[Ovmsdev] Android App beta
Mon Oct 10 04:10:00 HKT 2022
I build from Android Studio, no special settings (should all be in the
files).
Am 09.10.22 um 20:22 schrieb Chris van der Meijden:
> It compiled and runs without troubles, but I needed to build with
> gradlew build -x lint
> Am Sonntag, dem 09.10.2022 um 19:16 +0200 schrieb Michael Balzer:
>> Chris, Michael, thanks for tests & feedback.
>> Code changes so far are now in the hub:
>> https://github.com/openvehicles/Open-Vehicle-Android/commit/c23b3dbd772bdae7e82601797cd3a71c2623a78c
>> This has become a very large commit, and it mixes some version update
>> changes that became necessary & deprecation fixes I should have kept
>> separate, but cannot disentangle now.
>> Some things still to do for the release, most notably removing UI
>> interaction from the service. So if any other stuff shall be added to
>> the next release, tell me & go ahead preparing that.
>> Am 09.10.22 um 17:09 schrieb Chris van der Meijden:
>> I tested the new build. Everything is working fine for me.
>> I think it is a good idea to restrict the respond to only
>> action.COMMAND and leave SendCommand for background operation.
>> Am Sonntag, dem 09.10.2022 um 16:05 +0200 schrieb Michael Balzer:
>>> Chris, Michael,
>>> new builds with the announced new security scheme:
>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-release.apk
>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100901-debug.apk
>>> This adds a new API key authorization to both Intent interfaces. The
>>> API key is automatically generated on App launch, and can be viewed,
>>> copied and regenerated from the general options page.
>>> It can be used for both command intents by passing in as extra
>>> "apikey", allowing to omit the vehicle password. The vehicle id is
>>> now also optional on both interfaces, if omitted the current vehicle
>>> will be used. To change the car you can either pass the vehicle
>>> password or the apikey along with the vehicle id.
>>> So with am, you can now use:
>>>   * am broadcast -a com.openvehicles.OVMS.SendCommand -e apikey … -e
>>>     command "stat"
>>>   * am start -a com.openvehicles.OVMS.action.COMMAND -e apikey … -e
>>>     command "stat"
>>> The second guarantees the activity is started, so the response will
>>> be visible.
>>> I'll probably restrict displaying the response to action.COMMAND in
>>> the next build, so SendCommand will be for background operations
>>> while action.COMMAND is for interactive uses.
>>> Android 10 (API 29) has a new limitation for displaying results
>>> (starting UI activities) from a service
>>> (https://developer.android.com/guide/components/activities/background-starts),
>>> so that works only by chance now anyway.
>>> Am 09.10.22 um 12:45 schrieb Chris van der Meijden:
>>> Hi Michael,
>>> thank you for your response. As always of great help :-)
>>> Good that you could find a possible security risc concerning the
>>> credentials.
>>> Regards
>>> Chris
>>> Am Sonntag, dem 09.10.2022 um 10:53 +0200 schrieb Michael Balzer:
>>>> Chris,
>>>> AFAIK you need to have an adb connection or a rooted Android to use
>>>> "am", so not suitable as a general way to call OVMS commands.
>>>> With your (rooted) Lineageos you should be able to use it like this:
>>>> am broadcast -a com.openvehicles.OVMS.SendCommand -e sel_vehicleid
>>>> xxx -e sel_server_password xxx -e msg_command "7,stat"
>>>> And I missed mentioning I also added support for user command
>>>> syntax to "SendCommand", so you can now alternatively do
>>>> xxx -e sel_server_password xxx -e command "stat"
>>>> Playing with am, I found out…
>>>> am start -n com.openvehicles.OVMS/.api.CommandActivity -a
>>>> com.openvehicles.OVMS.action.COMMAND -e command "stat"
>>>> …actually works to trigger the new command receiver. I thought
>>>> restricting the new receiver to app-internal intents would be
>>>> possible, but it apparently isn't. That bothers me, it means any
>>>> App could issue a command without knowing the credentials or an
>>>> auth key and without a previous explicit user interaction to allow
>>>> this.
>>>> So I need to add a credentials check to the new action, which means
>>>> you will need to reinstall all bookmarks / shortcut assignments.
