[Ovmsdev] Repeated WDT crashes after upgrade to 3.3 with 4G
Sat Mar 5 16:02:43 HKT 2022
Another theory: I found Mark's comment in the SIM7600 driver NMEA startup:
// We need to do this a little differently from the standard, as SIM7600
// may start GPS on power up, and doesn't like us using CGPS=1,1 when
// it is already on. So workaround is to first CGPS=0.
IOW, the SIM7600 may have GPS enabled by default, possibly also sending
NMEA sentences, if not explicitly switched off.
BTW, that also explains the difficulties in booting a 3.3 module from
USB… :-/
a) We don't switch off GPS if GPS is disabled.
b) I just tried switching off GPS manually after a GPS-enabled startup,
and the modem still continued to send NMEA sentences:
OVMS# cellular cmd AT+CGPS=0
MODEM command has been sent.
D (475190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1, LEN=31)
V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc, LEN=31)
V (475190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60, LEN=32)
D (475190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
V (475190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25, LEN=32)
V (475190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28, LEN=32)
V (480180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
D (480190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
OVMS# cellular cmd AT+CGPSNMEA=0
D (505190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=c1, LEN=31)
V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=cc, LEN=31)
V (505190) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=60, LEN=32)
D (505190) gsm-nmea: Incoming GNS: $GNGNS,,,,,,NNN,,,,,,*1D
V (505190) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=25, LEN=32)
V (505190) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=28, LEN=32)
V (510180) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
D (510190) gsm-nmea: Incoming RMC: $GPRMC,,V,,,,,,,,,,N*53
So without us starting the NMEA subsystem, is it possible these
transmissions are still there, filling up some MUX buffer?
Am 05.03.22 um 08:33 schrieb Michael Balzer:
> I've tried to reproduce this with my old 3.2 & hand soldered 3.3 dev
> module, with different vehicle modules and modem GPS disabled.
> Results:
> - the vehicle module is irrelevant
> - 3.2 (SIM5360E) runs without issues (had this running over night)
> - 3.3 (SIM7600G) consistently crashes by the TWDT within a couple of
> minutes after modem init
> This is caused by the modem task hogging core 0 as soon as the PPP
> connection is up:
> I (87161) cellular: Identified cellular modem: SIM7600/Experimental
> support for SIMCOM SIM7600
> D (87161) cellular: Remove old 'auto' modem driver
> I (87161) cellular: Set modem driver to 'SIM7600'
> I (87161) cellular: State: Enter PoweredOn state
> OVMS# mo ta
> Number of Tasks = 18 Stack: Now Max Total Heap 32-bit
> SPIRAM C# PRI CPU% BPR/MH
> 3FFAFB88 1 Blk esp_timer 436 708 4096 41648 644
> 44544 0 22 0% 22/ 0
> 3FFC2BD8 2 Blk OVMS DukTape 500 9252 12288 188 0 524288
> 1 5 0% 5/ 0
> 3FFC46B4 3 Blk eventTask 480 2032 4608 108 0 0
> 0 20 0% 20/ 0
> 3FFC6B38 4 Blk OVMS Events 484 3204 8192 80136 0 79300
> 1 8 1% 8/ 0
> 3FFC9C30 5 Blk OVMS CanRx 476 1996 4096 3240 0 50556
> 0 23 0% 23/ 0
> 3FFCAA2C 6 Blk ipc0 424 504 1024 7804 0 0
> 0 24 0% 24/ 0
> 3FFCB030 7 Blk ipc1 428 524 1024 120 0 0
> 1 24 0% 24/ 0
> *3FFCCEA0 10 Rdy IDLE0 412 508 1024 0 0 0
> 0 0 98% 0/ 0*
> 3FFCD438 11 Rdy IDLE1 404 580 1024 0 0 0
> 1 0 97% 0/ 0
> 3FFCE1D0 12 Blk Tmr Svc 380 1404 3072 124 0 0
> 0 20 0% 20/ 0
> 3FFCC308 17 Blk tiT 532 2036 3072 924 0 1040
> 1 18 0% 18/ 0
> *3FFD34E0 20 Blk OVMS Cellular 652 2396 4096 5848 0
> 0 0 20 0% 20/ 0*
> 3FFD656C 21 Blk wifi 472 2840 3584 38080 0 5632
> 0 22 1% 22/ 1
> 3FFE3244 22 Blk OVMS Vehicle 496 496 8192 0 0 0
> 1 10 0% 10/ 0
> 3FFE7BD4 23 Rdy OVMS Console 848 2688 10240 356 12100
> 15960 1 5 1% 5/ 1
> 3FFEA5A0 24 Blk OVMS NetMan 908 2684 10240 832 0 2152
> 1 5 0% 5/ 0
> 3FFEBBDC 25 Blk mdns 504 2200 4096 104 0 4
> 0 1 0% 1/ 0
> 3FFEFDC8 26 Blk OVMS FileLog 580 1524 3072 36 0 0
> 1 2 0% 2/ 0
> I (118171) cellular: Network Registration status: RegisteredRoaming
> D (118181) cellular: mux-rx-line #3: +CCLK: "22/03/05,08:22:23+04"
