[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Sat Mar 5 18:21:42 HKT 2022
I've now tried starting the NMEA channel without actually sending any
GPS init commands (also no +CGPS=0).
That inhibits the crashes, although apparently no NMEA sentences are
coming in. The only communication on MUX channel 1 (NMEA) are some
initial frames:
balzer at leela:~/ovms/v3> grep -A1 CHAN=1 minicom.log
V (26168) gsm-mux: ProcessFrame(CHAN=1, ADDR=07, CTRL=73, FCS=15, LEN=6)
I (26168) gsm-mux: Channel #1 is open
V (32568) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56, LEN=20)
V (32568) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=d1, LEN=20)
V (32938) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
V (32938) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=32, LEN=21)
V (36948) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56, LEN=20)
V (36948) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=d1, LEN=20)
V (38968) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
V (38968) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=32, LEN=21)
V (42638) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
V (42638) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f0, LEN=21)
V (44988) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b5, LEN=21)
V (44988) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f0, LEN=21)
Unrelated to this issue, but possibly to the framing errors: I've also
removed the NMEA log filter from modem::StandardLineHandler() and found
after normal GPS startup, the NMEA sentences always come in three times
via three MUX channels – additionally to channel 1 on channels 3 & 4:
V (130148) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
D (130148) gsm-nmea: Incoming RMC:
$GPRMC,095314.00,A,xxxx.139928,N,xxxx.391626,E,0.0,,050322,0.9,W,A*06
V (130158) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
D (130158) cellular: mux-rx-line #3:
V (130158) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
D (130158) cellular: mux-rx-line #4:
V (130168) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
D (130168) gsm-nmea: Incoming GNS:
$GNGNS,095314.00,xxxx.139928,N,xxxx.391626,E,AAN,16,0.7,327.9,47.0,,,V*60
V (130178) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
D (130178) cellular: mux-rx-line #3:
V (130178) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
D (130178) cellular: mux-rx-line #4:
I don't know if that's intended behaviour or can be changed, but I
suspect this to add unnecessary load to the serial communication.
Am 05.03.22 um 09:02 schrieb Michael Balzer:
> Another theory: I found Mark's comment in the SIM7600 driver NMEA startup:
>   // We need to do this a little differently from the standard, as SIM7600
>   // may start GPS on power up, and doesn't like us using CGPS=1,1 when
>   // it is already on. So workaround is to first CGPS=0.
> IOW, the SIM7600 may have GPS enabled by default, possibly also
> sending NMEA sentences, if not explicitly switched off.
> BTW, that also explains the difficulties in booting a 3.3 module from
> USB… :-/
> a) We don't switch off GPS if GPS is disabled.
> b) I just tried switching off GPS manually after a GPS-enabled
> startup, and the modem still continued to send NMEA sentences:
> OVMS# cellular cmd AT+CGPS=0
> MODEM command has been sent.
>> D (475190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
> V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1, LEN=31)
> V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc, LEN=31)
> V (475190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60, LEN=32)
> D (475190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
> V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25, LEN=32)
> V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28, LEN=32)
> V (480180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
> D (480190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
>> OVMS# cellular cmd AT+CGPSNMEA=0
> D (505190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
> V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1, LEN=31)
> V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc, LEN=31)
> V (505190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60, LEN=32)
> D (505190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
> V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25, LEN=32)
> V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28, LEN=32)
> V (510180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
> D (510190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
> So without us starting the NMEA subsystem, is it possible these
> transmissions are still there, filling up some MUX buffer?
> Am 05.03.22 um 08:33 schrieb Michael Balzer:
>> I've tried to reproduce this with my old 3.2 & hand soldered 3.3 dev
>> module, with different vehicle modules and modem GPS disabled.
