[Ovmsdev] New Metric Units
    Michael Geddes
    Fri Nov 25 10:13:14 HKT 2022
I have an idea which might reduce traffic for maintaining the metrics[]
array in the browser and cope with the user units.
I'll start by saying I'm not a JS developer per se.. so a newb in JS
really. Still, it's mainly just another language so .. we'll give it a go.
Firstly:
* Implement the 'changed' filters as below for the web-socket.. for both
normal and 'user' values.
* Add a function that subscribes to a value (and returns the current value
of it)..including to 'user' value/unitlabel.
Subscribing the normal way to the metrics over the websocket would have the
normal effect.. but we would have a new way that would subscribe in a
filtered way.
I've had a little play with the Proxy object .. so at least I know this
should work:
Have a metrics_ array that is the real associative array for metrics[] and
then define a Proxy that has (at the least)  'get' and 'has' defined
(giving us the ability to overload *metrics['prop']*  and *"prop" in
metrics operations*).
The *get *function would return the underlying value if it exists in the
*metrics_ *array (which  is maintained through the websocket from currently
subscribed values in the current manner).
If the value is not in the *metrics_* array - it would then do a
subscribe+query on the websocket getting the current value and adding it
into the  *metrics_*  container. If it was unavailable then it would put
*undefined* into the array.
The 'has' would do the get() and return true if the value was not ==
*undefined*.
For the 'query the websocket' bit, I'm assuming I would be working with
promises or futures or some such: I'll do the research and do it properly
unless somebody can help me out with it. That's the bit I was going to work
on next for the proof-of-concept.
Any immediate thoughts? Dangers?
I also noticed there was a bit that went through html element properties
and looked for metrics .. this could be used to bulk subscribe to any
metric values required there.
//.ichael
On Thu, 17 Nov 2022 at 07:52, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> Yeah, ok.
> I will get all the other 'user unit' stuff done as a line in the sand, and
> then move to working out the web stuff.  I'm still finding my way though
> all the client side javascript, which looks very cool.. but I've not really
> done jQuery before (just enough to recognise it).
> Subscribing to metrics with/without user units makes a lot of sense.
> Obviously the default needs to be 'Subscribe to all metrics but not
> user units' to maintain compatibility... but I was also thinking it might
> be nice if we could filter down even the normal subscribed events.
> We could have:
> * Web socket command to  filter units (flag on websocket to say 'filtered'
> + flag bitset on each  metric  similar to 'dirty')
> Then either:
> * Web socket command to turn on user units (single flag on that websocket)
> or
> * Web socket command to turn on user units for specific metrics (flag
> bitset on each metric)
> A parameter to the URI for the websocket could start the socket in
> 'filtered' mode to avoid the initial rush of metrics.
> This could drastically reduce traffic and time for the metrics command to
> execute.  It would be possible to also check (on a 'filtered' websocket)
> for any changes to metrics for that websocket slot before queueing the
> 'metric update' socket command.
> //.ichael
> On Thu, 17 Nov 2022 at 00:35, Michael Balzer <dexter at expeedo.de> wrote:
>> Michael,
>> I don't have much spare time currently, just some quick first comments:
>> it's important to implement this as lightweight as possible, both in terms
>> of network load and client CPU & memory requirements. Some devices already
>> have issues, which can be seen by the "websocket overflow" messages. The
>> web UI also should stay usable via cellular.
>> My impression is the new scheme, while only slightly raising the client
>> requirements, adds substantially to the network requirements.
>> An option could be to separate the units -- or more, back when
>> implementing this I thought about separating the names later on. Another
>> question is if we normally generally need both the native and the converted
>> values in the web UI. We maybe could provide an option to switch to
>> converted values, or add an option to retreive or subscribe to a set of
>> converted metrics on demand.
>> Standard plugins like ABRP and PwrMon rely on getting metric (native)
>> units, and there probably are non-public plugins, e.g. for engineering &
>> scientific projects, that depend on metric units to do their calculations
>> and don't need anything else. We shouldn't make life harder for these
>> applications without good reason.
>> Am 15.11.22 um 01:26 schrieb Michael Geddes:
>> If you're ok with the [default] option I'll stick with that. I mean in
>> some ways it would be nice to have a button choice
>> metric | usa | europe | asia | custom   etc and I kind of considered
>> something like that but figured it's only a handful of choices.. and it's
>> an embedded device.. so simpler is better.
