[Ovmsdev] SWCAN
Alexander K
alexander.kiiash at gmail.com
Wed May 25 14:23:18 HKT 2022
NCV7356 is compliant to GMW3089.
Also TH8056 has two versions with 8 and 14 pins. Both are suitable.
пн, 23 мая 2022 г. в 10:40, Mark Webb-Johnson <mark at webb-johnson.net>:
> Discussing with the manufacturer, feedback is:
> - Given component vs board manufacturing cost, it seems simplest to
> combine this with the existing k-line option board, to produce a new
> ‘combo’ option board containing both K-line and SWCAN (DIP switch
> selectable one or the other, not both).
> - The TH8056 component is causing issues. Availability is poor (in
> China) and price is very high.
> Does anyone know of any alternative to the TH8056 that can be suggested?
> Any other comments on this?
> On 18 May 2022, at 8:55 AM, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
> Regarding:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/704
> Marko did some work on the back in 2019, and helpfully published under MIT
> license here:
> https://github.com/mjuhanne/OVMS-SWCAN
> Very grateful for that.
> Now, the Bolt EV people are asking for this.
> In general, it seems that we can do a simple board in the same way as the
> K-Line was done. Use the two available GPIOs (one for INT and the other
> CS). Then the GPIOs on the MCP2515 to control the transceiver mode. Expose
> the single SWCAN pin on the DB9, in the same way as K-Line does it. GND
> (for SWCAN-low) is already available there.
> Anybody see any problems with that approach?
> I am happy to arrange the hardware, given sufficient interest, but have
> almost no way of testing (as none of the cars I have access to have SWCAN).
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220525/6cd3e136/attachment.htm>
