[Ovmsdev] SWCAN
    Wed May 18 08:55:46 HKT 2022
Regarding: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/704 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/704>
Marko did some work on the back in 2019, and helpfully published under MIT license here:
https://github.com/mjuhanne/OVMS-SWCAN <https://github.com/mjuhanne/OVMS-SWCAN>
Very grateful for that.
Now, the Bolt EV people are asking for this.
In general, it seems that we can do a simple board in the same way as the K-Line was done. Use the two available GPIOs (one for INT and the other CS). Then the GPIOs on the MCP2515 to control the transceiver mode. Expose the single SWCAN pin on the DB9, in the same way as K-Line does it. GND (for SWCAN-low) is already available there.
Anybody see any problems with that approach?
I am happy to arrange the hardware, given sufficient interest, but have almost no way of testing (as none of the cars I have access to have SWCAN).
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220518/dbeb7d54/attachment.htm>
