[Ovmsdev] Use of deallocated memory in a bunch of places!?
Mon Oct 3 14:25:43 HKT 2022
Thanks, Michael.
> The main problem was the diversity of tab style.
Yes… I see you even tried to fix indentation style where it seems to
have been mixed unintentionally by the module developers ^_^
Btw, I've begun including EditorConfigs and Artistic Style configs for
newer modules, e.g.:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/zip/.editorconfig
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_vweup/src/.astylerc
Am 03.10.22 um 04:07 schrieb Michael Geddes:
> Pull request created.
> I hope it's ok.
> //.ichael
> On Mon, 3 Oct 2022 at 09:23, Michael Geddes
> <frog at bunyip.wheelycreek.net> wrote:
> Not 8 issues. 8 Files that I found issues in, each with a bunch
> of them - so around 50 all up.
> I did a vimgrep for lines starting with something like 'const
> char* ident =' ish...
> Yeah, I agree, checking for IsDefined() is a lot less cludgy, so
> have done that (yay for vim macros). Also the existing code didn't
> cope with -ve values!
> I guess I better fork the project now and submit a pull request!! :)
> //.ichael
> On Sun, 2 Oct 2022 at 22:01, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> oh, the dreadful c_str() trap once again… nice find.
> The deallocated heap buffer *can* have been reallocated
> easily, we're running on a preemptive OS and on two CPU cores.
> IOW, all of these need to be fixed. Sure there are only 8 of them?
> On your is_empty_metric() utility: may be I miss something,
> but why don't we simply use the metric's IsDefined() method?
> Am 02.10.22 um 13:37 schrieb Michael Geddes:
>> Hi all,
>> I noticed some behavior on the *tpms* command I'd copied from
>> the Kia/Kona code, which sent me down a small rabbit hole.
>> What I was seeing was that the temperature was repeated
>> instead of seeing the pressure and temperature.
>> Even in vehicle.cpp, we can see code like this:
>> const char* range_est =
>> StdMetrics.ms_v_bat_range_est->AsUnitString("-", rangeUnit,
>> 0).c_str();
>> if (*range_est != '-')
>> writer->printf("Est. range: %s\n", range_est);
>> My C++ is a bit rusty, however I believe that the 'const
>> char*' won't hold the temporary std::string object returned
>> by 'AsUnitString'. To do that, I believe we need to assign
>> to a reference (which I know will work). The problem is that
>> the original code will mostly work (especially in cases like
>> the above), as the deallocated heap memory won't have been
>> reallocated.
>> const std::string& range_est =
>> StdMetrics.ms_v_bat_range_est->AsUnitString("-", rangeUnit, 0);
>> if (!is_empty_metric(range_est))
>> writer->printf("Est. range: %s\n", range_est.c_str());
>> Where I've defined in vehicle.h the following:
>> inline bool is_empty_metric(const std::string &measure)
>> return (measure == "") || (measure[0] == '-');
>> Will the above work functionally? Would it be better to be:
>> return (measure =="") || (measure == "-")
>> This occurs in 8 files (outside my new Ioniq 5 files) that I
>> have noted.
>> I would make a separate commit for this and do a pull request
>> for it,
>> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221003/bdf856e9/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221003/bdf856e9/attachment-0001.sig>
