[Ovmsdev] New Metric Units
    Michael Geddes
    Thu Nov 17 07:52:34 HKT 2022
Yeah, ok.
I will get all the other 'user unit' stuff done as a line in the sand, and
then move to working out the web stuff.  I'm still finding my way though
all the client side javascript, which looks very cool.. but I've not really
done jQuery before (just enough to recognise it).
Subscribing to metrics with/without user units makes a lot of sense.
Obviously the default needs to be 'Subscribe to all metrics but not
user units' to maintain compatibility... but I was also thinking it might
be nice if we could filter down even the normal subscribed events.
We could have:
* Web socket command to  filter units (flag on websocket to say 'filtered'
+ flag bitset on each  metric  similar to 'dirty')
Then either:
* Web socket command to turn on user units (single flag on that websocket)
or
* Web socket command to turn on user units for specific metrics (flag
bitset on each metric)
A parameter to the URI for the websocket could start the socket in
'filtered' mode to avoid the initial rush of metrics.
This could drastically reduce traffic and time for the metrics command to
execute.  It would be possible to also check (on a 'filtered' websocket)
for any changes to metrics for that websocket slot before queueing the
'metric update' socket command.
//.ichael
On Thu, 17 Nov 2022 at 00:35, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> I don't have much spare time currently, just some quick first comments:
> it's important to implement this as lightweight as possible, both in terms
> of network load and client CPU & memory requirements. Some devices already
> have issues, which can be seen by the "websocket overflow" messages. The
> web UI also should stay usable via cellular.
> My impression is the new scheme, while only slightly raising the client
> requirements, adds substantially to the network requirements.
> An option could be to separate the units -- or more, back when
> implementing this I thought about separating the names later on. Another
> question is if we normally generally need both the native and the converted
> values in the web UI. We maybe could provide an option to switch to
> converted values, or add an option to retreive or subscribe to a set of
> converted metrics on demand.
> Standard plugins like ABRP and PwrMon rely on getting metric (native)
> units, and there probably are non-public plugins, e.g. for engineering &
> scientific projects, that depend on metric units to do their calculations
> and don't need anything else. We shouldn't make life harder for these
> applications without good reason.
> Am 15.11.22 um 01:26 schrieb Michael Geddes:
> If you're ok with the [default] option I'll stick with that. I mean in
> some ways it would be nice to have a button choice
> metric | usa | europe | asia | custom   etc and I kind of considered
> something like that but figured it's only a handful of choices.. and it's
> an embedded device.. so simpler is better.
> On a related note - I was thinking how it would be nice if the dashboard
> (etc) had access to the 'user' units, so went hunting down that little
> rabbit hole. Quite a nice mechanism with the web socket updating the
> "metrics" object in the UI.
> This is a snippet of one idea, which is that for any metric that has the
> possibility of a user unit, we set the extra values of the metric with
> '#unit' and '#user' appended - see below. (I've chosen '#' arbitrarily..
> but it could be '/' or ':' or '>'  but maybe not '.' )
> v.p.odometer#unit: "M"
> v.p.odometer#user: 6754.91
> v.p.satcount: 13
> v.p.speed: 0
> v.p.speed#unit: "km/h"
> v.p.speed#user: null
> *v.p.trip: 28*
> *v.p.trip#unit: "M" v.p.trip#user: 17.3984*
> Then we can use this in the dials to populate the values and captions!
> (not that I like Miles).
> I
> [image: image.png]
> The other (similar) way was to have something like the following:
> "v.p.trip#user" : { "value": 17.3984, "unit": "M" }
> It wouldn't make the total message any shorter.. soo.. dunno.
> There's also some complications with setting up the dials (for min/max
> values) - like for the speed.
> Notice also that I'm returning null for undefined values. It's nice - but
> I'm not sure how javascript handles null when used / printed etc.
> //.ichael
> On Sun, 13 Nov 2022 at 21:06, Michael Balzer <dexter at expeedo.de> wrote:
>> Michael,
>> looks good.
