[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Sun Mar 6 23:31:03 HKT 2022
Yes.
Am 06.03.22 um 15:28 schrieb Mark Webb-Johnson:
> Nice catch. I had reviewed that code section this afternoon, but
> missed it.
> Shall we make a 3.3.002 and push it to EAP?
> Regards, Mark
>> On 6 Mar 2022, at 5:58 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>  I've found & fixed the bug: there was an endless loop in
>> modem::IncomingMuxData() when the NMEA channel had not been created.
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/a6e5b9ab957ab72f56740d6fd4ba484fe1691f80
>> Am 05.03.22 um 11:21 schrieb Michael Balzer:
>>> I've now tried starting the NMEA channel without actually sending
>>> any GPS init commands (also no +CGPS=0).
>>> That inhibits the crashes, although apparently no NMEA sentences are
>>> coming in. The only communication on MUX channel 1 (NMEA) are some
>>> initial frames:
>>> balzer at leela:~/ovms/v3> grep -A1 CHAN=1 minicom.log
>>> V (26168) gsm-mux: ProcessFrame(CHAN=1, ADDR=07, CTRL=73, FCS=15, LEN=6)
>>> I (26168) gsm-mux: Channel #1 is open
>>> V (32568) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56,
>>> LEN=20)
>>> V (32568) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=d1,
>>> LEN=20)
>>> V (32938) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5,
>>> LEN=21)
>>> V (32938) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=32,
>>> LEN=21)
>>> V (36948) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56,
>>> LEN=20)
>>> V (36948) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=d1,
>>> LEN=20)
>>> V (38968) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5,
>>> LEN=21)
>>> V (38968) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=32,
>>> LEN=21)
>>> V (42638) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5,
>>> LEN=21)
>>> V (42638) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f0,
>>> LEN=21)
>>> V (44988) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5,
>>> LEN=21)
>>> V (44988) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f0,
>>> LEN=21)
>>> Unrelated to this issue, but possibly to the framing errors: I've
>>> also removed the NMEA log filter from modem::StandardLineHandler()
>>> and found after normal GPS startup, the NMEA sentences always come
>>> in three times via three MUX channels – additionally to channel 1 on
>>> channels 3 & 4:
>>> V (130148) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
>>> LEN=78)
>>> D (130148) gsm-nmea: Incoming RMC:
>>> $GPRMC,095314.00,A,xxxx.139928,N,xxxx.391626,E,0.0,,050322,0.9,W,A*06
>>> V (130158) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>>> LEN=78)
>>> D (130158) cellular: mux-rx-line #3:
>>> V (130158) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>>> LEN=78)
>>> D (130158) cellular: mux-rx-line #4:
>>> V (130168) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
>>> LEN=82)
>>> D (130168) gsm-nmea: Incoming GNS:
>>> $GNGNS,095314.00,xxxx.139928,N,xxxx.391626,E,AAN,16,0.7,327.9,47.0,,,V*60
>>> V (130178) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>>> LEN=82)
>>> D (130178) cellular: mux-rx-line #3:
>>> V (130178) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
>>> LEN=82)
>>> D (130178) cellular: mux-rx-line #4:
>>> I don't know if that's intended behaviour or can be changed, but I
>>> suspect this to add unnecessary load to the serial communication.
>>> Am 05.03.22 um 09:02 schrieb Michael Balzer:
>>>> Another theory: I found Mark's comment in the SIM7600 driver NMEA
>>>> startup:
>>>>   // We need to do this a little differently from the standard, as
>>>> SIM7600
>>>>   // may start GPS on power up, and doesn't like us using CGPS=1,1 when
>>>>   // it is already on. So workaround is to first CGPS=0.
>>>> IOW, the SIM7600 may have GPS enabled by default, possibly also
>>>> sending NMEA sentences, if not explicitly switched off.
>>>> BTW, that also explains the difficulties in booting a 3.3 module
>>>> from USB… :-/
>>>> a) We don't switch off GPS if GPS is disabled.
