[Ovmsdev] Android App beta
Chris van der Meijden
chris at arachnon.de
Sun Oct 9 01:30:49 HKT 2022
I have been playing with the "SH" function of KWGT and tried to send a
broadcast over the shell, like adb:
'am broadcast -a com.whereismywifeserver.intent.TEST --es sms_body
"test from adb"'
That did not work, there where "rights" issues.
I took a look at the commands documentation. I will play a bit with
that.
Thanx for explaining!
Am Samstag, dem 08.10.2022 um 18:54 +0200 schrieb Michael Balzer:
> Chris,
> "com.openvehicles.OVMS.SendCommand" is the old command action, it's
> still supported and should work the same way as before, except there
> are some new extras in the response intent.
> The "SendCommand" interface is raw MP function level, that's why you
> need to prefix "7," for text commands (7 = execute text command).
> Other MP commands work just the same way as raw commands, e.g.
> "20,<pin>" will lock the car if supported.
> (https://docs.openvehicles.com/en/latest/protocol_v2/commands.html)
> The newly added command intent action is
> "com.openvehicles.OVMS.action.COMMAND", it just takes one extra
> "command", which takes the command just as entered in the
> notification page. See help there for the syntax, text commands can
> be given as in the shell, to send the above MP lock command, you'd
> enter "#20,<pin>". This action currently always sends the command to
> the currently selected vehicle.
> KWGT doesn't support sending intents, that's why I've done all this.
> To call a stored command from KWGT, set a suitable element's touch
> handler to "start shortcut". After clicking on that action, you can
> open a selector. It will show the list of shortcut providers
> installed including the OVMS App now. Click on the OVMS entry, then
> select the command from the list of stored commands.
> Am 08.10.22 um 17:54 schrieb Chris van der Meijden:
> Hi Michael
> I just installed the release apk on my degoogled Lineageos 19.1.
> Installation went without any troubles. I tested the broadcast with
> my fireplace app via webinent:
> action: 'com.openvehicles.OVMS.SendCommand',
> extras: {
> sel_vehicleid: vid,
> sel_server_password: pwd,
> msg_command: '7,climatecontrol on'
> It works still fine and I can see the response dialog in the OVMS
> app.
> I don't understand the "MP function". Do you have an example for for
> i.e. "climatecontrol on" via Buttons in KWGT? I'd love to test that
> And do you know if there is a way to send intent broadcasts with
> KWGT? I tried with a "GLOBALE", but I could not get that to work.
> Regards
> Chris
> Am Samstag, dem 08.10.2022 um 15:37 +0200 schrieb Michael Balzer:
> > New test build:
> > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-release.apk
> > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22100801-debug.apk
> > This includes major extensions & code rewrites, I think I'll bump
> > the version to 4.0 when releasing this to Google Play.
> > Main goal & outcome of this effort: command bookmarks.
> > The App now offers stored commands (see notifications tab). Stored
> > commands can be pinned to the launcher and selected from third
> > party Apps like KWGT as shortcuts to execute on triggers / actions.
> > So this enabled custom widgets to include buttons triggering car
> > commands.
> > Commands are given using the user syntax, i.e. don't need the MP
> > function prefix. You can still call an MP function by using the
> > user syntax, i.e. "#…".
> > Command responses are shown as a dialog with a timeoout of 5
> > seconds unless you hold it by touching or begin scrolling a long
> > response. If the App is paused it will be resumed and switch to the
> > notifications page (which keeps a record of all commands &
> > responses). If the App isn't running, only the response dialog is
> > shown on the launcher.
> > All this of course needs the service to be enabled & allow commands
> > to be sent.
> > Command responses are also broadcasted now, so KWGT et al can
> > receive them -- but they will currently need to know the command
> > sent previously and copy command responses if they need to keep
> > them, I don't know if KWGT can do that (Automagic can). KWGT seems
> > to only have a simple variable storage model.
> > I think about extending the ApiService to keep a command queue so
> > the broadcast can at least carry the command, the response is
> > supposedly produced for. Unfortunately the MP API cannot guarantee
> > this, as it doesn't currently return a copy of the original command
> > or a command ID reference with the response, so this would at best
> > be a guess. Not sure if users actually need this.
> > Note: I haven't pushed the code changes to github yet, I'd first
> > like to get some test feedback. I've tested this on Android 6, 7,
> > 11 & 13, but not on any degoogled Androids.
> > Regards,
> > Michael
> > Am 26.09.22 um 17:26 schrieb Chris van der Meijden:
> > For an includable example it would be nice if we could send the
> > vehicle image from the OVMS app to KWGT.
> > You can assign "Activities" to the "Touch" event on an image. Would
> > be cool if that works, so we can start the remote climate control
> > similar to how I do that with my OVMS-Fireplace app:
> > https://github.com/devmarxx/OVMS-Fireplace
> > Am Montag, dem 26.09.2022 um 13:56 +0200 schrieb Michael Balzer:
> > > Nice, please go ahead if you want to create an includable example
> > > widget :-)
> > > I've found out you can also use progress bars to display values,
> > > enable formula input on the "step" & set the formular to e.g.
> > > $br(ovms, car_soc)$.
> > > Works, although I need to convert all car model values to strings
> > > for KWGT. Btw, I also need to unroll the TPMS arrays, they are
> > > split into a "_cnt" & "_<n>" variables. I need to add an info on
> > > this to the wiki.
> > > I haven't found out how to send a broadcast from KWGT yet, is
> > > that possible? That would enable creating command shortcuts &
> > > buttons as with Automagic.
