[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Sun Mar 6 22:28:46 HKT 2022
Nice catch. I had reviewed that code section this afternoon, but missed it.
Shall we make a 3.3.002 and push it to EAP?
> On 6 Mar 2022, at 5:58 PM, Michael Balzer <dexter at expeedo.de> wrote:
>  I've found & fixed the bug: there was an endless loop in modem::IncomingMuxData() when the NMEA channel had not been created.
>https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/a6e5b9ab957ab72f56740d6fd4ba484fe1691f80
> Am 05.03.22 um 11:21 schrieb Michael Balzer:
>> I've now tried starting the NMEA channel without actually sending any GPS init commands (also no +CGPS=0).
>> That inhibits the crashes, although apparently no NMEA sentences are coming in. The only communication on MUX channel 1 (NMEA) are some initial frames:
>> balzer at leela:~/ovms/v3> grep -A1 CHAN=1 minicom.log
>> V (26168) gsm-mux: ProcessFrame(CHAN=1, ADDR=07, CTRL=73, FCS=15, LEN=6)
>> I (26168) gsm-mux: Channel #1 is open
>> V (32568) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56, LEN=20)
>> V (32568) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=d1, LEN=20)
>> V (32938) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
>> V (32938) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=32, LEN=21)
>> V (36948) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56, LEN=20)
>> V (36948) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=d1, LEN=20)
>> V (38968) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
>> V (38968) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=32, LEN=21)
>> V (42638) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
>> V (42638) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f0, LEN=21)
>> V (44988) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
>> V (44988) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f0, LEN=21)
>> Unrelated to this issue, but possibly to the framing errors: I've also removed the NMEA log filter from modem::StandardLineHandler() and found after normal GPS startup, the NMEA sentences always come in three times via three MUX channels – additionally to channel 1 on channels 3 & 4:
>> V (130148) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
>> D (130148) gsm-nmea: Incoming RMC: $GPRMC,095314.00,A,xxxx.139928,N,xxxx.391626,E,0.0,,050322,0.9,W,A*06
>> V (130158) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
>> D (130158) cellular: mux-rx-line #3: $GPRMC,095314.00,A,xxxx.139928,N,xxxx.391626,E,0.0,,050322,0.9,W,A*06
>> V (130158) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
>> D (130158) cellular: mux-rx-line #4: $GPRMC,095314.00,A,xxxx.139928,N,xxxx.391626,E,0.0,,050322,0.9,W,A*06
>> V (130168) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
>> D (130168) gsm-nmea: Incoming GNS: $GNGNS,095314.00,xxxx.139928,N,xxxx.391626,E,AAN,16,0.7,327.9,47.0,,,V*60
>> V (130178) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
>> D (130178) cellular: mux-rx-line #3: $GNGNS,095314.00,xxxx.139928,N,xxxx.391626,E,AAN,16,0.7,327.9,47.0,,,V*60
>> V (130178) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
>> D (130178) cellular: mux-rx-line #4: $GNGNS,095314.00,xxxx.139928,N,xxxx.391626,E,AAN,16,0.7,327.9,47.0,,,V*60
>> I don't know if that's intended behaviour or can be changed, but I suspect this to add unnecessary load to the serial communication.
>> Am 05.03.22 um 09:02 schrieb Michael Balzer:
>>> Another theory: I found Mark's comment in the SIM7600 driver NMEA startup:
>>>   // We need to do this a little differently from the standard, as SIM7600
>>>   // may start GPS on power up, and doesn't like us using CGPS=1,1 when
>>>   // it is already on. So workaround is to first CGPS=0.
>>> IOW, the SIM7600 may have GPS enabled by default, possibly also sending NMEA sentences, if not explicitly switched off.
>>> BTW, that also explains the difficulties in booting a 3.3 module from USB… :-/
>>> a) We don't switch off GPS if GPS is disabled.
>>> b) I just tried switching off GPS manually after a GPS-enabled startup, and the modem still continued to send NMEA sentences:
>>> OVMS# cellular cmd AT+CGPS=0
>>> MODEM command has been sent.
>>>>>> D (475190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>> V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1, LEN=31)
>>> V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc, LEN=31)
>>> V (475190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60, LEN=32)
>>> D (475190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
>>> V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25, LEN=32)
>>> V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28, LEN=32)
>>> V (480180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
>>> D (480190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>>>>> OVMS# cellular cmd AT+CGPSNMEA=0
>>> D (505190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>> V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1, LEN=31)
>>> V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc, LEN=31)
>>> V (505190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60, LEN=32)
>>> D (505190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
>>> V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25, LEN=32)
>>> V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28, LEN=32)
>>> V (510180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
>>> D (510190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>>> So without us starting the NMEA subsystem, is it possible these transmissions are still there, filling up some MUX buffer?