>> I think having an explicit 'default' option is better than taking the
>> 'Metric' equivalent for that, as in your example you already show unit
>> alternatives within the metric system to support different scalings (kW /
>> W, kWh / Wh). (Btw… waiting for someone to miss Horsepower & BTU here ;-))
>> @Patrick, I think that also answers your implicit question:
>> The default button makes it unclear what the actual setting is.
>> The default (native unit) is always metric, but you may have a mix of
>> scalings, as we try to find the one that fits best for the given
>> application when defining a metric. For example the current driving energy
>> consumption is stored natively in Wh/km, while the energy used or
>> regenerated is in kWh, and the odometer & trip counters are in km, while
>> the altitude ist in m.
>> Am 13.11.22 um 08:42 schrieb Michael Geddes:
>> Greetings,
>> so this is my idea of being able to select which units various groups use
>> (in addition to Distance).
>> This can be then accessed by the special 'user' unit code.  (or  'metrics
>> list -u ' )
>> The idea of [Default] selection below  simply means storing the value to
>> blank - meaning use whatever unit the particular metric uses.  The other
>> idea I had was to actually default it to the equivalent of 'Metric' special
>> unit code and not have the [Default] button.
>> [image: image.png]
>> Currently I've made it so that if there are more than 3 choices other
>> than [default] that it uses the choice/combo box rather than the Radio
>> buttons. (ie this list is auto-generated from the Metric Units table and
>> the Metric Groups table).
>> Thoughts / comments?
>> //.ichael
>> On Sat, 12 Nov 2022 at 17:35, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/771
>>> I'm hoping this P/R is ok in this form (made of 5 separate commits).
>>> I will have a look at implementing the "user" unit code.  The base for
>>> how it would work is already a part of the above pull request.  I'll just
>>> look at the module configuration for distance.
>>> The 'power consumption' is one where it's not just a check-box..
>>> there're 5 possible choice!
>>> I should also add 'bar' for pressure given that for some reason that's
>>> still a thing people want.
>>> //.ichael
>>> On Sat, 12 Nov 2022 at 16:24, Michael Balzer <dexter at expeedo.de> wrote:
>>>> I think this is pretty decent & complete now.
>>>> I also like the approach of the 'user' unit code. Moving all user unit
>>>> prefs into the module configuration is an old todo. Currently only the
>>>> distance unit is defined at the module side, temperature and pressure are
>>>> App prefs.
>>>> Regards,
>>>> Michael
>>>> Am 11.11.22 um 09:54 schrieb Michael Geddes:
>>>> Ok - so here's what I have implemented for Duktape and Metrics. (I
>>>> added IsDefined() as well).
>>>> Any thoughts on this?
>>>> Noting
>>>>    OvmsMetrics.Float( {metric} ) -> Outputs metric as float (same)
>>>>    OvmsMetrics.Float( {metric}, {unit}) -> Outputs metric as float
>>>> converted to given unit  (new)
>>>>    OvmsMetrics.Value( {metric} )   -> Outputs Metric in native value
>>>> (same)
>>>>    OvmsMetrics.Value( {metric} , false)   -> Outputs Metric as string
>>>> and no units (same)
>>>>    OvmsMetrics.Value( {metric} ,  {unit})  -> Outputs Metric converted
>>>> to given unit as native value. (new)
>>>>   OvmsMetrics.Value( {metric} ,  {unit}, false )  -> Outputs Metric
>>>> converted to given unit as string including any unit specifier. (new)
>>>> also  OvmsMetric.GetValues( {metric} [,{unit}] [, {converted} ] )  Adds
>>>> similar behaviour to Value() above.
>>>> also the special units '*imperial*' and '*metric*' will convert to the
>>>> associated imperial / metric version of the units as appropriate.