>>>> b) I just tried switching off GPS manually after a GPS-enabled
>>>> startup, and the modem still continued to send NMEA sentences:
>>>> OVMS# cellular cmd AT+CGPS=0
>>>> MODEM command has been sent.
>>>>>>>> D (475190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>>> V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1,
>>>> LEN=31)
>>>> V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc,
>>>> LEN=31)
>>>> V (475190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60,
>>>> LEN=32)
>>>> D (475190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
>>>> V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25,
>>>> LEN=32)
>>>> V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28,
>>>> LEN=32)
>>>> V (480180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84,
>>>> LEN=31)
>>>> D (480190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>>>>>>> OVMS# cellular cmd AT+CGPSNMEA=0
>>>> D (505190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>>> V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1,
>>>> LEN=31)
>>>> V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc,
>>>> LEN=31)
>>>> V (505190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60,
>>>> LEN=32)
>>>> D (505190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
>>>> V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25,
>>>> LEN=32)
>>>> V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28,
>>>> LEN=32)
>>>> V (510180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84,
>>>> LEN=31)
>>>> D (510190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>>> So without us starting the NMEA subsystem, is it possible these
>>>> transmissions are still there, filling up some MUX buffer?
>>>> Regards,
>>>> Michael
>>>> Am 05.03.22 um 08:33 schrieb Michael Balzer:
>>>>> I've tried to reproduce this with my old 3.2 & hand soldered 3.3
>>>>> dev module, with different vehicle modules and modem GPS disabled.
>>>>> Results:
>>>>> - the vehicle module is irrelevant
>>>>> - 3.2 (SIM5360E) runs without issues (had this running over night)
>>>>> - 3.3 (SIM7600G) consistently crashes by the TWDT within a couple
>>>>> of minutes after modem init
>>>>> This is caused by the modem task hogging core 0 as soon as the PPP
>>>>> connection is up:
>>>>> I (87161) cellular: Identified cellular modem:
>>>>> SIM7600/Experimental support for SIMCOM SIM7600
>>>>> D (87161) cellular: Remove old 'auto' modem driver
>>>>> I (87161) cellular: Set modem driver to 'SIM7600'
>>>>> I (87161) cellular: State: Enter PoweredOn state
>>>>> OVMS# mo ta
>>>>> Number of Tasks = 18        Stack:  Now   Max Total Heap 32-bit
>>>>> SPIRAM C# PRI CPU% BPR/MH
>>>>> 3FFAFB88    1 Blk esp_timer         436   708  4096 41648    644
>>>>> 44544  0  22   0%  22/ 0
>>>>> 3FFC2BD8    2 Blk OVMS DukTape      500  9252 12288     188      0
>>>>> 524288  1   5   0%   5/ 0
>>>>> 3FFC46B4    3 Blk eventTask         480  2032 4608     108
>>>>> 0      0  0  20   0%  20/ 0
>>>>> 3FFC6B38    4 Blk OVMS Events       484  3204  8192 80136      0
>>>>> 79300  1   8   1%   8/ 0
>>>>> 3FFC9C30    5 Blk OVMS CanRx        476  1996  4096 3240      0
>>>>> 50556  0  23   0%  23/ 0
>>>>> 3FFCAA2C    6 Blk ipc0              424   504  1024 7804
