[Ovmsdev] Strange crashes when logging additional info in can logs
Ludovic LANGE ll-ovmsdev at lange.nom.fr
Thu Nov 17 05:45:34 HKT 2022
Dear list,
You may remember that I'm trying to enhance the "datalogger" side of
OVMS - in different ways.
One facet of this endeavour is to have (CAN) logs that also incorporate
other data coming from OVMS. In particular, I'd like to have GNSS (GPS)
data in the same log as my CAN data.
My first try is to slightly alter `canlog.cpp` and add the ability to
`LogInfo` some chosen metrics, in the same spirit of the already logged
subset of events. (With CRTD format, it appears as comments)
While doing this, I'm facing multiple crashes that are somehow strange:
  * The crashes only occur when closing the logs (`can log stop`), never
    when logging
  * The cause of the crash is not always the same (LoadProhibited,
    InstrFetchProhibited)
  * Sometimes the PC is impacted / overwritten
The crashes seems to always occur in a window of 20s after the `can log
stop` command (In general it's immediate, but sometime can take some
more seconds).
(It lead me also to discover that the feature of our version of esp-idf
that resolves the memory addresses in the serial output - `make monitor`
- is broken, and that it's better to use GDB for that)
While I am doing my homework and try to solve this, I wanted to share it
here also to see if you already encountered this and/or if my changes
are not done properly / not on the right OS task / etc.... - for which I
lack background and experience. (In the process I think I found a
non-freed variable, but it's not causing my issue - cf
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/774 )
Here are the changes - you'll see that the crash do occur as soon as I
`LogInfo` something - after the log has been closed.
modified: vehicle/OVMS.V3/components/can/src/canlog.cpp
@ vehicle/OVMS.V3/components/can/src/canlog.cpp:355 @
canlog::canlog(const char* type, std::string format,
canformat::canformat_serve_
    using std::placeholders::_1;
    using std::placeholders::_2;
    MyEvents.RegisterEvent(IDTAG, "*", std::bind(&canlog::EventListener,
this, _1, _2));
+  MyMetrics.RegisterListener(IDTAG.c_str(), "*",
std::bind(&canlog::MetricListener, this, _1));
    int queuesize = MyConfig.GetParamValueInt("can", "log.queuesize",100);
    m_queue = xQueueCreate(queuesize, sizeof(CAN_log_message_t));
@ vehicle/OVMS.V3/components/can/src/canlog.cpp:365 @
  canlog::~canlog()
    MyEvents.DeregisterEvent(IDTAG);
+  MyMetrics.DeregisterListener(IDTAG.c_str());
    if (m_task)
@ vehicle/OVMS.V3/components/can/src/canlog.cpp:441 @ void
canlog::EventListener(std::string event, void* data)
      LogInfo(NULL, CAN_LogInfo_Event, event.c_str());
+void canlog::MetricListener(OvmsMetric* metric) {
+    std::string name = metric->m_name;
+    ESP_LOGI(TAG,"MetricListener - enter : %s", name.c_str());
+  if (startsWith(name, "v.p.gps") || (name == "v.p.latitude") || (name
== "v.p.longitude") || (name == "v.p.altitude") || (name ==
"v.p.direction") || (name == "v.p.satcount") || (name ==
"m.net.wifi.sq") || (name == "m.freeram")) {
+    std::string metric_text = "metric: " + name;
+    ESP_LOGI(TAG,"MetricListener - keep : %s", metric_text.c_str());
+    LogInfo(NULL, CAN_LogInfo_Event, metric_text.c_str());
  const char* canlog::GetType()
    return m_type;
Note: "m.net.wifi.sq" / "m.freeram" are providing debugging data, so
that I can quickly receive metrics after the boot. Not what I'm
interested in for the final version of course, and the list will be
configurable.
Here are some example of panic handler infos:
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was
unhandled.
