[Ovmsdev] Ioniq 5 - Pushing up some prerequisite changes to components/vehicles
Michael Geddes
Thu Nov 3 05:54:40 HKT 2022
Those formats I just copied from the previous code... So am very happy to
change them.
Let me know if you decide on some standard metrics...
I would welcome some assistance in mapping out more metrics (and commands?)
On Thu, 3 Nov 2022, 12:33 am Michael Balzer, <dexter at expeedo.de> wrote:
> Michael,
> very nice initial release.
> Some of your custom metrics are clearly standard candidates, I'll have a
> closer look.
> Some of your metrics namings are a bit off the standard scheme, for
> example "xiq.version" would better be "xiq.m.version". Reason for this is
> users can use the same metrics query pattern to get all standard and custom
> metrics of that segment, e.g. to get all software versions:
> OVMS# me li m.ver
> m.version 3.3.003-63-g942d04f7/ota_0/edge
> (build idf v3.3.4-849-g6e214dc335 Nov 2 2022 08:00:16)
> xvu.m.version 0.22.5 Nov 2 2022 08:00:41
> Likewise "v.d." should list all door related metrics, and so on. But
> you're free to go against that scheme where appropriate.
> Before reworking these, let me check for standard model candidates. Your
> door and seat belt ones clearly are some.
> Build is already on my server, I'll also post a note on the german
> Goingelectric forum.
> Am 02.11.22 um 10:04 schrieb Michael Geddes:
> Excellent,
> Pull request has gone up for Ioniq 5
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/762
> I hope I haven't pre-empted some of the config things/defaults.
> There is still a bunch of work I'd like to do in discovering more
> addresses... and I'm kinda hoping that somebody with better resources can
> fill in some controls (I got as far as confirming that none of the ones
> from the Kia/Kona work).
> For eg I found accelerator pedal percent, but not the brake, and I've
> confirmed all the door and lids.. except the charge port one!
> Unfortunately I also don't have a second driver in the household (who can
> physically drive my car without extra controls) so I can't drive around and
> query stuff.. but I have a friend who might be up for it.
> The VIN I get is a weird partial thing with the letters (in a weird order)
> and no number. NFI if it's encoded weirdly or what.
> I have an OBD splitter on the way that might help me work out why the HUD
> I bought doesn't work (at the least I can test the voltage drop).
> //.ichael
> On Wed, 2 Nov 2022 at 14:57, Michael Balzer <dexter at expeedo.de> wrote:
>> If you only add the #defines, that's ok included in your PR. If you also
>> change usages of 0x7df etc. in the vehicle framework, that would be a
>> separate PR.
>> Am 02.11.22 um 00:54 schrieb Michael Geddes:
>> I'm close to the ioniq5 release now. (Read-only for the moment). Thanks
>> for your support and patience!
>> One of the things I included were the following defines in vehicle.h
>> which I think should go here, but I'm really not fussed.
>> #define VEHICLE_OBD_BROADCAST_MODULE_TX 0x7df
>> #define VEHICLE_OBD_BROADCAST_MODULE_RX 0x0
>> These are used in the following call to get at the VIN.
>> std::string response;
>> int res = PollSingleRequest( m_can1,
>> VEHICLE_OBD_BROADCAST_MODULE_TX, VEHICLE_OBD_BROADCAST_MODULE_RX,
>> VEHICLE_POLL_TYPE_OBDIIVEHICLE, 2, response, 1000);
>> questions:
>> - Do you want one/both these in vehicle.h (I can always just have 0
>> in place of *_RX in the call)?
>> - If so, should I:
>> - make a separate P/R or
>> - just include it as a commit in the Ioniq-5 P/R ?
>> //.ichael
>> On Sat, 29 Oct 2022 at 22:48, Michael Balzer <dexter at expeedo.de> wrote:
>>> I've already merged PR #754 and commented on #753.
>>> Other opinions on #753 are of course welcome.
>>> Am 29.10.22 um 16:25 schrieb Michael Geddes:
>>> No problems at all, these were just thoughts.
>>> So are those 2 PRs ok as they stand?
>>> I have a couple more in the pipeline(as I previously described) before
>>> the main I5 one.