>> On a related note - I was thinking how it would be nice if the dashboard
>> (etc) had access to the 'user' units, so went hunting down that little
>> rabbit hole. Quite a nice mechanism with the web socket updating the
>> "metrics" object in the UI.
>> This is a snippet of one idea, which is that for any metric that has the
>> possibility of a user unit, we set the extra values of the metric with
>> '#unit' and '#user' appended - see below. (I've chosen '#' arbitrarily..
>> but it could be '/' or ':' or '>'  but maybe not '.' )
>> v.p.odometer#unit: "M"
>> v.p.odometer#user: 6754.91
>> v.p.satcount: 13
>> v.p.speed: 0
>> v.p.speed#unit: "km/h"
>> v.p.speed#user: null
>> *v.p.trip: 28*
>> *v.p.trip#unit: "M" v.p.trip#user: 17.3984*
>> Then we can use this in the dials to populate the values and captions!
>> (not that I like Miles).
>> I
>> [image: image.png]
>> The other (similar) way was to have something like the following:
>> "v.p.trip#user" : { "value": 17.3984, "unit": "M" }
>> It wouldn't make the total message any shorter.. soo.. dunno.
>> There's also some complications with setting up the dials (for min/max
>> values) - like for the speed.
>> Notice also that I'm returning null for undefined values. It's nice - but
>> I'm not sure how javascript handles null when used / printed etc.
>> //.ichael
>> On Sun, 13 Nov 2022 at 21:06, Michael Balzer <dexter at expeedo.de> wrote:
>>> Michael,
>>> looks good.
>>> I think having an explicit 'default' option is better than taking the
>>> 'Metric' equivalent for that, as in your example you already show unit
>>> alternatives within the metric system to support different scalings (kW /
>>> W, kWh / Wh). (Btw… waiting for someone to miss Horsepower & BTU here ;-))
>>> @Patrick, I think that also answers your implicit question:
>>> The default button makes it unclear what the actual setting is.
>>> The default (native unit) is always metric, but you may have a mix of
>>> scalings, as we try to find the one that fits best for the given
>>> application when defining a metric. For example the current driving energy
>>> consumption is stored natively in Wh/km, while the energy used or
>>> regenerated is in kWh, and the odometer & trip counters are in km, while
>>> the altitude ist in m.
>>> Am 13.11.22 um 08:42 schrieb Michael Geddes:
>>> Greetings,
>>> so this is my idea of being able to select which units various groups
>>> use (in addition to Distance).
>>> This can be then accessed by the special 'user' unit code.  (or
>>> 'metrics list -u ' )
>>> The idea of [Default] selection below  simply means storing the value to
>>> blank - meaning use whatever unit the particular metric uses.  The other
>>> idea I had was to actually default it to the equivalent of 'Metric' special
>>> unit code and not have the [Default] button.
>>> [image: image.png]
>>> Currently I've made it so that if there are more than 3 choices other
>>> than [default] that it uses the choice/combo box rather than the Radio
>>> buttons. (ie this list is auto-generated from the Metric Units table and
>>> the Metric Groups table).
>>> Thoughts / comments?
>>> //.ichael
>>> On Sat, 12 Nov 2022 at 17:35, Michael Geddes <
>>> frog at bunyip.wheelycreek.net> wrote:
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/771
>>>> I'm hoping this P/R is ok in this form (made of 5 separate commits).
>>>> I will have a look at implementing the "user" unit code.  The base for
>>>> how it would work is already a part of the above pull request.  I'll just
>>>> look at the module configuration for distance.
>>>> The 'power consumption' is one where it's not just a check-box..
>>>> there're 5 possible choice!
>>>> I should also add 'bar' for pressure given that for some reason that's
>>>> still a thing people want.
>>>> //.ichael
>>>> On Sat, 12 Nov 2022 at 16:24, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> I think this is pretty decent & complete now.
>>>>> I also like the approach of the 'user' unit code. Moving all user unit
>>>>> prefs into the module configuration is an old todo. Currently only the
>>>>> distance unit is defined at the module side, temperature and pressure are
>>>>> App prefs.
>>>>> Regards,
>>>>> Michael
>>>>> Am 11.11.22 um 09:54 schrieb Michael Geddes:
>>>>> Ok - so here's what I have implemented for Duktape and Metrics. (I
>>>>> added IsDefined() as well).
>>>>> Any thoughts on this?
