[Ovmsdev] New Metric Units
Tue Nov 8 21:06:38 HKT 2022
Another option: add another argument to 'GetValues()' to optionally
modify the behaviour in this way.
Am 08.11.22 um 14:01 schrieb Michael Balzer:
> That's basically a good approach, but be aware 'IsDefined()' has an
> ambiguous meaning here, as with the API stem "OvmsMetrics" it would
> naturally be expected to mean "is this metric defined", not "does this
> metric have a defined value".
> An undefined metric currently can be derived from 'Values()' returning
> undefined, but that's more an undocumented side effect than intended.
> Maybe 'GetDefined()' could be a better name, leveraging this
> behaviour, i.e. returning 'undefined' for an actually undefined
> metric, and 'null' for a defined metric without a value.
> Am 08.11.22 um 13:46 schrieb Michael Geddes:
>> Ah yes. Arrays - will check those.  Yeah, how about we add a
>> 'IsDefined' method to metrics instead of the null thing (it does
>> sound like it will upset too many applecarts).
>> On Tue, 8 Nov 2022 at 20:35, Michael Balzer <dexter at expeedo.de> wrote:
>>     Michael,
>>     looks all good to me, once again nice find with the decode
>>     argument. Adding decode to the Value() call was only for symmetry
>>     IIRC, the main use was with GetValues()
>>     (https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsmetrics).
>>     Don't forget to test arrays, e.g. "v.t.pressure" & "v.t.temp".
>>     Returning null for an undefined metric seems like a natural
>>     choice, but is a rather deep change, as for consistency not only
>>     the Duktape metrics API but also the Web UI metrics API would
>>     need to be changed accordingly. Unless you've got a real use case
>>     that needs that, we should be careful.
>>     Regards,
>>     Michael
>>     Am 07.11.22 um 15:00 schrieb Michael Geddes:
>>>     I have figured out a bunch of stuff and have implemented the
>>>     following: (having done away with needing AsFloatUnit)
>>>     OvmsMetrics.Value( {metric} [, {decode}])
>>>     OvmsMetrics.Value( {metric}, {unit} [,{decode}])
>>>     It turns out that the [decode] flag wasn't working anyway (since
>>>     the function was being registered as only having 1 param)...
>>>     This way it is still really 1 function.. but I check it the
>>>     second parameter is a 'boolean', and if not.. try the second form.
>>>     OvmsMetrics.AsFloat( {metric} [,{unit}] )
>>>     and add the function
>>>     Ovms.Metrics.ValueUnit( {metric} [,{unit}])
>>>     This prints the value and the unit.
>>>     Here's a sample function and the output! This also shows the
>>>     types of the output.
>>>     (function() {
>>>        x = OvmsMetrics.Value("xiq.v.trip.consumption");
>>>        print( (typeof x) + ": "+  x+"\n"  );
>>>        x = OvmsMetrics.Value("xiq.v.trip.consumption", false);
>>>        print( (typeof x) + ": "+  x +"\n" );
>>>        x =  OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh")
>>>        print( (typeof x) + ": "+ x +"\n");
>>>        x =  OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh",
>>>     false)
>>>        x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
>>>        x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
>>>        x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption")
>>>        x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh")
>>>     number: 17.0582
>>>     string: 17.0582
>>>     number: 5.86227
>>>     string: 3.64264
>>>     string: 17.0582kWh/100km
>>>     string: 3.64264mi/kWh
>>>     number: 17.0582
>>>     number: 5.86227
>>>     It still might be an idea to use 'null' as a return value if the
>>>     metrics is!IsDefined() but that would be changing the existing
>>>     behaviour slightly.
>>>     //.ichael
>>>     On Mon, 7 Nov 2022 at 08:12, Michael Geddes
>>>     <frog at bunyip.wheelycreek.net> wrote:
>>>         I've worked out what the decode flag is for and how it
>>>         works, and I think how optional params work.
>>>         I'm pretty sure I won't  need the 'AsFloatUnit' function;
>>>         the unit would be an option to AsFloat(); I'll know that soon.