>>>> Please wait with complex setups until I've added that.
>>>> Regards,
>>>> Michael
>>>> Am 08.10.22 um 19:30 schrieb Chris van der Meijden:
>>>> I have been playing with the "SH" function of KWGT and tried to
>>>> send a broadcast over the shell, like adb:
>>>> 'am broadcast -acom.whereismywifeserver.intent.TEST --essms_body
>>>> "test fromadb"'
>>>> That did not work, there where "rights" issues.
>>>> I took a look at the commands documentation. I will play a bit with
>>>> that.
>>>> Thanx for explaining!
>>>> Am Samstag, dem 08.10.2022 um 18:54 +0200 schrieb Michael Balzer:
>>>>> Chris,
>>>>> "com.openvehicles.OVMS.SendCommand" is the old command action,
>>>>> it's still supported and should work the same way as before,
>>>>> except there are some new extras in the response intent.
>>>>> The "SendCommand" interface is raw MP function level, that's why
>>>>> you need to prefix "7," for text commands (7 = execute text
>>>>> command). Other MP commands work just the same way as raw
>>>>> commands, e.g. "20,<pin>" will lock the car if supported.
>>>>> (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html)
>>>>> The newly added command intent action is
>>>>> "com.openvehicles.OVMS.action.COMMAND", it just takes one extra
>>>>> "command", which takes the command just as entered in the
>>>>> notification page. See help there for the syntax, text commands
>>>>> can be given as in the shell, to send the above MP lock command,
>>>>> you'd enter "#20,<pin>". This action currently always sends the
>>>>> command to the currently selected vehicle.
>>>>> KWGT doesn't support sending intents, that's why I've done all this.
>>>>> To call a stored command from KWGT, set a suitable element's touch
>>>>> handler to "start shortcut". After clicking on that action, you
>>>>> can open a selector. It will show the list of shortcut providers
>>>>> installed including the OVMS App now. Click on the OVMS entry,
>>>>> then select the command from the list of stored commands.
>>>>> Regards,
>>>>> Michael
>>>>> Am 08.10.22 um 17:54 schrieb Chris van der Meijden:
>>>>> Hi Michael
>>>>> I just installed the release apk on my degoogled Lineageos 19.1.
>>>>> Installation went without any troubles. I tested the broadcast
>>>>> with my fireplace app via webinent:
>>>>> action: 'com.openvehicles.OVMS.SendCommand',
>>>>> extras: {
>>>>>    sel_vehicleid: vid,
>>>>>    sel_server_password: pwd,
>>>>>    msg_command: '7,climatecontrol on'
>>>>> It works still fine and I can see the response dialog in the OVMS app.
>>>>> I don't understand the "MP function". Do you have an example for
>>>>> for i.e. "climatecontrol on" via Buttons in KWGT? I'd love to test
>>>>> that :-)
>>>>> And do you know if there is a way to send intent broadcasts with
>>>>> KWGT? I tried with a "GLOBALE", but I could not get that to work.
>>>>> Regards
>>>>> Chris
>>>>> Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael Balzer:
>>>>>> New test build:
>>>>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk
>>>>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk
>>>>>> This includes major extensions & code rewrites, I think I'll bump
>>>>>> the version to 4.0 when releasing this to Google Play.
>>>>>> Main goal & outcome of this effort: command bookmarks.
>>>>>> The App now offers stored commands (see notifications tab).
>>>>>> Stored commands can be pinned to the launcher and selected from
>>>>>> third party Apps like KWGT as shortcuts to execute on triggers /
>>>>>> actions.
>>>>>> So this enabled custom widgets to include buttons triggering car
>>>>>> commands.
>>>>>> Commands are given using the user syntax, i.e. don't need the MP
>>>>>> function prefix. You can still call an MP function by using the
>>>>>> user syntax, i.e. "#…".
>>>>>> Command responses are shown as a dialog with a timeoout of 5
>>>>>> seconds unless you hold it by touching or begin scrolling a long
>>>>>> response. If the App is paused it will be resumed and switch to
>>>>>> the notifications page (which keeps a record of all commands &
>>>>>> responses). If the App isn't running, only the response dialog is
>>>>>> shown on the launcher.