>>>> (function() {
>>>>    dump = function (metric) { print( metric+ " ["+(typeof metric)+"]\n"
>>>>    dump_obj = function (obj )  {
>>>>      print('--- Object ----\n')
>>>>      for (var k in obj) {
>>>>        xk = obj[k];
>>>>        print( k+':'+ xk + ' ['+typeof xk+ "]\n");
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption"));
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", false));
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh"));
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false));
>>>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption"));
>>>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh"));
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial"))
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial", false))
>>>>    dump_obj(OvmsMetrics.GetValues("trip", "metric"))
>>>>    dump_obj(OvmsMetrics.GetValues("trip", "imperial", false))
>>>> With this output:
>>>> 19.2308 [number]
>>>> 19.2308 [string]
>>>> 5.2 [number]
>>>> 3.23112mi/kWh [string]
>>>> 19.2308 [number]
>>>> 5.2 [number]
>>>> 309.49 [number]
>>>> 309.49Wh/mi [string]
>>>> --- Object ----
>>>> v.p.trip:13 [number]
>>>> xiq.e.trip:0 [number]
>>>> xiq.e.trip.energy.recuperated:0 [number]
>>>> xiq.e.trip.energy.used:0 [number]
>>>> xiq.v.trip.consumption:19.2308 [number]
>>>> --- Object ----
>>>> v.p.trip:8.07781M [string]
>>>> xiq.e.trip:0M [string]
>>>> xiq.e.trip.energy.recuperated:0kWh [string]
>>>> xiq.e.trip.energy.used:0kWh [string]
>>>> xiq.v.trip.consumption:309.49Wh/mi [string]
>>>> On Wed, 9 Nov 2022 at 05:47, Michael Geddes <
>>>> frog at bunyip.wheelycreek.net> wrote:
>>>>> Yeah - I like HasValue.  I implemented IsDefined() but I will rename
>>>>> it.. that's a much clearer name.
>>>>> Another thought. How about if we did this (but also with GetValues()
>>>>> as well - see the special values below)
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption",  true)  -> 17.0582
>>>>> (Number)
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption",  false)  -> 17.0582
>>>>> (String)
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", true)  ->
>>>>> 3.64264  (Number)
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)  ->
>>>>> 3.64264Mi/kWh  (String)
>>>>>  OvmsMetrics.Value("xiq.v.trip.consumption", "native", false)  ->
>>>>> 17.0582km/kWh  (String)
>>>>> and
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "imperial", false)  ->
>>>>> I have already implemented the special values 'native' (existing),
>>>>> 'imperial' and 'metric'.
>>>>> I was also thinking that in the future you could have 'user'. Where
>>>>> for each group of values:
>>>>> 'temperature', 'distance', 'shortdistance', 'power' etc.. you could
>>>>> have a user preference. I probably won't implement it now,.but it could be
>>>>> cool that any UI could just ask for the user defined units (rather than
>>>>> having a separate choice).
>>>>> //.ichael
>>>>> On Tue, 8 Nov 2022 at 21:57, Mark Webb-Johnson <mark at webb-johnson.net>
>>>>> wrote:
>>>>>> Or perhaps something more specific?
>>>>>>     HasValue()
>>>>>> Mark
>>>>>> On 8 Nov 2022, at 9:01 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>> Signed PGP part
>>>>>> That's basically a good approach, but be aware 'IsDefined()' has an
>>>>>> ambiguous meaning here, as with the API stem "OvmsMetrics" it would
>>>>>> naturally be expected to mean "is this metric defined", not "does this
>>>>>> metric have a defined value".
>>>>>> An undefined metric currently can be derived from 'Values()'
>>>>>> returning undefined, but that's more an undocumented side effect than
>>>>>> intended.
>>>>>> Maybe 'GetDefined()' could be a better name, leveraging this
>>>>>> behaviour, i.e. returning 'undefined' for an actually undefined metric, and
>>>>>> 'null' for a defined metric without a value.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 08.11.22 um 13:46 schrieb Michael Geddes:
>>>>>> Ah yes. Arrays - will check those.  Yeah, how about we add a
>>>>>> 'IsDefined' method to metrics instead of the null thing (it does sound like
>>>>>> it will upset too many applecarts).
