[Ovmsdev] Duplicate timer callbacks (was: Branch for-v3.3 network issues)
    Sat Jan 15 18:08:21 HKT 2022
The effect also affects periodic timers, but with a very low frequency.
Extended test & results:
https://github.com/espressif/esp-idf/issues/8234#issuecomment-1013650548
The test run had 3 periodic callback dupes while counting 5912 single
shot callback dupes.
Timer usages in the OVMS aside events are a) the housekeeping per second
timer, from which the monotictime and all standard tickers are derived,
and b) the update ticker for websocket connections.
Vehicles using timers are: Nissan Leaf, Tesla Roadster, Renault Twizy &
VW e-Up. I suggest the respective maintainers check their timer uses for
issues that might result from a duplicate callback.
The event timer already detects duplicate invocations and produces the
log warning (see below) on this.
Regarding the main ticker timer: a duplicate call would cause the
monotonictime counter to get ouf of sync with the actual system time,
but I don't think we would rely on that anywhere. More serious could be
that the per second ticker can run twice on the same second in this
case. But I also don't think we rely on a mininum execution interval as
well -- after all, these are software timers and generally not
guaranteed to run in exactly the interval they are defined to run. We
use the monotonictime for some expiry checks, but none of these should
be so low a single skipped second would matter.
So I don't think the housekeeping ticker running occasionally twice
would cause an issue. I do remember though I had an issue with the
monotonictime behaving strangely once, but I don't recall the exact issue.
The websocket timer is used to schedule data updates, metrics etc., for
the websocket clients. It does not rely on a minimum interval as well,
and the occasional queue overflow events we see there are more probably
caused by a slow network / client.
The vehicle uses of timers may be more critical, as they seem to involve
protocol timing, I recommend to check these ASAP.
A simple strategy to detect duplicate calls on periodic timers can be to
keep & compare the FreeRTOS tick count (xTaskGetTickCount()) of the last
execution in some static variable, if it's the same, skip the run.
For single shot timers, the strategy I've used in the events framework
seems to work: use the timer ID to check the call validity, i.e. define
some timer ID property to mark an invalid call and set that property in
the callback.
Am 14.01.22 um 09:43 schrieb Michael Balzer:
> The effect is also present with SPIRAM disabled (and 64K for
> cpuload_task to fit in internal RAM), and it's even more frequent when
> running in single core mode.
> I haven't reviewed all our timers yet, I'll try to test periodic
> timers first for the effect so we know if these need to be reviewed also.
> Am 14.01.22 um 06:50 schrieb Mark Webb-Johnson:
>> Good to hear this has been confirmed in a test case.
>> Do we need to review all our use of timers? Or have you already checked?
>> I wonder if it is reproducible single core and without SPI RAM?
>> Whether this is another ESP32 hardware bug affecting something else...
>>> On 14 Jan 2022, at 12:03 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Signed PGP part
>>> Everyone,
>>> I've managed to reproduce the effect on a standard ESP32 development
>>> board with a simple test project only involving timers, some
>>> CPU/memory load & wifi networking.
>>> I've tested both the standard esp-idf release 3.3 and the latest
>>> esp-idf release 4.4 (using gcc 8.4) for this, and the effect is
>>> still present.
>>> → Bug report: https://github.com/espressif/esp-idf/issues/8234
>>> Attached are my test projects if you'd like to reproduce this or
>>> improve the test.
>>> I haven't tested periodic timer callbacks yet for the effect. These
>>> are normally designed to run periodically, but if the timing is
>>> important (e.g. on some CAN transmission?), this could cause
>>> erroneous behaviour as well.
>>> Am 30.12.21 um 19:25 schrieb Michael Balzer:
>>>> Followup to…
>>>> Am 26.09.21 um 19:28 schrieb Michael Balzer:
>>>>> If so, my conclusions so far would be:
>>>>> a) we've got a real heap corruption issue that sometimes gets
>>>>> triggered by the test. I've had it twice around the same place,
>>>>> i.e. within the scheduled event processing. I'll check my code.
>>>>> Am 26.09.21 um 18:46 schrieb Craig Leres:
>>>>>> Second crash on the production module, CORRUPT HEAP after ~350
>>>>>> minutes.
>>>>>> OVMS# CORRUPT HEAP: Bad head at 0x3f8adc78. Expected 0xabba1234
>>>>>> got 0x3f8adcc0
>>>>>> abort() was called at PC 0x400844c3 on core 0
>>>> I've found the heap corruption source and a new bug class:
>>>> The corruption was caused by a duplicate free() (here via delete),
>>>> which was basically impossible: it was the free() call for the
>>>> event message for a delayed event delivery. There is exactly one
>>>> producer (OvmsEvents::ScheduleEvent) and exactly one consumer
>>>> (OvmsEvents::SignalScheduledEvent), which is called exactly once --
>>>> when the single shot timer expires.