Core 1 register dump:
PC      : 0x400d95f8  PS      : 0x00060830  A0      : 0x8030d32c
A1      : 0x3ffc4980
A2      : 0x3ffeb5a8  A3      : 0x00000000  A4      : 0xfefefefe
A5      : 0x3ffb5200
A6      : 0x3f805e78  A7      : 0x000000fe  A8      : 0x800d95f0
A9      : 0x3ffc4930
A10     : 0x3ffeb5a8  A11     : 0x00000000  A12     : 0x00000009
A13     : 0x73c80b46
A14     : 0x3ffc4930  A15     : 0x3f8b4164  SAR     : 0x00000004
EXCCAUSE: 0x0000001c
EXCVADDR: 0xfefeff2e  LBEG    : 0x4008abe4  LEND    : 0x4008ac00
LCOUNT  : 0xffffffff
ELF file SHA256: eb3e5ce8f67640c8
Backtrace: 0x400d95f8:0x3ffc4980 0x4030d329:0x3ffc49e0
0x4012122d:0x3ffc4a00 0x40121296:0x3ffc4a60 0x40120e6e:0x3ffc4a80
0x400ede1f:0x3ffc4aa0 0x400eed41:0x3ffc4ae0 0x400ecdc9:0x3ffc4b00
0x4011c5b6:0x3ffc4b40 0x4011c7b6:0x3ffc4b70 0x4011c8d8:0x3ffc4be0 0x0
0x400d95f8 is exactly the address of the call to LogInfo in my changes:
(gdb) list *0x400d95f8
0x400d95f8 is in canlog::MetricListener(OvmsMetric*)
(vehicle/OVMS.V3/components/can/src/canlog.cpp:447).
442       std::string name = metric->m_name;
443       ESP_LOGI(TAG,"MetricListener - enter : %s", name.c_str());
444     if (startsWith(name, "v.p.gps") || (name == "v.p.latitude") ||
(name == "v.p.longitude") || (name == "v.p.altitude") || (name ==
445       std::string metric_text = "metric: " + name;
446       ESP_LOGI(TAG,"MetricListener - keep : %s", metric_text.c_str());
*447       LogInfo(NULL, CAN_LogInfo_Event, metric_text.c_str());*
448     }
449    }
450
0xfefe / 0xfefefefe seems related to some of the Heap Memory Debugging
options I've activated (Cf
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/heap_debug.html
) and seems to indicate a possible use-after-free issue. I'll look to
debug in that direction.
Another version (before Heap Memory Debugging activated) did that from
time to time:
Guru Meditation Error: Core  0 panic'ed (InstrFetchProhibited).
Exception was unhandled.
Core 0 register dump:
PC      : 0x00008100  PS      : 0x00060530  A0      : 0x802f0cf0 A1
: 0x3ffd0f00
A2      : 0x3ffeb214  A3      : 0x00008100  A4      : 0x402f1df8 A5
: 0x00000000
A6      : 0x00000003  A7      : 0x3ffb556c  A8      : 0x800d9540 A9
: 0x3ffd0ee0
A10     : 0x3ffeb214  A11     : 0x00000000  A12     : 0x00000009 A13
: 0x3f8b4a24
A14     : 0xffffffff  A15     : 0x40404040  SAR     : 0x00000018
EXCCAUSE: 0x00000014
EXCVADDR: 0x00008100  LBEG    : 0x4008a848  LEND    : 0x4008a864 LCOUNT
: 0xffffffff
ELF file SHA256: f4d0c43aa48ef759
Backtrace: 0x00008100:0x3ffd0f00 0x402f0ced:0x3ffd0fb0
0x4011c56d:0x3ffd0fd0 0x4011c5c6:0x3ffd1020 0x4011c24a:0x3ffd1040
0x4014f51d:0x3ffd1060 0x4014f953:0x3ffd1080 0x4014e6e3:0x3ffd11d0
0x4014ef16:0x3ffd1210 0x4014f001:0x3ffd1230 0x4014f119:0x3ffd1260
0x4014e889:0x3ffd1290 0x4014e9ed:0x3ffd1310 0x4014ebf9:0x3ffd13f0
Thanks for any hint or advices you may want to share.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221116/f2025c00/attachment.htm>