>>>>> Noting
>>>>>    OvmsMetrics.Float( {metric} ) -> Outputs metric as float (same)
>>>>>    OvmsMetrics.Float( {metric}, {unit}) -> Outputs metric as float
>>>>> converted to given unit  (new)
>>>>>    OvmsMetrics.Value( {metric} )   -> Outputs Metric in native value
>>>>> (same)
>>>>>    OvmsMetrics.Value( {metric} , false)   -> Outputs Metric as string
>>>>> and no units (same)
>>>>>    OvmsMetrics.Value( {metric} ,  {unit})  -> Outputs Metric converted
>>>>> to given unit as native value. (new)
>>>>>   OvmsMetrics.Value( {metric} ,  {unit}, false )  -> Outputs Metric
>>>>> converted to given unit as string including any unit specifier. (new)
>>>>> also  OvmsMetric.GetValues( {metric} [,{unit}] [, {converted} ] )
>>>>> Adds similar behaviour to Value() above.
>>>>> also the special units '*imperial*' and '*metric*' will convert to
>>>>> the associated imperial / metric version of the units as appropriate.
>>>>> (function() {
>>>>>    dump = function (metric) { print( metric+ " ["+(typeof
>>>>> metric)+"]\n"  ); }
>>>>>    dump_obj = function (obj )  {
>>>>>      print('--- Object ----\n')
>>>>>      for (var k in obj) {
>>>>>        xk = obj[k];
>>>>>        print( k+':'+ xk + ' ['+typeof xk+ "]\n");
>>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption"));
>>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", false));
>>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh"));
>>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false));
>>>>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption"));
>>>>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh"));
>>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial"))
>>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial", false))
>>>>>    dump_obj(OvmsMetrics.GetValues("trip", "metric"))
>>>>>    dump_obj(OvmsMetrics.GetValues("trip", "imperial", false))
>>>>> With this output:
>>>>> 19.2308 [number]
>>>>> 19.2308 [string]
>>>>> 5.2 [number]
>>>>> 3.23112mi/kWh [string]
>>>>> 19.2308 [number]
>>>>> 5.2 [number]
>>>>> 309.49 [number]
>>>>> 309.49Wh/mi [string]
>>>>> --- Object ----
>>>>> v.p.trip:13 [number]
>>>>> xiq.e.trip:0 [number]
>>>>> xiq.e.trip.energy.recuperated:0 [number]
>>>>> xiq.e.trip.energy.used:0 [number]
>>>>> xiq.v.trip.consumption:19.2308 [number]
>>>>> --- Object ----
>>>>> v.p.trip:8.07781M [string]
>>>>> xiq.e.trip:0M [string]
>>>>> xiq.e.trip.energy.recuperated:0kWh [string]
>>>>> xiq.e.trip.energy.used:0kWh [string]
>>>>> xiq.v.trip.consumption:309.49Wh/mi [string]
>>>>> On Wed, 9 Nov 2022 at 05:47, Michael Geddes <
>>>>>> Yeah - I like HasValue.  I implemented IsDefined() but I will rename
>>>>>> it.. that's a much clearer name.
>>>>>> Another thought. How about if we did this (but also with GetValues()
>>>>>> as well - see the special values below)
>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption",  true)  -> 17.0582
>>>>>> (Number)
>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption",  false)  -> 17.0582
>>>>>> (String)
>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", true)  ->
>>>>>> 3.64264  (Number)
>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)  ->
>>>>>> 3.64264Mi/kWh  (String)
>>>>>>  OvmsMetrics.Value("xiq.v.trip.consumption", "native", false)  ->
>>>>>> 17.0582km/kWh  (String)
>>>>>> and
>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "imperial", false)  ->
>>>>>> I have already implemented the special values 'native' (existing),
>>>>>> 'imperial' and 'metric'.
>>>>>> I was also thinking that in the future you could have 'user'. Where
>>>>>> for each group of values:
>>>>>> 'temperature', 'distance', 'shortdistance', 'power' etc.. you could
>>>>>> have a user preference. I probably won't implement it now,.but it could be
>>>>>> cool that any UI could just ask for the user defined units (rather than
>>>>>> having a separate choice).
>>>>>> //.ichael
>>>>>> On Tue, 8 Nov 2022 at 21:57, Mark Webb-Johnson <mark at webb-johnson.net>
>>>>>> wrote:
>>>>>>> Or perhaps something more specific?
>>>>>>>     HasValue()
>>>>>>> Mark
>>>>>>> On 8 Nov 2022, at 9:01 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>>> Signed PGP part
>>>>>>> That's basically a good approach, but be aware 'IsDefined()' has an
>>>>>>> ambiguous meaning here, as with the API stem "OvmsMetrics" it would
>>>>>>> naturally be expected to mean "is this metric defined", not "does this
>>>>>>> metric have a defined value".
