[Ovmsdev] Use of deallocated memory in a bunch of places!?
Mon Oct 3 09:23:39 HKT 2022
Not 8 issues.  8 Files that I found issues in, each with a bunch of them -
so around 50 all up.
I did a vimgrep for lines starting with something like 'const char* ident
=' ish...
Yeah, I agree, checking for IsDefined() is a lot less cludgy, so have done
that (yay for vim macros). Also the existing code didn't cope with -ve
values!
I guess I better fork the project now and submit a pull request!! :)
//.ichael
On Sun, 2 Oct 2022 at 22:01, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> oh, the dreadful c_str() trap once again… nice find.
> The deallocated heap buffer *can* have been reallocated easily, we're
> running on a preemptive OS and on two CPU cores.
> IOW, all of these need to be fixed. Sure there are only 8 of them?
> On your is_empty_metric() utility: may be I miss something, but why don't
> we simply use the metric's IsDefined() method?
> Am 02.10.22 um 13:37 schrieb Michael Geddes:
> Hi all,
> I noticed some behavior on the *tpms* command I'd copied from the
> Kia/Kona code, which sent me down a small rabbit hole.
> What I was seeing was that the temperature was repeated instead of seeing
> the pressure and temperature.
> Even in vehicle.cpp, we can see code like this:
>   const char* range_est =
> StdMetrics.ms_v_bat_range_est->AsUnitString("-", rangeUnit, 0).c_str();
>   if (*range_est != '-')
>     writer->printf("Est. range: %s\n", range_est);
> My C++ is a bit rusty, however I believe that the 'const char*' won't hold
> the temporary std::string object returned by 'AsUnitString'.  To do that, I
> believe we need to assign to a reference (which I know will work).  The
> problem is that the original code will mostly work (especially in cases
> like the above), as the deallocated heap memory won't have been reallocated.
>   const std::string& range_est =
> StdMetrics.ms_v_bat_range_est->AsUnitString("-", rangeUnit, 0);
>   if (!is_empty_metric(range_est))
>     writer->printf("Est. range: %s\n", range_est.c_str());
> Where I've defined in vehicle.h the following:
> inline bool is_empty_metric(const std::string &measure)
>   return (measure == "") || (measure[0] == '-');
> Will the above work functionally?  Would it be better to be:
> return (measure =="") || (measure == "-")
> This occurs in 8 files (outside my new Ioniq 5 files) that I have noted.
> I would make a separate commit for this and do a pull request for it,
> //.ichael
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221003/0bcab79f/attachment.htm>