>>>         The 'Value' function is more complicated because of the
>>>         optional decode bool. I guess I could add the Unit to the
>>>         end of that.
>>>         ValueUnit could be still useful then to provide a 'Value +
>>>         Unit'.
>>>         Question:  Is there a reason we shouldn't be returning with
>>>         duk_push_null   if the metric !IsDefined()  in both
>>>         AsFloat() and Value(metric,true) cases?
>>>         //.ichael
>>>         On Sun, 6 Nov 2022 at 11:22, Michael Geddes
>>>             Right, so I've implemented some stuff that seems to work
>>>             quite well.
>>>             https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>>>             should be ready now after a couple of stupid mistakes
>>>             slipped through.   This absolutely needs somebody to
>>>             review it please! (There's a reason why I've converted
>>>             some if()'s to switch() - which is that it will be used
>>>             in the follow-up commit).
>>>             The commit that will follow on from that it implements
>>>             the new Units: kWh/100km, km/kWh  and  mi/kWh.
>>>             This is a summary of what I've implemented for scripting
>>>             - including showing the unit codes I have so far. I've
>>>             considered a few things:
>>>               * Should some of the longer unit codes be shortened
>>>             (eg mi, mins, m, ft, deg, perc)
>>>               * The unit codes could be much more regular and
>>>             separated by dots  eg:
>>>               watthours -> w.h
>>>               kwhp100km -> kw.h_100km or kw.h/100km
>>>               miph ->  mi_h or mi/h  (or should it be mph).
>>>               psi -> p_in.in <http://p_in.in> or p/in.in
>>>             <http://in.in> or lb_in.in <http://lb_in.in> (yes,
>>>             slightly weird, but predictable)
>>>             *OVMS# metric units*
>>>                       km : km
>>>                    miles : M
>>>                   meters : m
>>>                     feet : ft
>>>                  celcius : °C
>>>               fahrenheit : °F
>>>                      kpa : kPa
>>>                       pa : Pa
>>>                      psi : psi
>>>                    volts : V
>>>                     amps : A
>>>             amphours: Ah
>>>                       kw : kW
>>>                      kwh : kWh
>>>                    watts : W
>>>             watthours: Wh
>>>                  seconds : Sec
>>>                  minutes : Min
>>>                    hours : Hour
>>>                      utc : UTC
>>>                  degrees : °
>>>                     kmph : km/h
>>>             miph: Mph
>>>             kmphps: km/h/s
>>>             miphps: Mph/s
>>>                     mpss : m/s²
>>>                      dbm : dBm
>>>                       sq : sq
>>>                  percent : %
>>>                    whpkm : Wh/km
>>>             whpmi: Wh/mi
>>>                kwhp100km : kWh/100km
>>>             kmpkwh: km/kWh
>>>             mipkwh: mi/kWh
>>>                       nm : Nm
>>>             *OVMS# metric unit mi*
>>>                    miles : M
>>>                  minutes : Min
>>>                     miph : Mph
>>>                   miphps : Mph/s
>>>                    whpmi : Wh/mi
>>>                   mipkwh : mi/kWh
>>>             *OVMS# metric get xiq.v.trip.consumption
>>>             *17.0597kWh/100km
>>>             *OVMS# metric get xiq.v.trip.consumption kpkwh
>>>             *5.86177km/kWh
>>>             *OVMS# metric get xiq.v.trip.consumption mpkwh
>>>             *3.64233mi/kWh
>>>             *OVMS# metric set xiq.c.speed 5 miph
>>>             *Metric set
>>>             *OVMS# metric get xiq.c.speed
>>>             *8.04673km/h
>>>             *OVMS# metric get xiq.c.speed miph
>>>             *5Mph
>>>             And then in DukTape - there are some questions I have
>>>             about the implementation:
>>>             * Names of functions? Better ideas?
>>>             * Should ValueUnit output the units?
>>>             * In Value() there is the line bool decode =
>>>             duk_opt_boolean(ctx, 1, true);
>>>                 * What does 'decode' mean here?
