[Ovmsdev] New Metric Units
Sat Nov 5 18:48:02 HKT 2022
Michael,
adding unit conversion support to the shell and Duktape commands is a
good idea.
Metrics are not meant to provide a user interface, they should be
defined to be efficient and non-redundant.
Btw, metrics names also shall not use upper case characters, and shall
only use "." as a separator.
Am 05.11.22 um 11:22 schrieb Michael Geddes:
> Hi all,
> Some of the code I copied from Kona/Kia code had both kwh/100km and
> km/kwh metrics in the code as 'Other'.
> Adding the various power consumption Units is not particularly hard (I
> will have a pull-request soon) - though the conversions between them
> all required some thought!
> ... but it also made me think these two metrics that are (with the
> consumption units added) defined like this:
> m_v_trip_consumption1 =
> MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km", 10, 0, kWHP100K);
> m_v_trip_consumption2 =
> MyMetrics.InitFloat("xiq.v.trip.consumption.km/kWh
> <http://xiq.v.trip.consumption.km/kWh>", 10, 0, kPkWH);
> These are effectively the same metric but in different units!
> I'm wondering if we would be better to have scripting and Duktape
> support for converting metrics to different unit! This might be also
> quite useful for those strange countries that insist on using miles as
> a measurement.
> On top of the 'metric list' and 'metric set' we could add a 'metric
> get' which gets a single value.. and add unit support for get/set.
> I've also got a pull request that improves the precision of the
> km<->mi conversions and factors it out.
> //.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221105/d2619784/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221105/d2619784/attachment-0001.sig>