> > > Regards,
> > > Michael
> > > Am 26.09.22 um 12:13 schrieb Chris van der Meijden:
> > > Correction:
> > > $br(ovms, sel_vehicle_label)$
> > > Am Montag, dem 26.09.2022 um 12:05 +0200 schrieb Chris van der
> > > Meijden:
> > > > I like the new KWGT Widget feature:
> > > > Above is the Tesla Widget of our Model 3, beneath that my OVMS
> > > > KWGT widget of our VW e-UP.
> > > > I had to allow "Passing data to other apps". The syntax for
> > > > getting the intent variables to text in KWGT is i.e.
> > > > $br(ovms, car_sel_vehicle_label)$
> > > > Other variables can be found here:
> > > > https://github.com/openvehicles/Open-Vehicle-Android/wiki/Update-Broadcast-Intent-data
> > > > The image is local on the filesystem of the phone and does not
> > > > come by intent.
> > > > Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael
> > > > Balzer:
> > > > No, icon can only be 0 from the else branch, in that case it
> > > > shall fall back to the default image.
> > > > But I've meanwhile found (I think) your maps/track crash,
> > > > commit is already in the hub. The checkbox handler didn't check
> > > > if the map object is initialized.
> > > > https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/FragMap.java#L319
> > > > Regards,
> > > > Michael
> > > > Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
> > > > Just guessing, but does
> > > > int icon;
> > > > in MyGcmListenerService.java at line 132
> > > > not need to be initialized like
> > > > int icon = 0;
> > > > now you use
> > > > .setSmallIcon((icon != 0) ? icon : R.drawable.map_car_default)
> > > > at line 150 now?
> > > > As the images and the Google stuff are related to that integer
> > > > it made me thinking ...
> > > > Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael
> > > > Balzer:
> > > > > Chris,
> > > > > that's not a crash log, that's just a warning.
> > > > > On that warning: the App requests
> > > > > android.permission.ACCESS_FINE_LOCATION by it's manifest.
> > > > > Maybe with LineageOS you need to manually give it that
> > > > > permission?
> > > > > A crash log has class "E" (error) and includes an exception
> > > > > and a backtrace, for an example see:
> > > > > https://issuetracker.google.com/issues/201308676#comment4
> > > > > On the crash: maybe it's because you don't have the Google
> > > > > components, not sure if FragMap can handle that.
> > > > > The forum post relates to /e/OS … maybe I need some emulator
> > > > > images running alternative Androids now…
> > > > > Regards,
> > > > > Michael
> > > > > Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
> > > > > Hey Michael,
> > > > > this is from logcat when I change "Track vehicle" and the app
> > > > > crashes:
> > > > > 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission
> > > > > Denial: receiving Intent {
> > > > > act=android.intent.action.SERVICE_STATE flg=0x1000010 (has
> > > > > extras) } to ProcessRecord{8dcdd54
> > > > > 2053:com.android.systemui/u0a148} (pid=2053, uid=10148)
> > > > > requires android.permission.ACCESS_FINE_LOCATION due to
> > > > > sender android (uid 1001)
> > > > > I saw now, that this crash also happens in the production
> > > > > app.
> > > > > The widget is running well. I will keep the app running for
> > > > > while and will see if it stays stable.
> > > > > Regards
> > > > > Chris
> > > > > Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael
> > > > > Balzer:
> > > > > > Chris,
> > > > > > thanks for testing. A crash log would help on any crashes
> > > > > > you see. Btw, I don't bump the revision until the actual
> > > > > > release build.
> > > > > > Crashes related to the car image don't occur immediately,
> > > > > > it sometimes takes hours of use before it happens. When it
> > > > > > does, clearing the App cache fixes the crash for another
> > > > > > random period.
> > > > > > Speed optimization was one goal. What about the widget?
> > > > > > Thanks,
> > > > > > Michael
> > > > > > Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
> > > > > > Hey Michael,
> > > > > > I just installed the "release" Version on LineageOS 19.1
> > > > > > (Android 12) without Google components.
> > > > > > The vehicle setup was without any troubles. I could select
> > > > > > the yellow VW e-UP image without crashing.
> > > > > > The App version is set wrong under "Vehicle info" (3.19.1,
> > > > > > 2021122401).
> > > > > > Everything seems to be faster than before.
> > > > > > When I change the checkbox on "Track vehicle" under
> > > > > > "Position" the App crashes. But after a new start of the
> > > > > > app the value of the checkbox has changed.
> > > > > > Perhaps this first impression is of some help.
> > > > > > Regards
> > > > > > Chris
> > > > > > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael
> > > > > > Balzer:
> > > > > > > Everyone,
> > > > > > > I'm currently working on the next Android release
> > > > > > > including KustomWidget support and a native app widget
> > > > > > > based on the old Automagic gauge widget.
> > > > > > > Automagic has been dead for some time now, and it keeps
> > > > > > > crashing on Androids >= 7.
> > > > > > > My changes so far are in the hub, APK builds are
> > > > > > > available here:
> > > > > > > * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
> > > > > > > * debug build for extended logging: https://dexters-web.de/f/tw-
> > > > > > > beta/OpenVehicleApp-22092401-debug.apk
> > > > > > > There's an issue with the App related to Android >= 10
> > > > > > > though, which I haven't found yet. It's been reported in
> > > > > > > the forum:
> > > > > > > * https://www.openvehicles.com/node/3410
> > > > > > > I could use some help with that, I've got no idea other
> > > > > > > than blaming Android.
> > > > > > > I've seen the effect in my emulator tests, and it seems
> > > > > > > to occur more frequently with non-roadster images.
> > > > > > > Regards,
> > > > > > > Michael
> > > > > > > _______________________________________________
> > > > > > > OvmsDev mailing list
> > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221008/6f70a871/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221008/6f70a871/attachment-0001.png>