>>>>>> All this of course needs the service to be enabled & allow
>>>>>> commands to be sent.
>>>>>> Command responses are also broadcasted now, so KWGT et al can
>>>>>> receive them -- but they will currently need to know the command
>>>>>> sent previously and copy command responses if they need to keep
>>>>>> them, I don't know if KWGT can do that (Automagic can). KWGT
>>>>>> seems to only have a simple variable storage model.
>>>>>> I think about extending the ApiService to keep a command queue so
>>>>>> the broadcast can at least carry the command, the response is
>>>>>> supposedly produced for. Unfortunately the MP API cannot
>>>>>> guarantee this, as it doesn't currently return a copy of the
>>>>>> original command or a command ID reference with the response, so
>>>>>> this would at best be a guess. Not sure if users actually need this.
>>>>>> Note: I haven't pushed the code changes to github yet, I'd first
>>>>>> like to get some test feedback. I've tested this on Android 6, 7,
>>>>>> 11 & 13, but not on any degoogled Androids.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 26.09.22 um 17:26 schrieb Chris van der Meijden:
>>>>>> For an includable example it would be nice if we could send the
>>>>>> vehicle image from the OVMS app to KWGT.
>>>>>> You can assign "Activities" to the "Touch" event on an image.
>>>>>> Would be cool if that works, so we can start the remote climate
>>>>>> control similar to how I do that with my OVMS-Fireplace app:
>>>>>> https://github.com/devmarxx/OVMS-Fireplace
>>>>>> Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb Michael Balzer:
>>>>>>> Nice, please go ahead if you want to create an includable
>>>>>>> example widget :-)
>>>>>>> I've found out you can also use progress bars to display values,
>>>>>>> enable formula input on the "step" & set the formular to e.g.
>>>>>>> $br(ovms, car_soc)$.
>>>>>>> Works, although I need to convert all car model values to
>>>>>>> strings for KWGT. Btw, I also need to unroll the TPMS arrays,
>>>>>>> they are split into a "_cnt" & "_<n>" variables. I need to add
>>>>>>> an info on this to the wiki.
>>>>>>> I haven't found out how to send a broadcast from KWGT yet, is
>>>>>>> that possible? That would enable creating command shortcuts &
>>>>>>> buttons as with Automagic.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 26.09.22 um 12:13 schrieb Chris van der Meijden:
>>>>>>> Correction:
>>>>>>> $br(ovms, sel_vehicle_label)$
>>>>>>> Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van der
>>>>>>> Meijden:
>>>>>>>> I like the new KWGT Widget feature:
>>>>>>>> Above is the Tesla Widget of our Model 3, beneath that my OVMS
>>>>>>>> KWGT widget of our VW e-UP.
>>>>>>>> I had to allow "Passing data to other apps". The syntax for
>>>>>>>> getting the intent variables to text in KWGT is i.e.
>>>>>>>> $br(ovms, car_sel_vehicle_label)$
>>>>>>>> Other variables can be found here:
>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-Intent-data
>>>>>>>> The image is local on the filesystem of the phone and does not
>>>>>>>> come by intent.
>>>>>>>> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer:
>>>>>>>> No, icon can only be 0 from the else branch, in that case it
>>>>>>>> shall fall back to the default image.
>>>>>>>> But I've meanwhile found (I think) your maps/track crash,
>>>>>>>> commit is already in the hub. The checkbox handler didn't check
>>>>>>>> if the map object is initialized.
>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/FragMap.java#L319
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
>>>>>>>> Just guessing, but does
>>>>>>>> int icon;
>>>>>>>> in MyGcmListenerService.java
>>>>>>>> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at
>>>>>>>> line 132
>>>>>>>> not need to be initialized like
>>>>>>>> int icon = 0;
>>>>>>>> now you use
>>>>>>>> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default)
>>>>>>>> at line 150 now?
>>>>>>>> As the images and the Google stuff are related to that integer
>>>>>>>> it made me thinking ...
>>>>>>>> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
>>>>>>>>> Chris,
>>>>>>>>> that's not a crash log, that's just a warning.