> D (118181) cellular: mux-rx-line #3: +CSQ: 24,0
> D (118181) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",0
> I (118181) cellular: Network Provider is: vodafone.de Hologram
> D (119151) cellular: State transition NetWait => NetStart
> I (119151) cellular: State: Enter NetStart state
> D (120151) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
> V (120191) gsm-mux: ProcessFrame(CHAN=0, ADDR=01, CTRL=ef, FCS=79, LEN=11)
> V (120201) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=fb, LEN=24)
> D (120201) cellular: mux-rx-line #2: CONNECT 115200
> *I (120201) cellular: PPP Connection is ready to start*
> V (120751) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=56, LEN=20)
> OVMS# mo ta
> 44544 0 22 0% 22/ 0
> 3FFC2BD8 2 Blk OVMS DukTape 500 9252 12288 284 0 524308
> 1 5 1% 5/ 0
> 0 20 0% 20/ 0
> 3FFC6B38 4 Blk OVMS Events 484 3204 8192 80280 0 79680
> 1 8 1% 8/ 0
> 0 23 0% 23/ 0
> 0 24 0% 24/ 0
> 1 24 0% 24/ 0
> 0 0 79% 0/ 0*
> 1 0 95% 0/ 0
> 3FFCE1D0 12 Blk Tmr Svc 380 1452 3072 124 0 0
> 0 20 0% 20/ 0
> 3FFCC308 17 Blk tiT 532 2036 3072 924 0 1044
> 1 18 0% 18/ 0
> *3FFD34E0 20 Rdy OVMS Cellular 876 2716 4096 6116 0
> 10440 0 20 19% 20/ 0*
> 0 22 1% 22/ 1
> 1 10 0% 10/ 0
> 15960 1 5 3% 5/ 1
> 1 5 0% 5/ 0
> 0 1 0% 1/ 0
> 1 2 0% 2/ 0
> I (122161) housekeeping: System considered stable (RAM: 8b=64256-64760
> 32b=184 SPI=3362168-3374964)
> D (122231) ovms-duktape: Duktape: Compacting DukTape memory done in 60 ms
> I (123151) ovms-server-v2: Send MP-0
> h1,0,*-OVM-DebugCrash,0,2592000,3.3.001-285-g601f2a70/factory/edge
> (build idf v3.3.4-848-g1ff5e24b1b Feb 22 2022
> 20:57:41),1,EarlyCrash,12,12,1,1,abort(),0,,0x4008ddca 0x4008e06
> 5 0x400e88b8 0x40084176 ,6,Task watchdog,,,0,IDLE0,OVMS WIFI BLE BT
> cores=2 rev=ESP32/3; MODEM SIM7600
> I (123361) ovms-server-v2: Incoming Msg: MP-0 h1
> OVMS# mo ta
> 44544 0 22 0% 22/ 0
> 1 5 0% 5/ 0
> 0 20 0% 20/ 0
> 1 8 1% 8/ 0
> 0 23 0% 23/ 0
> 0 24 0% 24/ 0
> 1 24 0% 24/ 0
> 0 0 0% 0/ 0*
> 1 0 95% 0/ 0
> 0 20 0% 20/ 0
> 1 18 0% 18/ 0
> 10440 0 20 98% 20/ 0*
> 0 22 1% 22/ 1
> 1 10 0% 10/ 0
> 3FFE7BD4 23 Rdy OVMS Console 880 2688 10240 356 12100
> 15960 1 5 4% 5/ 1
> 1 5 0% 5/ 0
> 0 1 0% 1/ 0
> 1 2 0% 2/ 0
> OVMS# E (181151) task_wdt: Task watchdog got triggered. The following
> tasks did not reset the watchdog in time:
> E (181151) task_wdt: - IDLE0 (CPU 0)
> E (181151) task_wdt: Tasks currently running:
> E (181151) task_wdt: CPU 0: Tmr Svc
> E (181151) task_wdt: CPU 1: IDLE1
> E (181151) task_wdt: Aborting.
> No other log messages.
> Am 04.03.22 um 17:08 schrieb Jeff Anton:
>> I woke from sleep thinking "interrupt storm."
>> Craig's observation makes me wonder... Does the gps system produce
>> interrupts which are not handled properly when gps is turned off.
>> Unhandled interrupts might get constantly repeated causing the IDLE
>> tasks to starve?
> I think that may be the case. Maybe the NMEA MUX channel gets
> continuous input from the 7600 when GPS is disabled?
> Am 04.03.22 um 23:15 schrieb Craig Leres:
>> One more data point; I turned GPS off on my dev module (v3.1 board
>> with a sim7600A running 3.3.001-285-g601f2a70-dirty) and it started
>> crashing.
>> Has anyone outside the US tried this?
>> Craig
>> ice 12 % ./backtrace.sh 0x400891af:0x3ffb0690 0x40089449:0x3ffb06b0
>> 0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
>> + xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x400891af:0x3ffb0690
>> 0x40089449:0x3ffb06b0 0x400e8950:0x3ffb06d0 0x40083dde:0x3ffb06f0
>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/esp32/task_wdt.c:274
>> /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/components/freertos/xtensa_vectors.S:1154
>> # esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c
>> 733
>> 734 void _esp_error_check_failed_without_abort(esp_err_t rc,
>> const char *file, int line, const char *function, const char
>> *expression)
>> 735 {
>> 736 esp_error_check_failed_print("ESP_ERROR_CHECK_WITHOUT_ABORT",
>> rc, file, line, function, expression);
>> 737 }
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220305/c31273a3/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220305/c31273a3/attachment-0001.sig>