>> Results:
>> - the vehicle module is irrelevant
>> - 3.2 (SIM5360E) runs without issues (had this running over night)
>> - 3.3 (SIM7600G) consistently crashes by the TWDT within a couple of
>> minutes after modem init
>> This is caused by the modem task hogging core 0 as soon as the PPP
>> connection is up:
>> I (87161) cellular: Identified cellular modem: SIM7600/Experimental
>> support for SIMCOM SIM7600
>> D (87161) cellular: Remove old 'auto' modem driver
>> I (87161) cellular: Set modem driver to 'SIM7600'
>> I (87161) cellular: State: Enter PoweredOn state
>> OVMS# mo ta
>> Number of Tasks = 18        Stack:  Now   Max Total    Heap 32-bit
>> SPIRAM C# PRI CPU% BPR/MH
>> 3FFAFB88    1 Blk esp_timer         436   708  4096   41648 644
>> 44544  0  22   0%  22/ 0
>> 3FFC2BD8    2 Blk OVMS DukTape      500  9252 12288 188      0
>> 524288  1   5   0%   5/ 0
>> 3FFC46B4    3 Blk eventTask         480  2032  4608 108      0
>> 0  0  20   0%  20/ 0
>> 3FFC6B38    4 Blk OVMS Events       484  3204  8192 80136      0
>> 79300  1   8   1%   8/ 0
>> 3FFC9C30    5 Blk OVMS CanRx        476  1996  4096 3240      0
>> 50556  0  23   0%  23/ 0
>> 3FFCAA2C    6 Blk ipc0              424   504  1024 7804      0
>> 0  0  24   0%  24/ 0
>> 3FFCB030    7 Blk ipc1              428   524  1024 120      0
>> 0  1  24   0%  24/ 0
>> *3FFCCEA0   10 Rdy IDLE0             412   508  1024 0      0      0
>> 0   0  98%   0/ 0*
>> 3FFCD438   11 Rdy IDLE1             404   580  1024 0      0      0
>> 1   0  97%   0/ 0
>> 3FFCE1D0   12 Blk Tmr Svc           380  1404  3072 124      0
>> 0  0  20   0%  20/ 0
>> 3FFCC308   17 Blk tiT               532  2036  3072 924      0
>> 1040  1  18   0%  18/ 0
>> *3FFD34E0   20 Blk OVMS Cellular     652  2396  4096 5848      0
>> 0  0  20   0%  20/ 0*
>> 3FFD656C   21 Blk wifi              472  2840  3584 38080      0
>> 5632  0  22   1%  22/ 1
>> 3FFE3244   22 Blk OVMS Vehicle      496   496  8192 0      0      0
>> 1  10   0%  10/ 0
>> 3FFE7BD4   23 Rdy OVMS Console      848  2688 10240     356 12100
>> 15960  1   5   1%   5/ 1
>> 3FFEA5A0   24 Blk OVMS NetMan       908  2684 10240 832      0
>> 2152  1   5   0%   5/ 0
>> 3FFEBBDC   25 Blk mdns              504  2200  4096 104      0
>> 4  0   1   0%   1/ 0
>> 3FFEFDC8   26 Blk OVMS FileLog      580  1524  3072 36      0      0
>> 1   2   0%   2/ 0
>> I (118171) cellular: Network Registration status: RegisteredRoaming
>> D (118181) cellular: mux-rx-line #3: +CCLK: "22/03/05,08:22:23+04"
>> D (118181) cellular: mux-rx-line #3: +CSQ: 24,0
>> D (118181) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",0
>> I (118181) cellular: Network Provider is: vodafone.de Hologram
>> D (119151) cellular: State transition NetWait => NetStart
>> I (119151) cellular: State: Enter NetStart state
>> D (120151) cellular: Netstart
>> AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
>> V (120191) gsm-mux: ProcessFrame(CHAN=0, ADDR=01, CTRL=ef, FCS=79,
>> LEN=11)
>> V (120201) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=fb,
>> LEN=24)
>> D (120201) cellular: mux-rx-line #2: CONNECT 115200
>> *I (120201) cellular: PPP Connection is ready to start*
>> V (120751) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56,
>> LEN=20)
>> OVMS# mo ta
>> 44544  0  22   0%  22/ 0
>> 3FFC2BD8    2 Blk OVMS DukTape      500  9252 12288 284      0
>> 524308  1   5   1%   5/ 0
>> 0  0  20   0%  20/ 0
>> 3FFC6B38    4 Blk OVMS Events       484  3204  8192 80280      0
>> 79680  1   8   1%   8/ 0
>> 50556  0  23   0%  23/ 0