>>>>>>> An undefined metric currently can be derived from 'Values()'
>>>>>>> returning undefined, but that's more an undocumented side effect than
>>>>>>> intended.
>>>>>>> Maybe 'GetDefined()' could be a better name, leveraging this
>>>>>>> behaviour, i.e. returning 'undefined' for an actually undefined metric, and
>>>>>>> 'null' for a defined metric without a value.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 08.11.22 um 13:46 schrieb Michael Geddes:
>>>>>>> Ah yes. Arrays - will check those.  Yeah, how about we add a
>>>>>>> 'IsDefined' method to metrics instead of the null thing (it does sound like
>>>>>>> it will upset too many applecarts).
>>>>>>> On Tue, 8 Nov 2022 at 20:35, Michael Balzer <dexter at expeedo.de>
>>>>>>> wrote:
>>>>>>>> Michael,
>>>>>>>> looks all good to me, once again nice find with the decode
>>>>>>>> argument. Adding decode to the Value() call was only for symmetry IIRC, the
>>>>>>>> main use was with GetValues() (
>>>>>>>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsmetrics
>>>>>>>> Don't forget to test arrays, e.g. "v.t.pressure" & "v.t.temp".
>>>>>>>> Returning null for an undefined metric seems like a natural choice,
>>>>>>>> but is a rather deep change, as for consistency not only the Duktape
>>>>>>>> metrics API but also the Web UI metrics API would need to be changed
>>>>>>>> accordingly. Unless you've got a real use case that needs that, we should
>>>>>>>> be careful.
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 07.11.22 um 15:00 schrieb Michael Geddes:
>>>>>>>> I have figured out a bunch of stuff and have implemented the
>>>>>>>> following: (having done away with needing AsFloatUnit)
>>>>>>>> OvmsMetrics.Value( {metric} [, {decode}])
>>>>>>>> OvmsMetrics.Value( {metric}, {unit} [,{decode}])
>>>>>>>> It turns out that the [decode] flag wasn't working anyway (since
>>>>>>>> the function was being registered as only having 1 param)...
>>>>>>>> This way it is still really 1 function.. but I check it the second
>>>>>>>> parameter is a 'boolean', and if not.. try the second form.
>>>>>>>> OvmsMetrics.AsFloat( {metric} [,{unit}] )
>>>>>>>> and add the function
>>>>>>>> Ovms.Metrics.ValueUnit( {metric} [,{unit}])
>>>>>>>> This prints the value and the unit.
>>>>>>>> Here's a sample function and the output! This also shows the types
>>>>>>>> of the output.
>>>>>>>> (function() {
>>>>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption");
>>>>>>>>    print( (typeof x) + ": "+  x+"\n"  );
>>>>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption", false);
>>>>>>>>    print( (typeof x) + ": "+  x +"\n" );
>>>>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh")
>>>>>>>>    print( (typeof x) + ": "+ x +"\n");
>>>>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh",
>>>>>>>> false)
>>>>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
>>>>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
>>>>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption")
>>>>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh")
>>>>>>>> number: 17.0582
>>>>>>>> string: 17.0582
>>>>>>>> number: 5.86227
>>>>>>>> string: 3.64264
>>>>>>>> string: 17.0582kWh/100km
>>>>>>>> string: 3.64264mi/kWh
>>>>>>>> number: 17.0582
>>>>>>>> number: 5.86227
>>>>>>>> It still might be an idea to use 'null' as a return value if the
>>>>>>>> metrics is !IsDefined() but that would be changing the existing
>>>>>>>> behaviour slightly.
>>>>>>>> //.ichael
>>>>>>>> On Mon, 7 Nov 2022 at 08:12, Michael Geddes <
>>>>>>>>> I've worked out what the decode flag is for and how it works, and
>>>>>>>>> I think how optional params work.
>>>>>>>>> I'm pretty sure I won't  need the 'AsFloatUnit' function; the unit
>>>>>>>>> would be an option to AsFloat(); I'll know that soon.
>>>>>>>>> The 'Value' function is more complicated because of the optional
>>>>>>>>> decode bool. I guess I could add the Unit to the end of that.
>>>>>>>>> ValueUnit could be still useful then to provide a 'Value + Unit'.
