[Ovmsdev] Android App beta
Sun Oct 9 16:53:45 HKT 2022
Chris,
AFAIK you need to have an adb connection or a rooted Android to use
"am", so not suitable as a general way to call OVMS commands.
With your (rooted) Lineageos you should be able to use it like this:
am broadcast -a com.openvehicles.OVMS.SendCommand -e sel_vehicleid xxx
-e sel_server_password xxx -e msg_command "7,stat"
And I missed mentioning I also added support for user command syntax to
"SendCommand", so you can now alternatively do
-e sel_server_password xxx -e command "stat"
Playing with am, I found out…
am start -n com.openvehicles.OVMS/.api.CommandActivity -a
com.openvehicles.OVMS.action.COMMAND -e command "stat"
…actually works to trigger the new command receiver. I thought
restricting the new receiver to app-internal intents would be possible,
but it apparently isn't. That bothers me, it means any App could issue a
command without knowing the credentials or an auth key and without a
previous explicit user interaction to allow this.
So I need to add a credentials check to the new action, which means you
will need to reinstall all bookmarks / shortcut assignments. Please wait
with complex setups until I've added that.
Am 08.10.22 um 19:30 schrieb Chris van der Meijden:
> I have been playing with the "SH" function of KWGT and tried to send a
> broadcast over the shell, like adb:
> 'am broadcast -acom.whereismywifeserver.intent.TEST --essms_body "test
> fromadb"'
> That did not work, there where "rights" issues.
> I took a look at the commands documentation. I will play a bit with that.
> Thanx for explaining!
> Am Samstag, dem 08.10.2022 um 18:54 +0200 schrieb Michael Balzer:
>> Chris,
>> "com.openvehicles.OVMS.SendCommand" is the old command action, it's
>> still supported and should work the same way as before, except there
>> are some new extras in the response intent.
>> The "SendCommand" interface is raw MP function level, that's why you
>> need to prefix "7," for text commands (7 = execute text command).
>> Other MP commands work just the same way as raw commands, e.g.
>> "20,<pin>" will lock the car if supported.
>> (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html)
>> The newly added command intent action is
>> "com.openvehicles.OVMS.action.COMMAND", it just takes one extra
>> "command", which takes the command just as entered in the
>> notification page. See help there for the syntax, text commands can
>> be given as in the shell, to send the above MP lock command, you'd
>> enter "#20,<pin>". This action currently always sends the command to
>> the currently selected vehicle.
>> KWGT doesn't support sending intents, that's why I've done all this.
>> To call a stored command from KWGT, set a suitable element's touch
>> handler to "start shortcut". After clicking on that action, you can
>> open a selector. It will show the list of shortcut providers
>> installed including the OVMS App now. Click on the OVMS entry, then
>> select the command from the list of stored commands.
>> Am 08.10.22 um 17:54 schrieb Chris van der Meijden:
>> Hi Michael
>> I just installed the release apk on my degoogled Lineageos 19.1.
>> Installation went without any troubles. I tested the broadcast with
>> my fireplace app via webinent:
>> action: 'com.openvehicles.OVMS.SendCommand',
>> extras: {
>> sel_vehicleid: vid,
>> sel_server_password: pwd,
>> msg_command: '7,climatecontrol on'
>> It works still fine and I can see the response dialog in the OVMS app.
>> I don't understand the "MP function". Do you have an example for for
>> i.e. "climatecontrol on" via Buttons in KWGT? I'd love to test that :-)
>> And do you know if there is a way to send intent broadcasts with
>> KWGT? I tried with a "GLOBALE", but I could not get that to work.
>> Regards
>> Chris
>> Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael Balzer:
>>> New test build:
>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk
>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk
>>> This includes major extensions & code rewrites, I think I'll bump
>>> the version to 4.0 when releasing this to Google Play.
>>> Main goal & outcome of this effort: command bookmarks.