>>> Mihael
>>> On Sat, 29 Oct 2022, 8:16 pm Michael Balzer, <dexter at expeedo.de> wrote:
>>>> Michael,
>>>> please don't change existing vehicle code for personal code style
>>>> reasons. The existing data extraction methods have been working and will
>>>> continue to work. By adding your utilities to the framework, we're giving
>>>> everyone interested the opportunity to consider using these, we don't force
>>>> them to do.
>>>> Regarding your combined data extraction & metric setting utility, from
>>>> my experience this won't be applicable in many (most) cases, or would need
>>>> quite a lot of extra features exceeding a simple scaling. Applications
>>>> often need or want to change metrics only indirectly after processing the
>>>> raw data read from the bus, often in combination with other readings and/or
>>>> delayed. Validity checks also need to be done in a broad variety, often
>>>> with side conditions.
>>>> A good approach is to first define & refine your generalized methods
>>>> locally in your component. Keep an eye on the existing method signatures,
>>>> so once you're happy with them it's easy to move them into the framework.
>>>> That way you'll avoid having to break compatibility for other developers
>>>> possibly already using an early release of your method.
>>>> Regards,
>>>> Michael
>>>> Am 27.10.22 um 09:36 schrieb Michael Geddes:
>>>> While I'm still happy with the base data extraction tools, I'm
>>>> wondering if some more direct tools would be better.
>>>> For example some methods on the Base vehicle that takes a buffer, a
>>>> byte index and template byte count a Metric object and a multiplier.. That
>>>> will conditionally set the metric if the data is within bounds.
>>>> Or methods on the metrics themselves that has similar results.
>>>> I notice that index by 4 bit 'nibbles' is also a Thing That Is Done.
>>>> I'm happy to implement that if there's appetite for it... And possibly
>>>> look at a few Vehicles to switch to that
>>>> Michael
>>>> On Mon, 24 Oct 2022, 1:26 pm Michael Geddes, <
>>>> frog at bunyip.wheelycreek.net> wrote:
>>>>> Ok - so I've pared down my requirements on the BMS module to the
>>>>> ability to be able to cap the # of Voltages/Temperatures at a lower (only)
>>>>> value than initialised at.
>>>>> This means that the code to create the averages etc is just pulled out
>>>>> to a private function here:
>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/753
>>>>> This P/R request adds the buffer extraction tools (with 32bit length)
>>>>> to ovms utils.
>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/754
>>>>> //.ichael
>>>>> On Sun, 23 Oct 2022 at 17:38, Michael Geddes <
>>>>>> Thanks Michael,
>>>>>> I have taken it in, and I'll use std::string in poll once code. I
>>>>>> guess it might make sense to convert everything else to std::string. It
>>>>>> wouldn't be a big task.
>>>>>> I had just taken out that commit and reworked anyway, and now that
>>>>>> you say it's not the best way of doing things, I'm even happier I made that
>>>>>> choice, as I had intended to possibly make more use of it and won't now.
>>>>>> At the moment I'm using it to get the VIN (snipped) where I'll try a couple
>>>>>> of times only, rather than continually poll for it.
>>>>>> Hmm... yea - I guess I could do some dynamically created poll table.
>>>>>> Will definitely consider that.
>>>>>> Further comments inline below:
>>>>>> On Sun, 23 Oct 2022 at 16:15, Michael Balzer <dexter at expeedo.de>
>>>>>> wrote:
>>>>>>> Michael,
>>>>>>> what I really dislike about your change is that it adds complexity
>>>>>>> to the underlying function just to fulfill an -- in my eyes more academic
>>>>>>> -- type style choice: having to handle multiple buffer pointers just to
>>>>>>> provide different typing approaches is bad. You could introduce a new
>>>>>>> construct to provide a single polymorphic pointer, but that again adds
>>>>>>> complexity.
>>>>>>> Agreed, std::string is a bit type-sloppy in depending on char being
>>>>>>> unsigned 8 bit, but that's all to consider, and can easily be enforced if
>>>>>>> ever necessary.
>>>>>>> On the plus side, std::string has far better library support, better
>>>>>>> interoperability (see our use cases), and small string optimization, which
>>>>>>> is especially useful for our platform, as most poll requests and responses
>>>>>>> easily fit into the initial capacity, normally eliminating the need for
>>>>>>> heap allocations.
>>>>>>> So, besides the type independency, I think std::vector has no
>>>>>>> advantage here.
