[Ovmsdev] Use of deallocated memory in a bunch of places!?
Sun Oct 2 22:01:00 HKT 2022
Michael,
oh, the dreadful c_str() trap once again… nice find.
The deallocated heap buffer *can* have been reallocated easily, we're
running on a preemptive OS and on two CPU cores.
IOW, all of these need to be fixed. Sure there are only 8 of them?
On your is_empty_metric() utility: may be I miss something, but why
don't we simply use the metric's IsDefined() method?
Am 02.10.22 um 13:37 schrieb Michael Geddes:
> Hi all,
> I noticed some behavior on the *tpms* command I'd copied from the
> Kia/Kona code, which sent me down a small rabbit hole.
> What I was seeing was that the temperature was repeated instead of
> seeing the pressure and temperature.
> Even in vehicle.cpp, we can see code like this:
> const char* range_est =
> StdMetrics.ms_v_bat_range_est->AsUnitString("-", rangeUnit, 0).c_str();
> if (*range_est != '-')
> writer->printf("Est. range: %s\n", range_est);
> My C++ is a bit rusty, however I believe that the 'const char*' won't
> hold the temporary std::string object returned by 'AsUnitString'. To
> do that, I believe we need to assign to a reference (which I know will
> work). The problem is that the original code will mostly work
> (especially in cases like the above), as the deallocated heap memory
> won't have been reallocated.
> const std::string& range_est =
> StdMetrics.ms_v_bat_range_est->AsUnitString("-", rangeUnit, 0);
> if (!is_empty_metric(range_est))
> writer->printf("Est. range: %s\n", range_est.c_str());
> Where I've defined in vehicle.h the following:
> inline bool is_empty_metric(const std::string &measure)
> return (measure == "") || (measure[0] == '-');
> Will the above work functionally? Would it be better to be:
> return (measure =="") || (measure == "-")
> This occurs in 8 files (outside my new Ioniq 5 files) that I have noted.
> I would make a separate commit for this and do a pull request for it,
> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221002/d26dc4af/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221002/d26dc4af/attachment.sig>
