[Ovmsdev] Use of deallocated memory in a bunch of places!?
Michael Geddes
Mon Oct 3 15:32:21 HKT 2022
I can live with those astyle settings, so I'll include them.
I've been using vim: tabstop=2 shiftwidth=2 expandtabs (which is the
same as --indent=spaces=2 afaict) - so that's a relief. Mixed tabs and
spaces are a pitb..
While I am used to delphi and so have been using the style that puts the
brace at the indent level l'm happy to go with the one you have chosen.
I really dislike that style with the brace indented. While I still like
much about C++, especially the template engine, I do miss delphi enums,
sets and a few other features!
I'll download astyle and make it nice before I push up. I've been making
lots of little commits as I'm going, but will probably just squash it into
one initial.
I'm wondering what I should do about my instrumented function calls!
For example - All my functions look like this at the moment (with XARM()
and XDISARM)
bool OvmsBatteryMon::checkStateChange()
XARM("OvmsBatteryMon::checkStateChange");
if (!m_dirty)
XDISARM;
return false;
OvmsBatteryState newState = calc_state();
bool res = newState != m_lastState;
m_lastState = newState;
m_dirty = false;
XDISARM;
return res;
These are Macros so they would process to blank for the release. The idea
is that if the object created by XARM() is not disarmed, it will cause a
log to happen. (ie if there's an unexpected exception). Should I just
leave them in?
//.ichael
On Mon, 3 Oct 2022 at 14:26, Michael Balzer <dexter at expeedo.de> wrote:
> Thanks, Michael.
> > The main problem was the diversity of tab style.
> Yes… I see you even tried to fix indentation style where it seems to have
> been mixed unintentionally by the module developers ^_^
> Btw, I've begun including EditorConfigs and Artistic Style configs for
> newer modules, e.g.:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/zip/.editorconfig
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_vweup/src/.astylerc
> Am 03.10.22 um 04:07 schrieb Michael Geddes:
> Pull request created.
> I hope it's ok.
> //.ichael
> On Mon, 3 Oct 2022 at 09:23, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> Not 8 issues. 8 Files that I found issues in, each with a bunch of them
>> - so around 50 all up.
>> I did a vimgrep for lines starting with something like 'const char* ident
>> =' ish...
>> Yeah, I agree, checking for IsDefined() is a lot less cludgy, so have
>> done that (yay for vim macros). Also the existing code didn't cope with -ve
>> values!
>> I guess I better fork the project now and submit a pull request!! :)
>> //.ichael
>> On Sun, 2 Oct 2022 at 22:01, Michael Balzer <dexter at expeedo.de> wrote:
>>> Michael,
>>> oh, the dreadful c_str() trap once again… nice find.
>>> The deallocated heap buffer *can* have been reallocated easily, we're
>>> running on a preemptive OS and on two CPU cores.
>>> IOW, all of these need to be fixed. Sure there are only 8 of them?
>>> On your is_empty_metric() utility: may be I miss something, but why
>>> don't we simply use the metric's IsDefined() method?
>>> Am 02.10.22 um 13:37 schrieb Michael Geddes:
>>> Hi all,
>>> I noticed some behavior on the *tpms* command I'd copied from the
>>> Kia/Kona code, which sent me down a small rabbit hole.
>>> What I was seeing was that the temperature was repeated instead of
>>> seeing the pressure and temperature.
>>> Even in vehicle.cpp, we can see code like this:
>>> const char* range_est =
>>> StdMetrics.ms_v_bat_range_est->AsUnitString("-", rangeUnit, 0).c_str();
>>> if (*range_est != '-')
>>> writer->printf("Est. range: %s\n", range_est);
>>> My C++ is a bit rusty, however I believe that the 'const char*' won't
>>> hold the temporary std::string object returned by 'AsUnitString'. To do
>>> that, I believe we need to assign to a reference (which I know will work).
>>> The problem is that the original code will mostly work (especially in cases
>>> like the above), as the deallocated heap memory won't have been reallocated.
>>> const std::string& range_est =
>>> StdMetrics.ms_v_bat_range_est->AsUnitString("-", rangeUnit, 0);
>>> if (!is_empty_metric(range_est))
>>> writer->printf("Est. range: %s\n", range_est.c_str());
>>> Where I've defined in vehicle.h the following:
>>> inline bool is_empty_metric(const std::string &measure)
>>> return (measure == "") || (measure[0] == '-');
>>> Will the above work functionally? Would it be better to be:
>>> return (measure =="") || (measure == "-")
>>> This occurs in 8 files (outside my new Ioniq 5 files) that I have noted.
>>> I would make a separate commit for this and do a pull request for it,
>>> //.ichael
>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221003/263e9b2b/attachment.htm>