>>>                 * Do I need it for ValueUnit() ?
>>>             (function() {
>>>                print( OvmsMetrics.Value("xiq.v.trip.consumption"));
>>>              print("\n")
>>>                print(
>>>             OvmsMetrics.ValueUnit("xiq.v.trip.consumption",""));
>>>              print("\n")
>>>                print(
>>>             OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh"));
>>>              print("\n")
>>>                print(
>>>             OvmsMetrics.AsFloatUnit("xiq.v.trip.consumption","kmpkwh"));
>>>             --- Output ---
>>>             17.0597
>>>             17.0597kWh/100km
>>>             3.64233mi/kWh
>>>             5.86177
>>>             The basic stuff all works - it's just quibbling over the
>>>             details.. but let's get them right!
>>>             //.ichael
>>>             On Sat, 5 Nov 2022 at 20:09, Michael Geddes
>>>                 Yeah - this was copied code from kia/kona and is
>>>                 what triggered these ideas; I totally agree this
>>>                 shouldn't be doubled up on.
>>>                 I've got some commits centred round Metrics that
>>>                 I'll just check over and push up ... and then I'll
>>>                 just have the single xiq.v.trip.consumption metric
>>>                 (unless you have some ideas for the namespace) which
>>>                 will be much neater.
>>>                 If it's ok with you then I might do that unit
>>>                 conversion proposal.
>>>                 Would it ok if the unit specifications were the same
>>>                 as to the programatic codes in ovms_metrics.h?
>>>                 (kWh,   WattHours , MetersPSS )
>>>                 I would probably add a command
>>>                 metric units <spec>
>>>                 to list all (matching) units and their associated
>>>                 Labels.
>>>                 //.ichael
>>>                 On Sat, 5 Nov 2022 at 18:48, Michael Balzer
>>>                     Michael,
>>>                     adding unit conversion support to the shell and
>>>                     Duktape commands is a good idea.
>>>                     Metrics are not meant to provide a user
>>>                     interface, they should be defined to be
>>>                     efficient and non-redundant.
>>>                     Btw, metrics names also shall not use upper case
>>>                     characters, and shall only use "." as a separator.
>>>                     Regards,
>>>                     Michael
>>>                     Am 05.11.22 um 11:22 schrieb Michael Geddes:
>>>>                     Hi all,
>>>>                     Some of the code I copied from Kona/Kia code
>>>>                     had both kwh/100km and km/kwh metrics in the
>>>>                     code as 'Other'.
>>>>                     Adding the various power consumption Units is
>>>>                     not particularly hard (I will have a
>>>>                     pull-request soon) - though the conversions
>>>>                     between them all required some thought!
>>>>                     ... but it also made me think these two metrics
>>>>                     that are (with the consumption units added)
>>>>                     defined like this:
>>>>                     m_v_trip_consumption1 =
>>>>                     MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km",
>>>>                     10, 0, kWHP100K);
>>>>                     m_v_trip_consumption2 =
>>>>                     MyMetrics.InitFloat("xiq.v.trip.consumption.km/kWh
>>>>                     <http://xiq.v.trip.consumption.km/kWh>", 10, 0,
>>>>                     kPkWH);
>>>>                     These are effectively the same metric but in
>>>>                     different units!
>>>>                     I'm wondering if we would be better to have
>>>>                     scripting and Duktape support for converting
>>>>                     metrics to different unit!  This might be also
>>>>                     quite useful for those strange countries that
>>>>                     insist on using miles as a measurement.
>>>>                     On top of the 'metric list' and 'metric set' we
>>>>                     could add a 'metric get' which gets a single
>>>>                     value.. and add unit support for get/set.
>>>>                     I've also got a pull request that improves the
>>>>                     precision of the km<->mi conversions and
>>>>                     factors it out.
>>>>                     //.ichael
>>>>                     _______________________________________________
>>>>                     OvmsDev mailing list
>>>>                     OvmsDev at lists.openvehicles.com
>>>>                     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>                     Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>                     Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221108/281b667c/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221108/281b667c/attachment-0001.sig>