>>>>>>>>> Question:  Is there a reason we shouldn't be returning with
>>>>>>>>> duk_push_null    if the metric !IsDefined()  in both AsFloat()
>>>>>>>>> and Value(metric,true) cases?
>>>>>>>>> //.ichael
>>>>>>>>> On Sun, 6 Nov 2022 at 11:22, Michael Geddes <
>>>>>>>>>> Right, so I've implemented some stuff that seems to work quite
>>>>>>>>>> well.
>>>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>>>>>>>>>> should be ready now after a couple of stupid mistakes slipped through.
>>>>>>>>>>  This absolutely needs somebody to review it please! (There's a reason why
>>>>>>>>>> I've converted some if()'s to switch() - which is that it will be used in
>>>>>>>>>> the follow-up commit).
>>>>>>>>>> The commit that will follow on from that it implements the new
>>>>>>>>>> Units: kWh/100km, km/kWh  and  mi/kWh.
>>>>>>>>>> This is a summary of what I've implemented for scripting -
>>>>>>>>>> including showing the unit codes I have so far.  I've considered a few
>>>>>>>>>> things:
>>>>>>>>>>   * Should some of the longer unit codes be shortened  (eg mi,
>>>>>>>>>> mins, m, ft, deg, perc)
>>>>>>>>>>   * The unit codes could be much more regular and separated by
>>>>>>>>>> dots  eg:
>>>>>>>>>>         watthours -> w.h
>>>>>>>>>>         kwhp100km -> kw.h_100km or kw.h/100km
>>>>>>>>>>         miph ->  mi_h or mi/h  (or should it be mph).
>>>>>>>>>>         psi -> p_in.in or p/in.in or lb_in.in (yes, slightly
>>>>>>>>>> weird, but predictable)
>>>>>>>>>> *OVMS# metric units*
>>>>>>>>>>           km : km
>>>>>>>>>>        miles : M
>>>>>>>>>>       meters : m
>>>>>>>>>>         feet : ft
>>>>>>>>>>      celcius : °C
>>>>>>>>>>   fahrenheit : °F
>>>>>>>>>>          kpa : kPa
>>>>>>>>>>           pa : Pa
>>>>>>>>>>          psi : psi
>>>>>>>>>>        volts : V
>>>>>>>>>>         amps : A
>>>>>>>>>>     amphours : Ah
>>>>>>>>>>           kw : kW
>>>>>>>>>>          kwh : kWh
>>>>>>>>>>        watts : W
>>>>>>>>>>    watthours : Wh
>>>>>>>>>>      seconds : Sec
>>>>>>>>>>      minutes : Min
>>>>>>>>>>        hours : Hour
>>>>>>>>>>          utc : UTC
>>>>>>>>>>      degrees : °
>>>>>>>>>>         kmph : km/h
>>>>>>>>>>         miph : Mph
>>>>>>>>>>       kmphps : km/h/s
>>>>>>>>>>       miphps : Mph/s
>>>>>>>>>>         mpss : m/s²
>>>>>>>>>>          dbm : dBm
>>>>>>>>>>           sq : sq
>>>>>>>>>>      percent : %
>>>>>>>>>>        whpkm : Wh/km
>>>>>>>>>>        whpmi : Wh/mi
>>>>>>>>>>    kwhp100km : kWh/100km
>>>>>>>>>>       kmpkwh : km/kWh
>>>>>>>>>>       mipkwh : mi/kWh
>>>>>>>>>>           nm : Nm
>>>>>>>>>> *OVMS# metric unit mi*
>>>>>>>>>>        miles : M
>>>>>>>>>>      minutes : Min
>>>>>>>>>>         miph : Mph
>>>>>>>>>>       miphps : Mph/s
>>>>>>>>>>        whpmi : Wh/mi
>>>>>>>>>>       mipkwh : mi/kWh
>>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption *17.0597kWh/100km
>>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption kpkwh *5.86177km/kWh
>>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption mpkwh *3.64233mi/kWh
>>>>>>>>>> *OVMS# metric set xiq.c.speed 5 miph *Metric set
>>>>>>>>>> *OVMS# metric get xiq.c.speed *8.04673km/h
>>>>>>>>>> *OVMS# metric get xiq.c.speed miph *5Mph
>>>>>>>>>> And then in DukTape - there are some questions I have about the
>>>>>>>>>> implementation:
>>>>>>>>>> * Names of functions? Better ideas?
>>>>>>>>>> * Should ValueUnit output the units?
>>>>>>>>>> * In Value() there is the line    bool decode =
>>>>>>>>>> duk_opt_boolean(ctx, 1, true);
>>>>>>>>>>     * What does 'decode' mean here?
