>>> The forum post relates to /e/OS … maybe I need some
>>>>>>>>>>>> emulator images running alternative Androids now…
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Michael
>>>>>>>>>>>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
>>>>>>>>>>>> Hey Michael,
>>>>>>>>>>>> this is from logcat when I change "Track vehicle" and the
>>>>>>>>>>>> app crashes:
>>>>>>>>>>>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission
>>>>>>>>>>>> Denial: receiving Intent {
>>>>>>>>>>>> act=android.intent.action.SERVICE_STATE flg=0x1000010 (has
>>>>>>>>>>>> extras) } to ProcessRecord{8dcdd54
>>>>>>>>>>>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148)
>>>>>>>>>>>> requires android.permission.ACCESS_FINE_LOCATION due to
>>>>>>>>>>>> sender android (uid 1001)
>>>>>>>>>>>> I saw now, that this crash also happens in the production app.
>>>>>>>>>>>> The widget is running well. I will keep the app running for
>>>>>>>>>>>> while and will see if it stays stable.
>>>>>>>>>>>> Regards
>>>>>>>>>>>> Chris
>>>>>>>>>>>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael
>>>>>>>>>>>> Balzer:
>>>>>>>>>>>>> Chris,
>>>>>>>>>>>>> thanks for testing. A crash log would help on any crashes
>>>>>>>>>>>>> you see. Btw, I don't bump the revision until the actual
>>>>>>>>>>>>> release build.
>>>>>>>>>>>>> Crashes related to the car image don't occur immediately,
>>>>>>>>>>>>> it sometimes takes hours of use before it happens. When it
>>>>>>>>>>>>> does, clearing the App cache fixes the crash for another
>>>>>>>>>>>>> random period.
>>>>>>>>>>>>> Speed optimization was one goal. What about the widget?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Michael
>>>>>>>>>>>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
>>>>>>>>>>>>> Hey Michael,
>>>>>>>>>>>>> I just installed the "release" Version on LineageOS 19.1
>>>>>>>>>>>>> (Android 12) without Google components.
>>>>>>>>>>>>> The vehicle setup was without any troubles. I could select
>>>>>>>>>>>>> the yellow VW e-UP image without crashing.
>>>>>>>>>>>>> The App version is set wrong under "Vehicle info" (3.19.1,
>>>>>>>>>>>>> 2021122401).
>>>>>>>>>>>>> Everything seems to be faster than before.
>>>>>>>>>>>>> When I change the checkbox on "Track vehicle" under
>>>>>>>>>>>>> "Position" the App crashes. But after a new start of the
>>>>>>>>>>>>> app the value of the checkbox has changed.
>>>>>>>>>>>>> Perhaps this first impression is of some help.
>>>>>>>>>>>>> Regards
>>>>>>>>>>>>> Chris
>>>>>>>>>>>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael
>>>>>>>>>>>>> Balzer:
>>>>>>>>>>>>>> Everyone,
>>>>>>>>>>>>>> I'm currently working on the next Android release
>>>>>>>>>>>>>> including KustomWidget support and a native app widget
>>>>>>>>>>>>>> based on the old Automagic gauge widget.
>>>>>>>>>>>>>> Automagic has been dead for some time now, and it keeps
>>>>>>>>>>>>>> crashing on Androids >= 7.
>>>>>>>>>>>>>> My changes so far are in the hub, APK builds are
>>>>>>>>>>>>>> available here:
>>>>>>>>>>>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>>>>>>>>>>>>>> * debug build for extended logging:
>>>>>>>>>>>>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>>>>>>>>>>>>>> There's an issue with the App related to Android >= 10
>>>>>>>>>>>>>> though, which I haven't found yet. It's been reported in
>>>>>>>>>>>>>> the forum:
>>>>>>>>>>>>>> * https://www.openvehicles.com/node/3410
>>>>>>>>>>>>>> I could use some help with that, I've got no idea other
>>>>>>>>>>>>>> than blaming Android.
>>>>>>>>>>>>>> I've seen the effect in my emulator tests, and it seems
>>>>>>>>>>>>>> to occur more frequently with non-roadster images.
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221021/1d79848d/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221021/1d79848d/attachment-0001.sig>
