[Ovmsdev] Strange crashes when logging additional info in can logs
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Fri Nov 18 08:49:36 HKT 2022
Some news...
My issue was caused because of course I made a mistake with the way of
registering my metrics Listener.
I used the following code (see my previous post) in the constructor:
+ MyMetrics.RegisterListener(IDTAG.c_str(), "*",
std::bind(&canlog::MetricListener, this, _1));
and for the destructor:
+ MyMetrics.DeregisterListener(IDTAG.c_str());
I had to use IDTAG because this class has multiple instances.
The issue is passing IDTAG.c_str() as a parameter ;
becauseMyMetrics.RegisterListener stores the value of this const char*
parameter and uses it 1) as an immutable parameter and 2) as a value.
Of course this does not work with my first way to call
MyMetrics.RegisterListener :
* the memory buffer returned by IDTAG.c_str() has no more existence
after exiting the constructor, so this lead to memory corruption.
* when calling IDTAG.c_str() again in the destructor, there is
absolutely no chance that this c_str() call returns the same memory
address as the call in the constructor, so the value comparison will
never work.
I rewrote the code this way by adding a new member (m_idtag) to the class:
@ vehicle/OVMS.V3/components/can/src/canlog.cpp:352 @
canlog::canlog(const char* type, std::string format,
canformat::canformat_serve_
m_dropcount = 0;
m_filtercount = 0;
+ m_idtag = strdup(IDTAG.c_str());
using std::placeholders::_1;
using std::placeholders::_2;
MyEvents.RegisterEvent(IDTAG, "*", std::bind(&canlog::EventListener,
this, _1, _2));
+ if (NULL != m_idtag)
+ MyMetrics.RegisterListener(m_idtag, "*",
+ else
+ ESP_LOGE(TAG,"Cannot allocate memory - not registering metrics
listener");
int queuesize = MyConfig.GetParamValueInt("can", "log.queuesize",100);
m_queue = xQueueCreate(queuesize, sizeof(CAN_log_message_t));
@ vehicle/OVMS.V3/components/can/src/canlog.cpp:374 @
canlog::~canlog()
MyEvents.DeregisterEvent(IDTAG);
+ MyMetrics.DeregisterListener(m_idtag);
+ free((void*)m_idtag);
if (m_task)
Another option is to change MyMetrics.RegisterListener so that it store
*a copy* of the parameter, and does string comparison instead of a value
comparison:
modified: vehicle/OVMS.V3/main/ovms_metrics.cpp
@ vehicle/OVMS.V3/main/ovms_metrics.cpp:1019 @ void
OvmsMetrics::RegisterListener(const char* caller, const char* name, MetricC
return;
+ const char * caller_copy = (const char *)strdup(caller);
+ if (NULL == caller_copy)
+ ESP_LOGE(TAG, "Problem registering metric %s for caller %s -
insufficient memory",name,caller);
+ return;
MetricCallbackList *ml = k->second;
- ml->push_back(new MetricCallbackEntry(caller,callback));
+ ml->push_back(new MetricCallbackEntry(caller_copy,callback));
void OvmsMetrics::DeregisterListener(const char* caller)
@ vehicle/OVMS.V3/main/ovms_metrics.cpp:1041 @ void
while (itc!=ml->end())
MetricCallbackEntry* ec = *itc;
- if (ec->m_caller == caller)
+ if (strcmp(ec->m_caller, caller) == 0)
+ free((char *)ec->m_caller);
itc = ml->erase(itc);
delete ec;
I've tested both approaches and they both solve my issue : no more
crashes and memory corruption.
The second one is more "risky" (as it potentially impacts everyone) but
I think that it should not cause much regression.
Let me know what you think - should I make a PR for this second approach ?
Le 16/11/2022 à 22:45, Ludovic LANGE a écrit :
> Dear list,
> You may remember that I'm trying to enhance the "datalogger" side of
> OVMS - in different ways.
> One facet of this endeavour is to have (CAN) logs that also
> incorporate other data coming from OVMS. In particular, I'd like to
> have GNSS (GPS) data in the same log as my CAN data.
> My first try is to slightly alter `canlog.cpp` and add the ability to
> `LogInfo` some chosen metrics, in the same spirit of the already
> logged subset of events. (With CRTD format, it appears as comments)
> While doing this, I'm facing multiple crashes that are somehow strange:
> * The crashes only occur when closing the logs (`can log stop`),
> never when logging
> * The cause of the crash is not always the same (LoadProhibited,
> InstrFetchProhibited)
> * Sometimes the PC is impacted / overwritten
> The crashes seems to always occur in a window of 20s after the `can
> log stop` command (In general it's immediate, but sometime can take
> some more seconds).
> (It lead me also to discover that the feature of our version of
> esp-idf that resolves the memory addresses in the serial output -
> `make monitor` - is broken, and that it's better to use GDB for that)
> While I am doing my homework and try to solve this, I wanted to share
> it here also to see if you already encountered this and/or if my
> changes are not done properly / not on the right OS task / etc.... -
> for which I lack background and experience. (In the process I think I
> found a non-freed variable, but it's not causing my issue - cf
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/774
> Here are the changes - you'll see that the crash do occur as soon as I
> `LogInfo` something - after the log has been closed.