>>> The App now offers stored commands (see notifications tab). Stored
>>> commands can be pinned to the launcher and selected from third party
>>> Apps like KWGT as shortcuts to execute on triggers / actions.
>>> So this enabled custom widgets to include buttons triggering car
>>> commands.
>>> Commands are given using the user syntax, i.e. don't need the MP
>>> function prefix. You can still call an MP function by using the user
>>> syntax, i.e. "#…".
>>> Command responses are shown as a dialog with a timeoout of 5 seconds
>>> unless you hold it by touching or begin scrolling a long response.
>>> If the App is paused it will be resumed and switch to the
>>> notifications page (which keeps a record of all commands &
>>> responses). If the App isn't running, only the response dialog is
>>> shown on the launcher.
>>> All this of course needs the service to be enabled & allow commands
>>> to be sent.
>>> Command responses are also broadcasted now, so KWGT et al can
>>> receive them -- but they will currently need to know the command
>>> sent previously and copy command responses if they need to keep
>>> them, I don't know if KWGT can do that (Automagic can). KWGT seems
>>> to only have a simple variable storage model.
>>> I think about extending the ApiService to keep a command queue so
>>> the broadcast can at least carry the command, the response is
>>> supposedly produced for. Unfortunately the MP API cannot guarantee
>>> this, as it doesn't currently return a copy of the original command
>>> or a command ID reference with the response, so this would at best
>>> be a guess. Not sure if users actually need this.
>>> Note: I haven't pushed the code changes to github yet, I'd first
>>> like to get some test feedback. I've tested this on Android 6, 7, 11
>>> & 13, but not on any degoogled Androids.
>>> Am 26.09.22 um 17:26 schrieb Chris van der Meijden:
>>> For an includable example it would be nice if we could send the
>>> vehicle image from the OVMS app to KWGT.
>>> You can assign "Activities" to the "Touch" event on an image. Would
>>> be cool if that works, so we can start the remote climate control
>>> similar to how I do that with my OVMS-Fireplace app:
>>> https://github.com/devmarxx/OVMS-Fireplace
>>> Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb Michael Balzer:
>>>> Nice, please go ahead if you want to create an includable example
>>>> widget :-)
>>>> I've found out you can also use progress bars to display values,
>>>> enable formula input on the "step" & set the formular to e.g.
>>>> $br(ovms, car_soc)$.
>>>> Works, although I need to convert all car model values to strings
>>>> for KWGT. Btw, I also need to unroll the TPMS arrays, they are
>>>> split into a "_cnt" & "_<n>" variables. I need to add an info on
>>>> this to the wiki.
>>>> I haven't found out how to send a broadcast from KWGT yet, is that
>>>> possible? That would enable creating command shortcuts & buttons as
>>>> with Automagic.
>>>> Regards,
>>>> Michael
>>>> Am 26.09.22 um 12:13 schrieb Chris van der Meijden:
>>>> Correction:
>>>> $br(ovms, sel_vehicle_label)$
>>>> Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van der Meijden:
>>>>> I like the new KWGT Widget feature:
>>>>> Above is the Tesla Widget of our Model 3, beneath that my OVMS
>>>>> KWGT widget of our VW e-UP.
>>>>> I had to allow "Passing data to other apps". The syntax for
>>>>> getting the intent variables to text in KWGT is i.e.
>>>>> $br(ovms, car_sel_vehicle_label)$
>>>>> Other variables can be found here:
>>>>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-Intent-data
>>>>> The image is local on the filesystem of the phone and does not
>>>>> come by intent.
>>>>> Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer:
>>>>> No, icon can only be 0 from the else branch, in that case it shall
>>>>> fall back to the default image.
>>>>> But I've meanwhile found (I think) your maps/track crash, commit
>>>>> is already in the hub. The checkbox handler didn't check if the
>>>>> map object is initialized.