>>>>>>>>>>     * Do I need it for ValueUnit() ?
>>>>>>>>>> * (function() {    print(
>>>>>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption"));    print("\n")    print(
>>>>>>>>>> OvmsMetrics.ValueUnit("xiq.v.trip.consumption",""));    print("\n")
>>>>>>>>>>  print( OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh"));
>>>>>>>>>>  print("\n")    print(
>>>>>>>>>> OvmsMetrics.AsFloatUnit("xiq.v.trip.consumption","kmpkwh")); })();*
>>>>>>>>>> --- Output ---
>>>>>>>>>> 17.0597
>>>>>>>>>> 17.0597kWh/100km
>>>>>>>>>> 3.64233mi/kWh
>>>>>>>>>> 5.86177
>>>>>>>>>> The basic stuff all works - it's just quibbling over the
>>>>>>>>>> details.. but let's get them right!
>>>>>>>>>> //.ichael
>>>>>>>>>> On Sat, 5 Nov 2022 at 20:09, Michael Geddes <
>>>>>>>>>>> Yeah - this was copied code from kia/kona and is what triggered
>>>>>>>>>>> these ideas; I totally agree this shouldn't be doubled up on.
>>>>>>>>>>> I've got some commits centred round Metrics that I'll just check
>>>>>>>>>>> over and push up ... and then I'll just have the single xiq.v.
>>>>>>>>>>> trip.consumption metric (unless you have some ideas for the
>>>>>>>>>>> namespace) which will be much neater.
>>>>>>>>>>> If it's ok with you then I might do that unit conversion
>>>>>>>>>>> proposal.
>>>>>>>>>>> Would it ok if the unit specifications were the same as to the
>>>>>>>>>>> programatic codes in ovms_metrics.h?
>>>>>>>>>>> (kWh,   WattHours , MetersPSS )
>>>>>>>>>>> I would probably add a command
>>>>>>>>>>> metric units <spec>
>>>>>>>>>>> to list all (matching) units and their associated Labels.
>>>>>>>>>>> //.ichael
>>>>>>>>>>> On Sat, 5 Nov 2022 at 18:48, Michael Balzer <dexter at expeedo.de>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Michael,
>>>>>>>>>>>> adding unit conversion support to the shell and Duktape
>>>>>>>>>>>> commands is a good idea.
>>>>>>>>>>>> Metrics are not meant to provide a user interface, they should
>>>>>>>>>>>> be defined to be efficient and non-redundant.
>>>>>>>>>>>> Btw, metrics names also shall not use upper case characters,
>>>>>>>>>>>> and shall only use "." as a separator.
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Michael
>>>>>>>>>>>> Am 05.11.22 um 11:22 schrieb Michael Geddes:
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> Some of the code I copied from Kona/Kia code had both kwh/100km
>>>>>>>>>>>> and km/kwh metrics in the code as 'Other'.
>>>>>>>>>>>> Adding the various power consumption Units is not particularly
>>>>>>>>>>>> hard (I will have a pull-request soon) - though the conversions between
>>>>>>>>>>>> them all required some thought!
>>>>>>>>>>>> ... but it also made me think these two metrics that are (with
>>>>>>>>>>>> the consumption units added) defined like this:
>>>>>>>>>>>> m_v_trip_consumption1 =
>>>>>>>>>>>> MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km", 10, 0, kWHP100K);
>>>>>>>>>>>> m_v_trip_consumption2 = MyMetrics.InitFloat("
>>>>>>>>>>>> xiq.v.trip.consumption.km/kWh", 10, 0, kPkWH);
>>>>>>>>>>>> These are effectively the same metric but in different units!
>>>>>>>>>>>> I'm wondering if we would be better to have scripting and
>>>>>>>>>>>> Duktape support for converting metrics to different unit!  This might be
>>>>>>>>>>>> also quite useful for those strange countries that insist on using miles as
>>>>>>>>>>>> a measurement.
>>>>>>>>>>>> On top of the 'metric list' and 'metric set' we could add a
>>>>>>>>>>>> 'metric get' which gets a single value.. and add unit support for get/set.
>>>>>>>>>>>> I've also got a pull request that improves the precision of the
>>>>>>>>>>>> km<->mi conversions and factors it out.
>>>>>>>>>>>> //.ichael
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221125/3cbecf74/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221125/3cbecf74/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221125/3cbecf74/attachment-0003.png>