>>> Am 05.03.22 um 08:33 schrieb Michael Balzer:
>>>> I've tried to reproduce this with my old 3.2 & hand soldered 3.3 dev module, with different vehicle modules and modem GPS disabled.
>>>> Results:
>>>> - the vehicle module is irrelevant
>>>> - 3.2 (SIM5360E) runs without issues (had this running over night)
>>>> - 3.3 (SIM7600G) consistently crashes by the TWDT within a couple of minutes after modem init
>>>> This is caused by the modem task hogging core 0 as soon as the PPP connection is up:
>>>> I (87161) cellular: Identified cellular modem: SIM7600/Experimental support for SIMCOM SIM7600
>>>> D (87161) cellular: Remove old 'auto' modem driver
>>>> I (87161) cellular: Set modem driver to 'SIM7600'
>>>> I (87161) cellular: State: Enter PoweredOn state
>>>> OVMS# mo ta
>>>> Number of Tasks = 18        Stack:  Now   Max Total    Heap 32-bit SPIRAM C# PRI CPU% BPR/MH
>>>> 3FFAFB88    1 Blk esp_timer         436   708  4096   41648    644  44544  0  22   0%  22/ 0
>>>> 3FFC2BD8    2 Blk OVMS DukTape      500  9252 12288                 188      0 524288  1   5   0%   5/ 0
>>>> 3FFC46B4    3 Blk eventTask         480  2032  4608     108      0      0  0  20   0%  20/ 0
>>>> 3FFC6B38    4 Blk OVMS Events       484  3204  8192   80136      0  79300  1   8   1%   8/ 0
>>>> 3FFC9C30    5 Blk OVMS CanRx        476  1996  4096    3240      0  50556  0  23   0%  23/ 0
>>>> 3FFCAA2C    6 Blk ipc0              424   504  1024    7804      0      0  0  24   0%  24/ 0
>>>> 3FFCB030    7 Blk ipc1              428   524  1024     120      0      0  1  24   0%  24/ 0
>>>> 3FFCCEA0   10 Rdy IDLE0             412   508  1024       0      0      0  0   0  98%   0/ 0
>>>> 3FFCD438   11 Rdy IDLE1             404   580  1024       0      0      0  1   0  97%   0/ 0
>>>> 3FFCE1D0   12 Blk Tmr Svc           380  1404  3072     124      0      0  0  20   0%  20/ 0
>>>> 3FFCC308   17 Blk tiT               532  2036  3072     924      0   1040  1  18   0%  18/ 0
>>>> 3FFD34E0   20 Blk OVMS Cellular     652  2396  4096                  5848      0      0  0  20   0%  20/ 0
>>>> 3FFD656C   21 Blk wifi              472  2840  3584   38080      0   5632  0  22   1%  22/ 1
>>>> 3FFE3244   22 Blk OVMS Vehicle      496   496  8192                   0      0      0  1  10   0%  10/ 0
>>>> 3FFE7BD4   23 Rdy OVMS Console      848  2688 10240     356  12100  15960  1   5   1%   5/ 1
>>>> 3FFEA5A0   24 Blk OVMS NetMan       908  2684 10240     832      0   2152  1   5   0%   5/ 0
>>>> 3FFEBBDC   25 Blk mdns              504  2200  4096     104      0      4  0   1   0%   1/ 0
>>>> 3FFEFDC8   26 Blk OVMS FileLog      580  1524  3072                  36      0      0  1   2   0%   2/ 0
>>>> I (118171) cellular: Network Registration status: RegisteredRoaming
>>>> D (118181) cellular: mux-rx-line #3: +CCLK: "22/03/05,08:22:23+04"
>>>> D (118181) cellular: mux-rx-line #3: +CSQ: 24,0
>>>> D (118181) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",0
>>>> I (118181) cellular: Network Provider is: vodafone.de Hologram
>>>> D (119151) cellular: State transition NetWait => NetStart
>>>> I (119151) cellular: State: Enter NetStart state
>>>> D (120151) cellular: Netstart             AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
>>>> V (120191) gsm-mux: ProcessFrame(CHAN=0, ADDR=01, CTRL=ef, FCS=79, LEN=11)
>>>> V (120201) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=fb, LEN=24)
>>>> D (120201) cellular: mux-rx-line #2: CONNECT 115200
>>>> I (120201) cellular: PPP Connection is ready to start
>>>> V (120751) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56, LEN=20)
>>>> OVMS# mo ta
