[Ovmsdev] HUD Connected to OVMS not working
Michael Geddes
Sun Oct 16 12:36:58 HKT 2022
Thanks for the response Greg.
I tried what you suggested and it still doesn't turn on. (The 'on/off' is a
slider switch rather than a momentary button)
I also went into Jaycar and tried this simple HUD:
https://www.jaycar.com.au/gps-speedometer-head-up-display-with-obdii-data/p/LA9036?gclid=CjwKCAjwtKmaBhBMEiwAyINuwAF-ZMXvydGdYsUu--w37CmHr6mf1Emx_o2shbA3IvUNUQ4k-ZWtcBoCwQoQAvD_BwE
Results were the same (didn't have time to find any settings though - as I
got permission to try it before I bought it).
I also confirmed that the cable is wired exactly as specified (no more, no
less) including 120ohm resistor.
I'm starting to think there's an issue with the OVMS board itself!?
//.ichael
On Sun, 16 Oct 2022 at 02:09, Greg D. <gregd2350 at gmail.com> wrote:
> Hi Michael,
> Yeah, odd.
> I see in the description that there's a power switch on the side of the
> unit, so that will probably interact with the voltage transition. After
> turning Ext12v on, and pushing the on/off button on the HUD unit, I would
> expect it would turn on. After that, transitioning Ext12v on/off should
> trigger the unit to turn on/off as well.
> Assuming you do get it running, what I would suggest is to create a pair
> of Events to force Ext12v on and off when the car state transitions. For
> my car, the states are vehicle.on and vehicle.off, but yours might be
> different. In the "on" event script I also stop and restart the obd2ecu
> process, as that will clear the CAN3 bus hang that I've experienced. It's
> a long shot, but perhaps the HUD isn't turning on because it's not seeing
> CAN traffic. You might try the 12v off / ecu stop / ecu start / 12v on
> sequence manually and see if that wakes the HUD up.
> OVMS# vfs cat /store/events/vehicle.on/myevent
> power ext12v off
> obdii ecu stop
> obdii ecu start can3
> power ext12v on
> OVMS# vfs cat /store/events/vehicle.off/myevent
> power ext12v off
> Good luck!
> Greg
> Michael Geddes wrote:
> More information:
> I'm definitely getting power on the OVMS -> OBDII cable. 11 volts when
> the car is off, and 12.6 volts when the car is on. I'm assuming this is
> quite deliberate. (And like 0.2 volts when the power to the ext12v is off).
> By default, the HUD was needing (according to docs - probably) 13.2v to
> trigger it to turn on.. so I connected it directly to the car OBD and
> changed that setting to 11.5 volts.
> When I turned the car off (still connected directly).. the HUD remained on
> as it was still getting > 12V.. so the setting definitely worked.
> Unfortunately when I then connected the OVMS to the OBDII and the OVMS ->
> OBDII cable to the HUD - it still didn't turn on. :( (oh and yes - "power
> ext12v on".
> Any thoughts on this would be welcome.
> //.ichael
> On Sat, 15 Oct 2022 at 07:15, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> Hi all,
>> Anybody got any experience with HUDs?
>> I bought this simple HUD from FastTech:
>> https://www.fasttech.com/products/9686283
>> When connected direct to the OBDII port, it powers on and seems to
>> function. When I connect it to the OVMS module with the standard
>> https://www.fasttech.com/products/9652027 the HUD doesn't even power on.
>> It's stated draw is 200ma which afaict should be fine. I'm pretty sure
>> the 12V power is getting to PIN 16... though I will try again to make sure.
>> I only have a crappy little Multimeter.
>> On the Troubleshooting it states:
>> "HUD only available for cars with OBD2 and EU-OBD agreements ... HUD
>> Products don't support JOBD and OBDI protocol."
>> The OBD HUD connector has the following pins:
>> 4* Chassis
>> 5* Signal Ground
>> 6 CAN High
>> 7 *ISO9141 K Line*
>> 14 CAN Low
>> 15 *ISO9141 L Line*
>> 16 Vehicle Battery +ve
>> * Long pins
>> These are the standard OVMS supplied pins:
>> 4 Chassis Ground
>> 5 Chassis Ground
>> 6 CAN H (Primary)
>> 14 CAN L (Primary)
>> 16 +12V
>> So obviously the main difference is the lack of K / L lines in the OVMS
>> ... but I wouldn't have thought that would have prevented it from powering
>> up.
>> Does anybody have any thoughts on this?
>> //.ichael
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221016/f6b63d06/attachment-0001.htm>
