[Ovmsdev] Android App beta
Michael Geddes
Tue Oct 4 12:35:30 HKT 2022
Ok, I have had a look at that, and hopefully can get an Ioniq 5 image going.
Is it possible to change the tyre pressure display to kPa?
On Tue, 27 Sept 2022, 11:38 am Michael Geddes, <frog at bunyip.wheelycreek.net>
wrote:
> Hi,
> have installed the new app. One thing I have noticed, is that the rear
> door open is not showing at all. I thought it was that the signals weren't
> being read correctly (I'm making good progress on the Ioniq 5 module), but
> it turns out those values are correct - but just not showing on the app.
> Also related - the front door opening icon doesn't quite line up with the
> main image (it's showing a bit down from the door on the Hyundai Ioniq
> image).
> What's the process for getting a new Image for the Ioniq 5? I saw
> somebody suggested the module being able to provide it, which would be good.
> //.ichael
> On Sun, 25 Sept 2022 at 02:10, Michael Balzer <dexter at expeedo.de> wrote:
>> Everyone,
>> I'm currently working on the next Android release including KustomWidget
>> support and a native app widget based on the old Automagic gauge widget.
>> Automagic has been dead for some time now, and it keeps crashing on
>> Androids >= 7.
>> My changes so far are in the hub, APK builds are available here:
>> - https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>> - debug build for extended logging:
>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>> There's an issue with the App related to Android >= 10 though, which I
>> haven't found yet. It's been reported in the forum:
>> - https://www.openvehicles.com/node/3410
>> I could use some help with that, I've got no idea other than blaming
>> Android.
>> I've seen the effect in my emulator tests, and it seems to occur more
>> frequently with non-roadster images.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221004/7124f5d4/attachment-0001.htm>