>>>>> 0      0  0  24   0%  24/ 0
>>>>> 3FFCB030    7 Blk ipc1              428   524 1024     120
>>>>> 0      0  1  24   0%  24/ 0
>>>>> *3FFCCEA0   10 Rdy IDLE0             412   508 1024       0
>>>>> 0      0  0   0  98%   0/ 0*
>>>>> 3FFCD438   11 Rdy IDLE1             404   580 1024       0
>>>>> 0      0  1   0  97%   0/ 0
>>>>> 3FFCE1D0   12 Blk Tmr Svc           380  1404 3072     124
>>>>> 0      0  0  20   0%  20/ 0
>>>>> 3FFCC308   17 Blk tiT               532  2036 3072     924
>>>>> 0   1040  1  18   0%  18/ 0
>>>>> *3FFD34E0   20 Blk OVMS Cellular     652  2396 4096    5848
>>>>> 0      0  0  20   0%  20/ 0*
>>>>> 3FFD656C   21 Blk wifi              472  2840  3584 38080      0
>>>>> 5632  0  22   1%  22/ 1
>>>>> 3FFE3244   22 Blk OVMS Vehicle      496   496 8192       0
>>>>> 0      0  1  10   0%  10/ 0
>>>>> 3FFE7BD4   23 Rdy OVMS Console      848  2688 10240     356
>>>>> 12100  15960  1   5   1%   5/ 1
>>>>> 3FFEA5A0   24 Blk OVMS NetMan       908  2684 10240     832
>>>>> 0   2152  1   5   0%   5/ 0
>>>>> 3FFEBBDC   25 Blk mdns              504  2200 4096     104
>>>>> 0      4  0   1   0%   1/ 0
>>>>> 3FFEFDC8   26 Blk OVMS FileLog      580  1524 3072      36
>>>>> 0      0  1   2   0%   2/ 0
>>>>> I (118171) cellular: Network Registration status: RegisteredRoaming
>>>>> D (118181) cellular: mux-rx-line #3: +CCLK: "22/03/05,08:22:23+04"
>>>>> D (118181) cellular: mux-rx-line #3: +CSQ: 24,0
>>>>> D (118181) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>> Hologram",0
>>>>> I (118181) cellular: Network Provider is: vodafone.de Hologram
>>>>> D (119151) cellular: State transition NetWait => NetStart
>>>>> I (119151) cellular: State: Enter NetStart state
>>>>> D (120151) cellular: Netstart
>>>>> AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
>>>>> V (120191) gsm-mux: ProcessFrame(CHAN=0, ADDR=01, CTRL=ef, FCS=79,
>>>>> LEN=11)
>>>>> V (120201) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=fb,
>>>>> LEN=24)
>>>>> D (120201) cellular: mux-rx-line #2: CONNECT 115200
>>>>> *I (120201) cellular: PPP Connection is ready to start*
>>>>> V (120751) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56,
>>>>> LEN=20)
>>>>> OVMS# mo ta
>>>>> 44544  0  22   0%  22/ 0
>>>>> 3FFC2BD8    2 Blk OVMS DukTape      500  9252 12288     284      0
>>>>> 524308  1   5   1%   5/ 0
>>>>> 0      0  0  20   0%  20/ 0
>>>>> 3FFC6B38    4 Blk OVMS Events       484  3204  8192 80280      0
>>>>> 79680  1   8   1%   8/ 0
>>>>> 50556  0  23   0%  23/ 0
>>>>> 0      0  0  24   0%  24/ 0
>>>>> 0      0  1  24   0%  24/ 0
>>>>> 0      0  0   0  79%   0/ 0*
>>>>> 0      0  1   0  95%   0/ 0
>>>>> 3FFCE1D0   12 Blk Tmr Svc           380  1452 3072     124
>>>>> 0      0  0  20   0%  20/ 0
>>>>> 0   1044  1  18   0%  18/ 0
>>>>> *3FFD34E0   20 Rdy OVMS Cellular     876  2716 4096    6116
>>>>> 0  10440  0  20  19%  20/ 0*
>>>>> 5632  0  22   1%  22/ 1
>>>>> 0      0  1  10   0%  10/ 0
>>>>> 12100  15960  1   5   3%   5/ 1
>>>>> 0   2152  1   5   0%   5/ 0
>>>>> 0      4  0   1   0%   1/ 0
>>>>> 0      0  1   2   0%   2/ 0
>>>>> I (122161) housekeeping: System considered stable (RAM:
>>>>> 8b=64256-64760 32b=184 SPI=3362168-3374964)
>>>>> D (122231) ovms-duktape: Duktape: Compacting DukTape memory done