>>>>>>> There's another thing I'd like to address: it seems you're planning
>>>>>>> to use single polls extensively?
>>>>>>> If so, please don't, unless you're also going to do a full rewrite
>>>>>>> of the poller towards a job/worker service task architecture (that's a very
>>>>>>> old todo).
>>>>>>> The single poll utility is really meant for sparse/manual polls
>>>>>>> outside the normal polling scheme. See my comment on the method:
>>>>>>> * PollSingleRequest: perform *prioritized synchronous* single
>>>>>>> OBD2/UDS request
>>>>>>> * Pass a full OBD2/UDS request (mode/type, PID, additional
>>>>>>> payload).
>>>>>>> * The request is sent immediately, *aborting a running poll list
>>>>>>> request*. The previous
>>>>>>> * poller state is automatically restored after the request has
>>>>>>> been performed, but
>>>>>>> * *without any guarantee for repetition or omission of an aborted
>>>>>>> poll*.
>>>>>>> This was really meant more for user/script use than for standard
>>>>>>> vehicle polls, though it's OK to use it, where applicable, with caution.
>>>>>>> For all standard polling, install a PID list. You can vary a list by
>>>>>>> the poll state, and you can switch lists if necessary. PID lists can easily
>>>>>>> be generated dynamically, see the VWUP code for an example.
>>>>>>> The place for general CAN utility methods is the
>>>>>>> components/can/src/canutils module, general utility methods go into the
>>>>>>> main/ovms_utils module.
>>>>>> Ahh.. cool.
>>>>>>> Regarding CAN buffer data extraction, there are currently probably
>>>>>>> as many approaches as there are vehicle modules. Certainly would be nice to
>>>>>>> have some standard way here, but won't be simple to rework the existing
>>>>>>> vehicle adaptors.
>>>>>>> The template approach is a nice one for a general solution, but keep
>>>>>>> in mind not every vehicle will use big endian encoding, in some cases not
>>>>>>> even consistently throughout the installed devices.
>>>>>> I had already implemented little-endian and big-endian versions of
>>>>>> the data extract. I will now explicitly mark all of them.
>>>>>>> To be really general, your byte addressing needs to support more
>>>>>>> than 256 bytes in the buffer.
>>>>>> Consider that fixed.
>>>>>>> Your templates also lack bit masking and shifting. Some devices use
>>>>>>> packed structs with odd sized bit fields. The DBC engine has support for
>>>>>>> all this, but not generalized. I remember Mark getting a headache from this…
>>>>>> I have a get_bit<>() function and so I would propose it be
>>>>>> implemented in a similar way... ie exract the byte first, then get the bits.
>>>>>> Something like: extract_int<1,2>(byte) --> Extract bits len 2
>>>>>> starting from bit 1. We can easily sign-extend that too.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 23.10.22 um 02:23 schrieb Michael Geddes:
>>>>>>> Hi Michael,
>>>>>>> Just wanted to say that if you override my objections on the
>>>>>>> std::vector<unit8_t> in the single poll code then I'm fine with that, I
>>>>>>> recognised that it's absolutely your call and that bit has a small impact
>>>>>>> on my code so far. I can even add versions of the extraction functions
>>>>>>> that use std::string if you want (they would just be inline
>>>>>>> template wrappers around common code anyway so zero compiled cost).
>>>>>>> Also: Is there a better place to put those templated functions? A
>>>>>>> version of my sign_extend function is already being proposed being used
>>>>>>> here:
>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/736
>>>>>>> - it would be good if both versions of this function were available in a
>>>>>>> single place. (There's sign_extend<UINT, INT>(int_value, sign_bit) and
>>>>>>> sign_extend<UINT, INT, SIGNBIT>(int_value) - so they should work fine as
>>>>>>> overloaded template functions).
>>>>>>> I would consider also whether I use std::string in my own code where
>>>>>>> I'm extracting my data out of complete ISOTP poll results. Up to you. That
>>>>>>> has slightly more impact, but the code change is pretty easy.
>>>>>>> //.ichael
>>>>>>> On Sat, 22 Oct 2022 at 07:56, Michael Geddes <
>>>>>>>> Thanks Michael,
>>>>>>>> I had already created my commits under the assumption that you
>>>>>>>> would prefer the general changes separate from the vehicle-specific commits.