>>>>>> On Tue, 8 Nov 2022 at 20:35, Michael Balzer <dexter at expeedo.de>
>>>>>> wrote:
>>>>>>> Michael,
>>>>>>> looks all good to me, once again nice find with the decode argument.
>>>>>>> Adding decode to the Value() call was only for symmetry IIRC, the main use
>>>>>>> was with GetValues() (
>>>>>>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsmetrics
>>>>>>> Don't forget to test arrays, e.g. "v.t.pressure" & "v.t.temp".
>>>>>>> Returning null for an undefined metric seems like a natural choice,
>>>>>>> but is a rather deep change, as for consistency not only the Duktape
>>>>>>> metrics API but also the Web UI metrics API would need to be changed
>>>>>>> accordingly. Unless you've got a real use case that needs that, we should
>>>>>>> be careful.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 07.11.22 um 15:00 schrieb Michael Geddes:
>>>>>>> I have figured out a bunch of stuff and have implemented the
>>>>>>> following: (having done away with needing AsFloatUnit)
>>>>>>> OvmsMetrics.Value( {metric} [, {decode}])
>>>>>>> OvmsMetrics.Value( {metric}, {unit} [,{decode}])
>>>>>>> It turns out that the [decode] flag wasn't working anyway (since the
>>>>>>> function was being registered as only having 1 param)...
>>>>>>> This way it is still really 1 function.. but I check it the second
>>>>>>> parameter is a 'boolean', and if not.. try the second form.
>>>>>>> OvmsMetrics.AsFloat( {metric} [,{unit}] )
>>>>>>> and add the function
>>>>>>> Ovms.Metrics.ValueUnit( {metric} [,{unit}])
>>>>>>> This prints the value and the unit.
>>>>>>> Here's a sample function and the output! This also shows the types
>>>>>>> of the output.
>>>>>>> (function() {
>>>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption");
>>>>>>>    print( (typeof x) + ": "+  x+"\n"  );
>>>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption", false);
>>>>>>>    print( (typeof x) + ": "+  x +"\n" );
>>>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh")
>>>>>>>    print( (typeof x) + ": "+ x +"\n");
>>>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)
>>>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
>>>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
>>>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption")
>>>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh")
>>>>>>> number: 17.0582
>>>>>>> string: 17.0582
>>>>>>> number: 5.86227
>>>>>>> string: 3.64264
>>>>>>> string: 17.0582kWh/100km
>>>>>>> string: 3.64264mi/kWh
>>>>>>> number: 17.0582
>>>>>>> number: 5.86227
>>>>>>> It still might be an idea to use 'null' as a return value if the
>>>>>>> metrics is !IsDefined() but that would be changing the existing
>>>>>>> behaviour slightly.
>>>>>>> //.ichael
>>>>>>> On Mon, 7 Nov 2022 at 08:12, Michael Geddes <
>>>>>>>> I've worked out what the decode flag is for and how it works, and I
>>>>>>>> think how optional params work.
>>>>>>>> I'm pretty sure I won't  need the 'AsFloatUnit' function; the unit
>>>>>>>> would be an option to AsFloat(); I'll know that soon.
>>>>>>>> The 'Value' function is more complicated because of the optional
>>>>>>>> decode bool. I guess I could add the Unit to the end of that.
>>>>>>>> ValueUnit could be still useful then to provide a 'Value + Unit'.
>>>>>>>> Question:  Is there a reason we shouldn't be returning with
>>>>>>>> duk_push_null    if the metric !IsDefined()  in both AsFloat() and
>>>>>>>> Value(metric,true) cases?
>>>>>>>> //.ichael
>>>>>>>> On Sun, 6 Nov 2022 at 11:22, Michael Geddes <
>>>>>>>>> Right, so I've implemented some stuff that seems to work quite
>>>>>>>>> well.
>>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>>>>>>>>> should be ready now after a couple of stupid mistakes slipped through.
>>>>>>>>>  This absolutely needs somebody to review it please! (There's a reason why
>>>>>>>>> I've converted some if()'s to switch() - which is that it will be used in
>>>>>>>>> the follow-up commit).