>> 0  0  24   0%  24/ 0
>> 0  1  24   0%  24/ 0
>> 0   0  79%   0/ 0*
>> 1   0  95%   0/ 0
>> 3FFCE1D0   12 Blk Tmr Svc           380  1452  3072 124      0
>> 0  0  20   0%  20/ 0
>> 1044  1  18   0%  18/ 0
>> *3FFD34E0   20 Rdy OVMS Cellular     876  2716  4096 6116      0
>> 10440  0  20  19%  20/ 0*
>> 5632  0  22   1%  22/ 1
>> 1  10   0%  10/ 0
>> 15960  1   5   3%   5/ 1
>> 2152  1   5   0%   5/ 0
>> 4  0   1   0%   1/ 0
>> 1   2   0%   2/ 0
>> I (122161) housekeeping: System considered stable (RAM:
>> 8b=64256-64760 32b=184 SPI=3362168-3374964)
>> D (122231) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
>> I (123151) ovms-server-v2: Send MP-0
>> h1,0,*-OVM-DebugCrash,0,2592000,3.3.001-285-g601f2a70/factory/edge
>> (build idf v3.3.4-848-g1ff5e24b1b Feb 22 2022
>> 20:57:41),1,EarlyCrash,12,12,1,1,abort(),0,,0x4008ddca 0x4008e06
>> 5 0x400e88b8 0x40084176 ,6,Task watchdog,,,0,IDLE0,OVMS WIFI BLE BT
>> cores=2 rev=ESP32/3; MODEM SIM7600
>> I (123361) ovms-server-v2: Incoming Msg: MP-0 h1
>> OVMS# mo ta
>> 44544  0  22   0%  22/ 0
>> 524288  1   5   0%   5/ 0
>> 0  0  20   0%  20/ 0
>> 79300  1   8   1%   8/ 0
>> 50556  0  23   0%  23/ 0
>> 0  0  24   0%  24/ 0
>> 0  1  24   0%  24/ 0
>> 0   0   0%   0/ 0*
>> 1   0  95%   0/ 0
>> 0  0  20   0%  20/ 0
>> 1044  1  18   0%  18/ 0
>> 10440  0  20  98%  20/ 0*
>> 5632  0  22   1%  22/ 1
>> 1  10   0%  10/ 0
>> 3FFE7BD4   23 Rdy OVMS Console      880  2688 10240     356 12100
>> 15960  1   5   4%   5/ 1
>> 2152  1   5   0%   5/ 0
>> 4  0   1   0%   1/ 0
>> 1   2   0%   2/ 0
>> OVMS# E (181151) task_wdt: Task watchdog got triggered. The following
>> tasks did not reset the watchdog in time:
>> E (181151) task_wdt:  - IDLE0 (CPU 0)
>> E (181151) task_wdt: Tasks currently running:
>> E (181151) task_wdt: CPU 0: Tmr Svc
>> E (181151) task_wdt: CPU 1: IDLE1
>> E (181151) task_wdt: Aborting.
>> No other log messages.
>> Am 04.03.22 um 17:08 schrieb Jeff Anton:
>>> I woke from sleep thinking "interrupt storm."
>>> Craig's observation makes me wonder... Does the gps system produce
>>> interrupts which are not handled properly when gps is turned off.
>>> Unhandled interrupts might get constantly repeated causing the IDLE
>>> tasks to starve?
>> I think that may be the case. Maybe the NMEA MUX channel gets
>> continuous input from the 7600 when GPS is disabled?
>> Am 04.03.22 um 23:15 schrieb Craig Leres:
>>> One more data point; I turned GPS off on my dev module (v3.1 board
>>> with a sim7600A running 3.3.001-285-g601f2a70-dirty) and it started
>>> crashing.
>>> Has anyone outside the US tried this?
>>>         Craig
>>> ice 12 % ./backtrace.sh 0x400891af:0x3ffb0690 0x40089449:0x3ffb06b0
>>> 0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
>>> + xtensa-esp32-elf-addr2line -e build/ovms3.elf
>>> 0x400891af:0x3ffb0690 0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0
>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
>>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
>>> # esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c
>>>     733
>>>     734 void _esp_error_check_failed_without_abort(esp_err_t rc,
>>> const char *file, int line, const char *function, const char
>>> *expression)
>>>     735 {
>>>     736
>>> esp_error_check_failed_print("ESP_ERROR_CHECK_WITHOUT_ABORT", rc,
>>> file, line, function, expression);
>>>     737 }
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220305/954d6bd6/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220305/954d6bd6/attachment-0001.sig>