>>>> In theory. _In reality, the timer callback occasionally gets
>>>> executed twice_. To exclude every possible race condition, I
>>>> enclosed both producer & consumer into a semaphore lock. I then
>>>> changed the code in order to clear the timer payload as soon as
>>>> it's read, and added a test for a NULL payload -- and voila, the
>>>> timer callback now gets occasionally called with a NULL payload,
>>>> which is also impossible as the allocation result is checked in the
>>>> producer.
>>>> I've had no luck reproducing this in a reduced test project, even
>>>> with multiple auto reload timers and distribution over both cores,
>>>> but I still see no other explanation than a bug in the FreeRTOS
>>>> timer service (or the Espressif FreeRTOS multi core adaption). Ah,
>>>> and yes, this occurs on the ESP32/r3 as well.
>>>> You should be able to reproduce the effect using the same event
>>>> test loop as for the Duktape TypeError issue:
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/474#issuecomment-1002687055
>>>> My workaround prevents crashes and outputs a log entry when the
>>>> NULL payload is detected.
>>>> Example log excerpt:
>>>> script eval 'testcnt=0; PubSub.subscribe("usr.testev", function(ev)
>>>> { var ms=Number(ev.substr(11))||10; if (++testcnt % (3*1000/ms) ==
>>>> 0) print(ev + ": " + testcnt); OvmsEvents.Raise("usr.testev."+ms,
>>>> ms); })'
>>>> script eval 'testcnt=0; OvmsEvents.Raise("usr.testev.10")'
>>>> I (13493019) events: ScheduleEvent: creating new timer
>>>> *W (13495919) events: SignalScheduledEvent: duplicate callback
>>>> invocation detected*
>>>> I (13497029) ovms-duk-util: [eval:1:] usr.testev.10: 300
>>>> I (13501109) housekeeping: 2021-12-30 18:12:35 CET (RAM:
>>>> 8b=64448-67004 32b=6472)
>>>> I (13521779) ovms-duk-util: [eval:1:] usr.testev.10: 2100
>>>> I (13525809) ovms-duk-util: [eval:1:] usr.testev.10: 2400
>>>> *W (13527579) events: SignalScheduledEvent: duplicate callback
>>>> invocation detected**
>>>> **W (13527629) events: SignalScheduledEvent: duplicate callback
>>>> I (13529839) ovms-duk-util: [eval:1:] usr.testev.10: 2700
>>>> I (13533329) ovms-server-v2: Incoming Msg: MP-0 AFA
>>>> I (13579149) ovms-duk-util: [eval:1:] usr.testev.10: 6300
>>>> I (13583319) ovms-duk-util: [eval:1:] usr.testev.10: 6600
>>>> *W (13584679) events: SignalScheduledEvent: duplicate callback
>>>> I (13587439) ovms-duk-util: [eval:1:] usr.testev.10: 6900
>>>> I (13591589) ovms-duk-util: [eval:1:] usr.testev.10: 7200
>>>> I (13714299) ovms-duk-util: [eval:1:] usr.testev.10: 16200
>>>> I (13718339) ovms-duk-util: [eval:1:] usr.testev.10: 16500
>>>> *W (13718719) events: SignalScheduledEvent: duplicate callback
>>>> I (13722459) ovms-duk-util: [eval:1:] usr.testev.10: 16800
>>>> I (13726509) ovms-duk-util: [eval:1:] usr.testev.10: 17100
>>>> I (13743149) ovms-duk-util: [eval:1:] usr.testev.10: 18300
>>>> I (13747129) ovms-duk-util: [eval:1:] usr.testev.10: 18600
>>>> *W (13748979) events: SignalScheduledEvent: duplicate callback
>>>> I (13751299) ovms-duk-util: [eval:1:] usr.testev.10: 18900
>>>> I (13755349) ovms-duk-util: [eval:1:] usr.testev.10: 19200
>>>> I (13784029) ovms-duk-util: [eval:1:] usr.testev.10: 21300
>>>> I (13788059) ovms-duk-util: [eval:1:] usr.testev.10: 21600
>>>> *W (13791409) events: SignalScheduledEvent: duplicate callback
>>>> I (13792179) ovms-duk-util: [eval:1:] usr.testev.10: 21900
>>>> I (13796239) ovms-duk-util: [eval:1:] usr.testev.10: 22200
>>>> The bug frequency differs from boot to boot, but as you can see can
>>>> be very high. I've had runs with ~ 1 occurrence every 300.000
>>>> callbacks, and runs like the above with ~ 1 every 3.000 callbacks.
>>>> If this is a common effect with timer callbacks, that may cause
>>>> some of the remaining issues. It's possible this only happens with
>>>> single shot timers, haven't checked our periodic timers yet.
>>>> Any additional input on this is welcome.
>>>> Regards,
>>>> Michael
>>>> OvmsDev mailing list
>>> <test-timer-dupecall.zip>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220115/73773e6e/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220115/73773e6e/attachment-0001.sig>