>>>>>>>>> The commit that will follow on from that it implements the new
>>>>>>>>> Units: kWh/100km, km/kWh  and  mi/kWh.
>>>>>>>>> This is a summary of what I've implemented for scripting -
>>>>>>>>> including showing the unit codes I have so far.  I've considered a few
>>>>>>>>> things:
>>>>>>>>>   * Should some of the longer unit codes be shortened  (eg mi,
>>>>>>>>> mins, m, ft, deg, perc)
>>>>>>>>>   * The unit codes could be much more regular and separated by
>>>>>>>>> dots  eg:
>>>>>>>>>         watthours -> w.h
>>>>>>>>>         kwhp100km -> kw.h_100km or kw.h/100km
>>>>>>>>>         miph ->  mi_h or mi/h  (or should it be mph).
>>>>>>>>>         psi -> p_in.in or p/in.in or lb_in.in (yes, slightly
>>>>>>>>> weird, but predictable)
>>>>>>>>> *OVMS# metric units*
>>>>>>>>>           km : km
>>>>>>>>>        miles : M
>>>>>>>>>       meters : m
>>>>>>>>>         feet : ft
>>>>>>>>>      celcius : °C
>>>>>>>>>   fahrenheit : °F
>>>>>>>>>          kpa : kPa
>>>>>>>>>           pa : Pa
>>>>>>>>>          psi : psi
>>>>>>>>>        volts : V
>>>>>>>>>         amps : A
>>>>>>>>>     amphours : Ah
>>>>>>>>>           kw : kW
>>>>>>>>>          kwh : kWh
>>>>>>>>>        watts : W
>>>>>>>>>    watthours : Wh
>>>>>>>>>      seconds : Sec
>>>>>>>>>      minutes : Min
>>>>>>>>>        hours : Hour
>>>>>>>>>          utc : UTC
>>>>>>>>>      degrees : °
>>>>>>>>>         kmph : km/h
>>>>>>>>>         miph : Mph
>>>>>>>>>       kmphps : km/h/s
>>>>>>>>>       miphps : Mph/s
>>>>>>>>>         mpss : m/s²
>>>>>>>>>          dbm : dBm
>>>>>>>>>           sq : sq
>>>>>>>>>      percent : %
>>>>>>>>>        whpkm : Wh/km
>>>>>>>>>        whpmi : Wh/mi
>>>>>>>>>    kwhp100km : kWh/100km
>>>>>>>>>       kmpkwh : km/kWh
>>>>>>>>>       mipkwh : mi/kWh
>>>>>>>>>           nm : Nm
>>>>>>>>> *OVMS# metric unit mi*
>>>>>>>>>        miles : M
>>>>>>>>>      minutes : Min
>>>>>>>>>         miph : Mph
>>>>>>>>>       miphps : Mph/s
>>>>>>>>>        whpmi : Wh/mi
>>>>>>>>>       mipkwh : mi/kWh
>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption *17.0597kWh/100km
>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption kpkwh *5.86177km/kWh
>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption mpkwh *3.64233mi/kWh
>>>>>>>>> *OVMS# metric set xiq.c.speed 5 miph *Metric set
>>>>>>>>> *OVMS# metric get xiq.c.speed *8.04673km/h
>>>>>>>>> *OVMS# metric get xiq.c.speed miph *5Mph
>>>>>>>>> And then in DukTape - there are some questions I have about the
>>>>>>>>> implementation:
>>>>>>>>> * Names of functions? Better ideas?
>>>>>>>>> * Should ValueUnit output the units?
>>>>>>>>> * In Value() there is the line    bool decode =
>>>>>>>>> duk_opt_boolean(ctx, 1, true);
>>>>>>>>>     * What does 'decode' mean here?
>>>>>>>>>     * Do I need it for ValueUnit() ?