>>>>>>>>> On that warning: the App requests
>>>>>>>>> android.permission.ACCESS_FINE_LOCATION by it's manifest.
>>>>>>>>> Maybe with LineageOS you need to manually give it that permission?
>>>>>>>>> A crash log has class "E" (error) and includes an exception
>>>>>>>>> and a backtrace, for an example see:
>>>>>>>>> https://issuetracker.google.com/issues/201308676#comment4
>>>>>>>>> On the crash: maybe it's because you don't have the Google
>>>>>>>>> components, not sure if FragMap can handle that.
>>>>>>>>> The forum post relates to /e/OS … maybe I need some emulator
>>>>>>>>> images running alternative Androids now…
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
>>>>>>>>> Hey Michael,
>>>>>>>>> this is from logcat when I change "Track vehicle" and the app
>>>>>>>>> crashes:
>>>>>>>>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission
>>>>>>>>> Denial: receiving Intent {
>>>>>>>>> act=android.intent.action.SERVICE_STATE flg=0x1000010 (has
>>>>>>>>> extras) } to ProcessRecord{8dcdd54
>>>>>>>>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148)
>>>>>>>>> requires android.permission.ACCESS_FINE_LOCATION due to sender
>>>>>>>>> android (uid 1001)
>>>>>>>>> I saw now, that this crash also happens in the production app.
>>>>>>>>> The widget is running well. I will keep the app running for
>>>>>>>>> while and will see if it stays stable.
>>>>>>>>> Regards
>>>>>>>>> Chris
>>>>>>>>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
>>>>>>>>>> Chris,
>>>>>>>>>> thanks for testing. A crash log would help on any crashes you
>>>>>>>>>> see. Btw, I don't bump the revision until the actual release
>>>>>>>>>> build.
>>>>>>>>>> Crashes related to the car image don't occur immediately, it
>>>>>>>>>> sometimes takes hours of use before it happens. When it does,
>>>>>>>>>> clearing the App cache fixes the crash for another random period.
>>>>>>>>>> Speed optimization was one goal. What about the widget?
>>>>>>>>>> Thanks,
>>>>>>>>>> Michael
>>>>>>>>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
>>>>>>>>>> Hey Michael,
>>>>>>>>>> I just installed the "release" Version on LineageOS 19.1
>>>>>>>>>> (Android 12) without Google components.
>>>>>>>>>> The vehicle setup was without any troubles. I could select
>>>>>>>>>> the yellow VW e-UP image without crashing.
>>>>>>>>>> The App version is set wrong under "Vehicle info" (3.19.1,
>>>>>>>>>> 2021122401).
>>>>>>>>>> Everything seems to be faster than before.
>>>>>>>>>> When I change the checkbox on "Track vehicle" under
>>>>>>>>>> "Position" the App crashes. But after a new start of the app
>>>>>>>>>> the value of the checkbox has changed.
>>>>>>>>>> Perhaps this first impression is of some help.
>>>>>>>>>> Regards
>>>>>>>>>> Chris
>>>>>>>>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
>>>>>>>>>>> Everyone,
>>>>>>>>>>> I'm currently working on the next Android release including
>>>>>>>>>>> KustomWidget support and a native app widget based on the
>>>>>>>>>>> old Automagic gauge widget.
>>>>>>>>>>> Automagic has been dead for some time now, and it keeps
>>>>>>>>>>> crashing on Androids >= 7.
>>>>>>>>>>> My changes so far are in the hub, APK builds are available here:
>>>>>>>>>>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>>>>>>>>>>>   * debug build for extended logging:
>>>>>>>>>>>     https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>>>>>>>>>>> There's an issue with the App related to Android >= 10
>>>>>>>>>>> though, which I haven't found yet. It's been reported in the
>>>>>>>>>>> forum:
>>>>>>>>>>>   * https://www.openvehicles.com/node/3410
>>>>>>>>>>> I could use some help with that, I've got no idea other than
>>>>>>>>>>> blaming Android.
>>>>>>>>>>> I've seen the effect in my emulator tests, and it seems to
>>>>>>>>>>> occur more frequently with non-roadster images.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/2ee56ff5/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/2ee56ff5/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/2ee56ff5/attachment-0001.sig>
