[Ovmsdev] Introduction - message replay and other topics
Ludovic LANGE ll-ovmsdev at lange.nom.fr
Wed Oct 19 06:44:14 HKT 2022
Thanks Michael !
I'll try to have a look at the can play framework - it could surely help
me speed up my dashboard development work (for the moment I'm injecting
on a real CAN Bus but it's not always ideal). But not everything is
clear for me in this concept, given that I don't know the whole
ecosystem very well (not helping is my inability to read C++).
If @Mark is reading, would you mind exchanging on this topic if you have
some time (and memories of what you had in mind when designing this part) ?
Here is a random dump of some other crazy ideas I'd like to share with
the list (read: things I thought would be nice to discuss):
  * Some features I like (seen in the doc of a related product):
      o Wifi: multiple AP/SSIDs defined in order to auto-connect to the
        strongest signal (or ability to "roam" from one site to another
        without having to re-configure the Wifi)
      o CanLog: ability to "split" log files according to some criterion
        : either the size (in bytes) of the log file ; or the timespan
        of the capture
      o CanFormat: support for reading / writing a compressed file
        format (e.g. Vector's BLF, etc...)
      o CanLog: ability to sync the log files to an external server
        (whenever a network connection is available), with (optional in
        my mind) local delete of the file after transfer.
  * DBC-based vehicle :
      o In my DBC experiments, I found I needed to register new metrics.
        While it's possible to create a new "vehicle_" module and have
        the registering occur there, it kinds of defeat the dynamic
        aspect of the DBC approach. So I was wondering if we could
        introduce a dynamic registration of metrics (e.g.: have a config
        setup, or a file in the vfs, that lists all the metrics that we
        want to register during vehicle module loading)
  * Wireguard interface : I was toying with the idea of having a
    network-enabled OVMS auto-registering in a dedicated network ; and
    being "locally" available, mdns working, web and ssh reachable...
    while exposing no local service on its main interface. I've seen
    discussion around a "firewall", and with this approach there is no
    more need to have one if no services are exposed.
    Don't know if it's feasible, a project like
    https://github.com/smartalock/wireguard-lwip is certainly
    interesting to look at (and also
    https://github.com/ciniml/WireGuard-ESP32-Arduino).
Let me know what you think about any of this
Ludovic
Le 10/10/2022 à 19:34, Michael Balzer a écrit :
> Ludovic, welcome :-)
> you're right, can play is unfinished. It seems it wasn't needed up to
> now, you're welcome to finish it. Mark would best comment on what's
> missing there, as it was his concept & framework draft.
> Another local option is replaying a set of specific frame sequences by
> scripts running series of "can tx" and/or "can rx" commands.
> Regarding dashboard development, you can simply add a random metrics
> data generator to the UI. You can find templates for this in the examples:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/ovms_webserver/dev/metrics.htm#L235
> Documentation of course can always be improved :-)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221019/cc746683/attachment.htm>