>>>> 3FFC2BD8    2 Blk OVMS DukTape      500  9252 12288                 284      0 524308  1   5   1%   5/ 0
>>>> 3FFC6B38    4 Blk OVMS Events       484  3204  8192   80280      0  79680  1   8   1%   8/ 0
>>>> 3FFCCEA0   10 Rdy IDLE0             412   508  1024       0      0      0  0   0  79%   0/ 0
>>>> 3FFCD438   11 Rdy IDLE1             404   580  1024       0      0      0  1   0  95%   0/ 0
>>>> 3FFCE1D0   12 Blk Tmr Svc           380  1452  3072     124      0      0  0  20   0%  20/ 0
>>>> 3FFCC308   17 Blk tiT               532  2036  3072     924      0   1044  1  18   0%  18/ 0
>>>> 3FFD34E0   20 Rdy OVMS Cellular     876  2716  4096                  6116      0  10440  0  20  19%  20/ 0
>>>> 3FFE7BD4   23 Rdy OVMS Console      848  2688 10240     356  12100  15960  1   5   3%   5/ 1
>>>> I (122161) housekeeping: System considered stable (RAM: 8b=64256-64760 32b=184 SPI=3362168-3374964)
>>>> D (122231) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
>>>> I (123151) ovms-server-v2: Send MP-0 h1,0,*-OVM-DebugCrash,0,2592000,3.3.001-285-g601f2a70/factory/edge (build idf v3.3.4-848-g1ff5e24b1b Feb 22 2022 20:57:41),1,EarlyCrash,12,12,1,1,abort(),0,,0x4008ddca 0x4008e06
>>>> 5 0x400e88b8 0x40084176 ,6,Task watchdog,,,0,IDLE0,OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
>>>> I (123361) ovms-server-v2: Incoming Msg: MP-0 h1
>>>> OVMS# mo ta
>>>> 3FFCCEA0   10 Rdy IDLE0             412   508  1024       0      0      0  0   0   0%   0/ 0
>>>> 3FFD34E0   20 Rdy OVMS Cellular     876  2716  4096                  6116      0  10440  0  20  98%  20/ 0
>>>> 3FFE7BD4   23 Rdy OVMS Console      880  2688 10240     356  12100  15960  1   5   4%   5/ 1
>>>> OVMS# E (181151) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
>>>> E (181151) task_wdt:  - IDLE0 (CPU 0)
>>>> E (181151) task_wdt: Tasks currently running:
>>>> E (181151) task_wdt: CPU 0: Tmr Svc
>>>> E (181151) task_wdt: CPU 1: IDLE1
>>>> E (181151) task_wdt: Aborting.
>>>> No other log messages.
>>>> Am 04.03.22 um 17:08 schrieb Jeff Anton:
>>>>> I woke from sleep thinking "interrupt storm."
>>>>> Craig's observation makes me wonder... Does the gps system produce interrupts which are not handled properly when gps is turned off. Unhandled interrupts might get constantly repeated causing the IDLE tasks to starve?
>>>> I think that may be the case. Maybe the NMEA MUX channel gets continuous input from the 7600 when GPS is disabled?
>>>> Regards,
>>>> Michael
>>>> Am 04.03.22 um 23:15 schrieb Craig Leres:
>>>>> One more data point; I turned GPS off on my dev module (v3.1 board with a sim7600A running 3.3.001-285-g601f2a70-dirty) and it started crashing.
>>>>> Has anyone outside the US tried this?
>>>>>         Craig
>>>>> ice 12 % ./backtrace.sh 0x400891af:0x3ffb0690 0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
>>>>> + xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x400891af:0x3ffb0690 0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
>>>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
>>>>> # esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c
>>>>>     733
>>>>>     734 void _esp_error_check_failed_without_abort(esp_err_t rc, const char *file, int line, const char *function, const char *expression)
>>>>>     735 {
>>>>>     736 esp_error_check_failed_print("ESP_ERROR_CHECK_WITHOUT_ABORT", rc, file, line, function, expression);
>>>>>     737 }
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220306/f1359a7e/attachment-0001.htm>
Type: application/octet-stream
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220306/f1359a7e/attachment-0001.obj>