>>>>>>>> I have created 3 pull requests so far.
>>>>>>>> 1) the bug - that's a no-brainer.
>>>>>>>> 2) 'finalisation' of temperatures and voltages. (Draft, see below)
>>>>>>>> 3) vector poll. This is more a point of discussion (see below)
>>>>>>>> A couple of the next bugs are kind of dependent on the second, so
>>>>>>>> I'll wait until I get that sorted out.
>>>>>>>> More comments below.
>>>>>>>> On Fri, 21 Oct 2022 at 23:31, Michael Balzer <dexter at expeedo.de>
>>>>>>>> wrote:
>>>>>>>>> Michael,
>>>>>>>>> Am 19.10.22 um 07:26 schrieb Michael Geddes:
>>>>>>>>> > Hi all,
>>>>>>>>> > I have 6 commits that I would _like_ to get pushed up that are
>>>>>>>>> changes
>>>>>>>>> > to components/vehicles required for my Ioniq 5 changes to work.
>>>>>>>>> > I can push them all up in a single merge request for review, or
>>>>>>>>> > separate them out into bits. Some of them I am expecting there
>>>>>>>>> to be
>>>>>>>>> > opinions on. I'm prepared to simplify some, and one in
>>>>>>>>> particular has
>>>>>>>>> > grounds for nixing. I think it's a good change, but I could
>>>>>>>>> manage
>>>>>>>>> > without it.
>>>>>>>>> Please keep PRs as small as possible, focusing on one specific
>>>>>>>>> modification / addition at a time. That way, every merge commit
>>>>>>>>> can
>>>>>>>>> easily be reverted if necessary, and changes can be followed and
>>>>>>>>> referred to easily. Especially keep framework changes separate
>>>>>>>>> from
>>>>>>>>> vehicle specific ones.
>>>>>>>>> It's also OK to open the PRs tagged as drafts / work in progress,
>>>>>>>>> that
>>>>>>>>> helps in commenting on certain parts and tracing refinements.
>>>>>>>>> Create one
>>>>>>>>> branch for each PR, pushing new commits into the branch will
>>>>>>>>> automatically update any open PR created from it.
>>>>>>>> Ooh. That's useful. It's been a while since I've used github for
>>>>>>>> collab. Switched the battery sensor P/R over to a draft.
>>>>>>>>> > One is a simple bugfix - a literal one-character change:
>>>>>>>>> > void OvmsVehicle::BmsRestartCellTemperatures()
>>>>>>>>> > m_bms_bitset_t.clear();
>>>>>>>>> > - m_bms_bitset_v.resize(m_bms_readings_t);
>>>>>>>>> > + m_bms_bitset_t.resize(m_bms_readings_t);
>>>>>>>>> > m_bms_bitset_ct = 0;
>>>>>>>>> Obviously a copy & paste bug, nice find. I wonder how that could
>>>>>>>>> slip
>>>>>>>>> through without causing crashes, as there are more voltages than
>>>>>>>>> temperatures in most packs.
>>>>>>>>> Please don't hesitate with opening PRs even for single fixes like
>>>>>>>>> this,
>>>>>>>>> the sooner we include them, the better.
>>>>>>>> Yep. Done and understood.
>>>>>>>>> > On is a simple code readability change. Using an enum instead of
>>>>>>>>> magic
>>>>>>>>> > status values for m_bms_talerts. Simple enough, but I'm
>>>>>>>>> prepared to
>>>>>>>>> > simplify that to a standard enum or get rid of it.
>>>>>>>>> The magic values are simply alert levels, but go ahead,
>>>>>>>>> readability is a
>>>>>>>>> good goal.
>>>>>>>>> I'll include it once the Battery Cell code is finalised.
>>>>>>>>> > There's some battery related ones where I want to be able to not
>>>>>>>>> quite
>>>>>>>>> > know the number of cells from the start and let the OBD
>>>>>>>>> responses specify.
>>>>>>>>> Dynamic pack layout reconfiguration is no issue, I've done that on
>>>>>>>>> the
>>>>>>>>> Twizy (look for comments "update pack layout" or calls to
>>>>>>>>> BmsSetCellArrangement*).