>>>>> in 60 ms
>>>>> I (123151) ovms-server-v2: Send MP-0
>>>>> h1,0,*-OVM-DebugCrash,0,2592000,3.3.001-285-g601f2a70/factory/edge
>>>>> (build idf v3.3.4-848-g1ff5e24b1b Feb 22 2022
>>>>> 20:57:41),1,EarlyCrash,12,12,1,1,abort(),0,,0x4008ddca 0x4008e06
>>>>> 5 0x400e88b8 0x40084176 ,6,Task watchdog,,,0,IDLE0,OVMS WIFI BLE
>>>>> BT cores=2 rev=ESP32/3; MODEM SIM7600
>>>>> I (123361) ovms-server-v2: Incoming Msg: MP-0 h1
>>>>> OVMS# mo ta
>>>>> 44544  0  22   0%  22/ 0
>>>>> 524288  1   5   0%   5/ 0
>>>>> 0      0  0  20   0%  20/ 0
>>>>> 79300  1   8   1%   8/ 0
>>>>> 50556  0  23   0%  23/ 0
>>>>> 0      0  0  24   0%  24/ 0
>>>>> 0      0  1  24   0%  24/ 0
>>>>> 0      0  0   0   0%   0/ 0*
>>>>> 0      0  1   0  95%   0/ 0
>>>>> 0      0  0  20   0%  20/ 0
>>>>> 0  10440  0  20  98%  20/ 0*
>>>>> 5632  0  22   1%  22/ 1
>>>>> 0      0  1  10   0%  10/ 0
>>>>> 3FFE7BD4   23 Rdy OVMS Console      880  2688 10240     356
>>>>> 12100  15960  1   5   4%   5/ 1
>>>>> 0   2152  1   5   0%   5/ 0
>>>>> 0      4  0   1   0%   1/ 0
>>>>> 0      0  1   2   0%   2/ 0
>>>>> OVMS# E (181151) task_wdt: Task watchdog got triggered. The
>>>>> following tasks did not reset the watchdog in time:
>>>>> E (181151) task_wdt:  - IDLE0 (CPU 0)
>>>>> E (181151) task_wdt: Tasks currently running:
>>>>> E (181151) task_wdt: CPU 0: Tmr Svc
>>>>> E (181151) task_wdt: CPU 1: IDLE1
>>>>> E (181151) task_wdt: Aborting.
>>>>> No other log messages.
>>>>> Am 04.03.22 um 17:08 schrieb Jeff Anton:
>>>>>> I woke from sleep thinking "interrupt storm."
>>>>>> Craig's observation makes me wonder... Does the gps system
>>>>>> produce interrupts which are not handled properly when gps is
>>>>>> turned off. Unhandled interrupts might get constantly repeated
>>>>>> causing the IDLE tasks to starve?
>>>>> I think that may be the case. Maybe the NMEA MUX channel gets
>>>>> continuous input from the 7600 when GPS is disabled?
>>>>> Regards,
>>>>> Michael
>>>>> Am 04.03.22 um 23:15 schrieb Craig Leres:
>>>>>> One more data point; I turned GPS off on my dev module (v3.1
>>>>>> board with a sim7600A running 3.3.001-285-g601f2a70-dirty) and it
>>>>>> started crashing.
>>>>>> Has anyone outside the US tried this?
>>>>>>         Craig
>>>>>> ice 12 % ./backtrace.sh 0x400891af:0x3ffb0690
>>>>>> 0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
>>>>>> + xtensa-esp32-elf-addr2line -e build/ovms3.elf
>>>>>> 0x400891af:0x3ffb0690 0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0
>>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
>>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
>>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
>>>>>> # esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c
>>>>>>     733
>>>>>>     734 void _esp_error_check_failed_without_abort(esp_err_t rc,
>>>>>> const char *file, int line, const char *function, const char
>>>>>> *expression)
>>>>>>     735 {
>>>>>>     736
>>>>>> esp_error_check_failed_print("ESP_ERROR_CHECK_WITHOUT_ABORT", rc,
>>>>>> file, line, function, expression);
>>>>>>     737 }
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220306/0d83c4d6/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220306/0d83c4d6/attachment-0001.sig>