>>>>>>>>> * (function() {    print(
>>>>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption"));    print("\n")    print(
>>>>>>>>> OvmsMetrics.ValueUnit("xiq.v.trip.consumption",""));    print("\n")
>>>>>>>>>  print( OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh"));
>>>>>>>>>  print("\n")    print(
>>>>>>>>> OvmsMetrics.AsFloatUnit("xiq.v.trip.consumption","kmpkwh")); })();*
>>>>>>>>> --- Output ---
>>>>>>>>> 17.0597
>>>>>>>>> 17.0597kWh/100km
>>>>>>>>> 3.64233mi/kWh
>>>>>>>>> 5.86177
>>>>>>>>> The basic stuff all works - it's just quibbling over the details..
>>>>>>>>> but let's get them right!
>>>>>>>>> //.ichael
>>>>>>>>> On Sat, 5 Nov 2022 at 20:09, Michael Geddes <
>>>>>>>>>> Yeah - this was copied code from kia/kona and is what triggered
>>>>>>>>>> these ideas; I totally agree this shouldn't be doubled up on.
>>>>>>>>>> I've got some commits centred round Metrics that I'll just check
>>>>>>>>>> over and push up ... and then I'll just have the single xiq.v.
>>>>>>>>>> trip.consumption metric (unless you have some ideas for the
>>>>>>>>>> namespace) which will be much neater.
>>>>>>>>>> If it's ok with you then I might do that unit conversion proposal.
>>>>>>>>>> Would it ok if the unit specifications were the same as to the
>>>>>>>>>> programatic codes in ovms_metrics.h?
>>>>>>>>>> (kWh,   WattHours , MetersPSS )
>>>>>>>>>> I would probably add a command
>>>>>>>>>> metric units <spec>
>>>>>>>>>> to list all (matching) units and their associated Labels.
>>>>>>>>>> //.ichael
>>>>>>>>>> On Sat, 5 Nov 2022 at 18:48, Michael Balzer <dexter at expeedo.de>
>>>>>>>>>> wrote:
>>>>>>>>>>> Michael,
>>>>>>>>>>> adding unit conversion support to the shell and Duktape commands
>>>>>>>>>>> is a good idea.
>>>>>>>>>>> Metrics are not meant to provide a user interface, they should
>>>>>>>>>>> be defined to be efficient and non-redundant.
>>>>>>>>>>> Btw, metrics names also shall not use upper case characters, and
>>>>>>>>>>> shall only use "." as a separator.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>>>>> Am 05.11.22 um 11:22 schrieb Michael Geddes:
>>>>>>>>>>> Hi all,
>>>>>>>>>>> Some of the code I copied from Kona/Kia code had both kwh/100km
>>>>>>>>>>> and km/kwh metrics in the code as 'Other'.
>>>>>>>>>>> Adding the various power consumption Units is not particularly
>>>>>>>>>>> hard (I will have a pull-request soon) - though the conversions between
>>>>>>>>>>> them all required some thought!
>>>>>>>>>>> ... but it also made me think these two metrics that are (with
>>>>>>>>>>> the consumption units added) defined like this:
>>>>>>>>>>> m_v_trip_consumption1 =
>>>>>>>>>>> MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km", 10, 0, kWHP100K);
>>>>>>>>>>> m_v_trip_consumption2 = MyMetrics.InitFloat("
>>>>>>>>>>> xiq.v.trip.consumption.km/kWh", 10, 0, kPkWH);
>>>>>>>>>>> These are effectively the same metric but in different units!
>>>>>>>>>>> I'm wondering if we would be better to have scripting and
>>>>>>>>>>> Duktape support for converting metrics to different unit!  This might be
>>>>>>>>>>> also quite useful for those strange countries that insist on using miles as
>>>>>>>>>>> a measurement.
>>>>>>>>>>> On top of the 'metric list' and 'metric set' we could add a
>>>>>>>>>>> 'metric get' which gets a single value.. and add unit support for get/set.
>>>>>>>>>>> I've also got a pull request that improves the precision of the
>>>>>>>>>>> km<->mi conversions and factors it out.
>>>>>>>>>>> //.ichael
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221117/f2556e98/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221117/f2556e98/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221117/f2556e98/attachment-0003.png>
