[Ovmsdev] Android App beta
Tue Oct 4 14:21:43 HKT 2022
Pressure can be set to bar from the car page menu (1 bar = 100 kPa).
Am 04.10.22 um 06:35 schrieb Michael Geddes:
> Ok, I have had a look at that, and hopefully can get an Ioniq 5 image
> going.
> Is it possible to change the tyre pressure display to kPa?
> On Tue, 27 Sept 2022, 11:38 am Michael Geddes,
> <frog at bunyip.wheelycreek.net> wrote:
> Hi,
> have installed the new app. One thing I have noticed, is that the
> rear door open is not showing at all. I thought it was that the
> signals weren't being read correctly (I'm making good progress on
> the Ioniq 5 module), but it turns out those values are correct -
> but just not showing on the app.
> Also related - the front door opening icon doesn't quite line up
> with the main image (it's showing a bit down from the door on the
> Hyundai Ioniq image).
> What's the process for getting a new Image for the Ioniq 5? I saw
> somebody suggested the module being able to provide it, which
> would be good.
> //.ichael
> On Sun, 25 Sept 2022 at 02:10, Michael Balzer <dexter at expeedo.de>
> wrote:
> Everyone,
> I'm currently working on the next Android release including
> KustomWidget support and a native app widget based on the old
> Automagic gauge widget.
> Automagic has been dead for some time now, and it keeps
> crashing on Androids >= 7.
> My changes so far are in the hub, APK builds are available here:
> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
> * debug build for extended logging:
> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
> There's an issue with the App related to Android >= 10 though,
> which I haven't found yet. It's been reported in the forum:
> * https://www.openvehicles.com/node/3410
> I could use some help with that, I've got no idea other than
> blaming Android.
> I've seen the effect in my emulator tests, and it seems to
> occur more frequently with non-roadster images.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221004/e10990b6/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221004/e10990b6/attachment.sig>