>>>>> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/FragMap.java#L319
>>>>> Regards,
>>>>> Michael
>>>>> Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
>>>>> Just guessing, but does
>>>>> int icon;
>>>>> in MyGcmListenerService.java
>>>>> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at
>>>>> line 132
>>>>> not need to be initialized like
>>>>> int icon = 0;
>>>>> now you use
>>>>> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default)
>>>>> at line 150 now?
>>>>> As the images and the Google stuff are related to that integer it
>>>>> made me thinking ...
>>>>> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
>>>>>> Chris,
>>>>>> that's not a crash log, that's just a warning.
>>>>>> On that warning: the App requests
>>>>>> android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe
>>>>>> with LineageOS you need to manually give it that permission?
>>>>>> A crash log has class "E" (error) and includes an exception and a
>>>>>> backtrace, for an example see:
>>>>>> https://issuetracker.google.com/issues/201308676#comment4
>>>>>> On the crash: maybe it's because you don't have the Google
>>>>>> components, not sure if FragMap can handle that.
>>>>>> The forum post relates to /e/OS … maybe I need some emulator
>>>>>> images running alternative Androids now…
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
>>>>>> Hey Michael,
>>>>>> this is from logcat when I change "Track vehicle" and the app
>>>>>> crashes:
>>>>>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial:
>>>>>> receiving Intent { act=android.intent.action.SERVICE_STATE
>>>>>> flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54
>>>>>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires
>>>>>> android.permission.ACCESS_FINE_LOCATION due to sender android
>>>>>> (uid 1001)
>>>>>> I saw now, that this crash also happens in the production app.
>>>>>> The widget is running well. I will keep the app running for while
>>>>>> and will see if it stays stable.
>>>>>> Regards
>>>>>> Chris
>>>>>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
>>>>>>> Chris,
>>>>>>> thanks for testing. A crash log would help on any crashes you
>>>>>>> see. Btw, I don't bump the revision until the actual release build.
>>>>>>> Crashes related to the car image don't occur immediately, it
>>>>>>> sometimes takes hours of use before it happens. When it does,
>>>>>>> clearing the App cache fixes the crash for another random period.
>>>>>>> Speed optimization was one goal. What about the widget?
>>>>>>> Thanks,
>>>>>>> Michael
>>>>>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
>>>>>>> Hey Michael,
>>>>>>> I just installed the "release" Version on LineageOS 19.1
>>>>>>> (Android 12) without Google components.
>>>>>>> The vehicle setup was without any troubles. I could select the
>>>>>>> yellow VW e-UP image without crashing.
>>>>>>> The App version is set wrong under "Vehicle info" (3.19.1,
>>>>>>> 2021122401).
>>>>>>> Everything seems to be faster than before.
>>>>>>> When I change the checkbox on "Track vehicle" under "Position"
>>>>>>> the App crashes. But after a new start of the app the value of
>>>>>>> the checkbox has changed.
>>>>>>> Perhaps this first impression is of some help.
>>>>>>> Regards
>>>>>>> Chris
>>>>>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
>>>>>>>> Everyone,
>>>>>>>> I'm currently working on the next Android release including
>>>>>>>> KustomWidget support and a native app widget based on the old
>>>>>>>> Automagic gauge widget.
>>>>>>>> Automagic has been dead for some time now, and it keeps
>>>>>>>> crashing on Androids >= 7.
>>>>>>>> My changes so far are in the hub, APK builds are available here:
>>>>>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>>>>>>>> * debug build for extended logging:
>>>>>>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>>>>>>>> There's an issue with the App related to Android >= 10 though,
>>>>>>>> which I haven't found yet. It's been reported in the forum:
>>>>>>>> * https://www.openvehicles.com/node/3410
>>>>>>>> I could use some help with that, I've got no idea other than
>>>>>>>> blaming Android.
>>>>>>>> I've seen the effect in my emulator tests, and it seems to
>>>>>>>> occur more frequently with non-roadster images.
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/b4ea3de5/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/b4ea3de5/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221009/b4ea3de5/attachment-0001.sig>