> modified: vehicle/OVMS.V3/components/can/src/canlog.cpp
> @ vehicle/OVMS.V3/components/can/src/canlog.cpp:355 @
> std::bind(&canlog::EventListener, this, _1, _2));
> @ vehicle/OVMS.V3/components/can/src/canlog.cpp:365 @
> canlog::~canlog()
> if (m_task)
> @ vehicle/OVMS.V3/components/can/src/canlog.cpp:441 @ void
> canlog::EventListener(std::string event, void* data)
> LogInfo(NULL, CAN_LogInfo_Event, event.c_str());
> +void canlog::MetricListener(OvmsMetric* metric) {
> + std::string name = metric->m_name;
> + ESP_LOGI(TAG,"MetricListener - enter : %s", name.c_str());
> + if (startsWith(name, "v.p.gps") || (name == "v.p.latitude") ||
> (name == "v.p.longitude") || (name == "v.p.altitude") || (name ==
> "v.p.direction") || (name == "v.p.satcount") || (name ==
> "m.net.wifi.sq") || (name == "m.freeram")) {
> + std::string metric_text = "metric: " + name;
> + ESP_LOGI(TAG,"MetricListener - keep : %s", metric_text.c_str());
> + LogInfo(NULL, CAN_LogInfo_Event, metric_text.c_str());
> const char* canlog::GetType()
> return m_type;
> Note: "m.net.wifi.sq" / "m.freeram" are providing debugging data, so
> that I can quickly receive metrics after the boot. Not what I'm
> interested in for the final version of course, and the list will be
> configurable.
> Here are some example of panic handler infos:
> Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception
> was unhandled.
> Core 1 register dump:
> PC : 0x400d95f8 PS : 0x00060830 A0 : 0x8030d32c
> A1 : 0x3ffc4980
> A2 : 0x3ffeb5a8 A3 : 0x00000000 A4 : 0xfefefefe
> A5 : 0x3ffb5200
> A6 : 0x3f805e78 A7 : 0x000000fe A8 : 0x800d95f0
> A9 : 0x3ffc4930
> A10 : 0x3ffeb5a8 A11 : 0x00000000 A12 : 0x00000009
> A13 : 0x73c80b46
> A14 : 0x3ffc4930 A15 : 0x3f8b4164 SAR : 0x00000004
> EXCCAUSE: 0x0000001c
> EXCVADDR: 0xfefeff2e LBEG : 0x4008abe4 LEND : 0x4008ac00
> LCOUNT : 0xffffffff
> ELF file SHA256: eb3e5ce8f67640c8
> Backtrace: 0x400d95f8:0x3ffc4980 0x4030d329:0x3ffc49e0
> 0x4012122d:0x3ffc4a00 0x40121296:0x3ffc4a60 0x40120e6e:0x3ffc4a80
> 0x400ede1f:0x3ffc4aa0 0x400eed41:0x3ffc4ae0 0x400ecdc9:0x3ffc4b00
> 0x4011c5b6:0x3ffc4b40 0x4011c7b6:0x3ffc4b70 0x4011c8d8:0x3ffc4be0 0x0
> 0x400d95f8 is exactly the address of the call to LogInfo in my changes:
> (gdb) list *0x400d95f8
> 0x400d95f8 is in canlog::MetricListener(OvmsMetric*)
> (vehicle/OVMS.V3/components/can/src/canlog.cpp:447).
> 442 std::string name = metric->m_name;
> 443 ESP_LOGI(TAG,"MetricListener - enter : %s", name.c_str());
> 444 if (startsWith(name, "v.p.gps") || (name == "v.p.latitude") ||
> 445 std::string metric_text = "metric: " + name;
> 446 ESP_LOGI(TAG,"MetricListener - keep : %s", metric_text.c_str());
> *447 LogInfo(NULL, CAN_LogInfo_Event, metric_text.c_str());*
> 448 }
> 449 }
> 450
> 0xfefe / 0xfefefefe seems related to some of the Heap Memory Debugging
> options I've activated (Cf
> https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/heap_debug.html
> ) and seems to indicate a possible use-after-free issue. I'll look to
> debug in that direction.
> Another version (before Heap Memory Debugging activated) did that from
> time to time:
> Guru Meditation Error: Core 0 panic'ed (InstrFetchProhibited).
> Exception was unhandled.
> Core 0 register dump:
> PC : 0x00008100 PS : 0x00060530 A0 : 0x802f0cf0
> A1 : 0x3ffd0f00
> A2 : 0x3ffeb214 A3 : 0x00008100 A4 : 0x402f1df8
> A5 : 0x00000000
> A6 : 0x00000003 A7 : 0x3ffb556c A8 : 0x800d9540
> A9 : 0x3ffd0ee0
> A10 : 0x3ffeb214 A11 : 0x00000000 A12 : 0x00000009
> A13 : 0x3f8b4a24
> A14 : 0xffffffff A15 : 0x40404040 SAR : 0x00000018
> EXCCAUSE: 0x00000014
> EXCVADDR: 0x00008100 LBEG : 0x4008a848 LEND : 0x4008a864
> LCOUNT : 0xffffffff
> ELF file SHA256: f4d0c43aa48ef759
> Backtrace: 0x00008100:0x3ffd0f00 0x402f0ced:0x3ffd0fb0
> 0x4011c56d:0x3ffd0fd0 0x4011c5c6:0x3ffd1020 0x4011c24a:0x3ffd1040
> 0x4014f51d:0x3ffd1060 0x4014f953:0x3ffd1080 0x4014e6e3:0x3ffd11d0
> 0x4014ef16:0x3ffd1210 0x4014f001:0x3ffd1230 0x4014f119:0x3ffd1260
> 0x4014e889:0x3ffd1290 0x4014e9ed:0x3ffd1310 0x4014ebf9:0x3ffd13f0
> Thanks for any hint or advices you may want to share.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221118/f2ac92b6/attachment-0001.htm>