>>>>>>>>> BmsSetCellArrangement does clear all the values... which is
>>>>>>>> probably the main thing I was trying to avoid. Ie- I get to the end and go
>>>>>>>> 'ooh.. only this number of cells were filled in'. More comments in the P/R
>>>>>>>> about what I want to achieve and fall-back positions.
>>>>>>>>> > There's also a battery one where the info for the cells have
>>>>>>>>> different
>>>>>>>>> > timings (because one has other info), so I want to be able to
>>>>>>>>> clear a
>>>>>>>>> > range of cells rather than just reset and start filling the info
>>>>>>>>> again.
>>>>>>>>> That may be a bad idea, maybe better to implement some
>>>>>>>>> synchronization /
>>>>>>>>> drop readings out of sync.
>>>>>>>>> Reaching a consistent state, the BMS will calculate deviations
>>>>>>>>> etc..
>>>>>>>>> Crucial on that part is an analysis of the consistency of the cell
>>>>>>>>> readings to determine the reliability of deviations exceeding
>>>>>>>>> thresholds.
>>>>>>>>> See my comments in BmsSetCellVoltage() and list thread:
>>>>>>>>> http://lists.openvehicles.com/pipermail/ovmsdev/2021-February/015079.html
>>>>>>>>> I've skimmed the comments but will read properly and digest.
>>>>>>>> Yeah it might be best if I just clear the values at the start of the more
>>>>>>>> often running one and then once the other ones come in it will finalise
>>>>>>>> once it gets to the end of those.. so they aren't too far apart.
>>>>>>>>> > I've modified slightly the dump for the battery cell
>>>>>>>>> > voltage/temperature, allowing for either or both columns to be
>>>>>>>>> visible
>>>>>>>>> > if available. It also copes with the above 'not set' scenario.
>>>>>>>>> Sounds good.
>>>>>>>> I'll push this once the FinaliseCellVoltage pull-request is
>>>>>>>> finalised and accepted.
>>>>>>>>> > Finally, the controversial one: I am using std::vector<uint8_t>
>>>>>>>>> as a
>>>>>>>>> > buffer in my ioniq5 code.. and I wanted to be able to use it for
>>>>>>>>> the
>>>>>>>>> > polling instead of std::string. I've not replaced the
>>>>>>>>> std::string but
>>>>>>>>> > added the ability to have either.
>>>>>>>>> > If my aversion to using std::string for binary data is
>>>>>>>>> misplaced, then
>>>>>>>>> > I'm ok with the currently small modification to my code that
>>>>>>>>> would use
>>>>>>>>> > the std::string version.
>>>>>>>>> The general use case of ISO-TP data is actually dynamic binary
>>>>>>>>> strings.
>>>>>>>>> They are meant to and need to be easily aggregated, cut, merged,
>>>>>>>>> partially extracted etc., so they really are strings, not vectors
>>>>>>>>> (type
>>>>>>>>> wise).
>>>>>>>> Hmm.. I'm not sure I entirely agree about needing to
>>>>>>>> aggregate/cut/merge; we know the size of the buffer after the first packet
>>>>>>>> comes in so we can pre-set the buffer internal size and append data as it
>>>>>>>> comes in without casting from uint8_t* to char *. Even if the size is
>>>>>>>> wrong, we can still very easily append to a vector.
>>>>>>>> ON the extraction, I have efficient templated functions that
>>>>>>>> extract the data from the std::vector<uint8_t> buffer.. including to a
>>>>>>>> std::string if required, or to big-endian/little-endian signed/unsigned
>>>>>>>> integers of 1..4 bytes with sign-extension now. These also check bounds so
>>>>>>>> are quite safe - possibly safer than the macros. The bounds check has
>>>>>>>> already proved itself useful.
>>>>>>>> I have pushed up a draft request 'single poll to buffer' as it is
>>>>>>>> the easiest way to describe what I want to do. The first commit is the
>>>>>>>> meat of the change ... but the second is adding all the utility functions.
>>>>>>>> They probably don't belong in vehicle.h/cpp, but that's easy enough to
>>>>>>>> change. I had them in my ioniq 5 specific code - but have shoved them in
>>>>>>>> there just for a point of discussion.
>>>>>>>> The great thing about the template functions here is that they
>>>>>>>> should expand inline at compile time to quite efficient code.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>> //.ichael
>>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221103/f154f8ac/attachment-0001.htm>
