[Ovmsdev] Duplicate timer callbacks (was: Branch for-v3.3 network issues)
Fri Jan 14 16:43:24 HKT 2022
The effect is also present with SPIRAM disabled (and 64K for
cpuload_task to fit in internal RAM), and it's even more frequent when
running in single core mode.
I haven't reviewed all our timers yet, I'll try to test periodic timers
first for the effect so we know if these need to be reviewed also.
Am 14.01.22 um 06:50 schrieb Mark Webb-Johnson:
> Good to hear this has been confirmed in a test case.
> Do we need to review all our use of timers? Or have you already checked?
> I wonder if it is reproducible single core and without SPI RAM?
> Whether this is another ESP32 hardware bug affecting something else...
>> On 14 Jan 2022, at 12:03 AM, Michael Balzer <dexter at expeedo.de> wrote:
>> Signed PGP part
>> Everyone,
>> I've managed to reproduce the effect on a standard ESP32 development
>> board with a simple test project only involving timers, some
>> CPU/memory load & wifi networking.
>> I've tested both the standard esp-idf release 3.3 and the latest
>> esp-idf release 4.4 (using gcc 8.4) for this, and the effect is still
>> present.
>> → Bug report: https://github.com/espressif/esp-idf/issues/8234
>> Attached are my test projects if you'd like to reproduce this or
>> improve the test.
>> I haven't tested periodic timer callbacks yet for the effect. These
>> are normally designed to run periodically, but if the timing is
>> important (e.g. on some CAN transmission?), this could cause
>> erroneous behaviour as well.
>> Am 30.12.21 um 19:25 schrieb Michael Balzer:
>>> Followup to…
>>> Am 26.09.21 um 19:28 schrieb Michael Balzer:
>>>> If so, my conclusions so far would be:
>>>> a) we've got a real heap corruption issue that sometimes gets
>>>> triggered by the test. I've had it twice around the same place,
>>>> i.e. within the scheduled event processing. I'll check my code.
>>>> Am 26.09.21 um 18:46 schrieb Craig Leres:
>>>>> Second crash on the production module, CORRUPT HEAP after ~350
>>>>> minutes.
>>>>> OVMS# CORRUPT HEAP: Bad head at 0x3f8adc78. Expected 0xabba1234
>>>>> got 0x3f8adcc0
>>>>> abort() was called at PC 0x400844c3 on core 0
>>> I've found the heap corruption source and a new bug class:
>>> The corruption was caused by a duplicate free() (here via delete),
>>> which was basically impossible: it was the free() call for the event
>>> message for a delayed event delivery. There is exactly one producer
>>> (OvmsEvents::ScheduleEvent) and exactly one consumer
>>> (OvmsEvents::SignalScheduledEvent), which is called exactly once --
>>> when the single shot timer expires.
>>> In theory. _In reality, the timer callback occasionally gets
>>> executed twice_. To exclude every possible race condition, I
>>> enclosed both producer & consumer into a semaphore lock. I then
>>> changed the code in order to clear the timer payload as soon as it's
>>> read, and added a test for a NULL payload -- and voila, the timer
>>> callback now gets occasionally called with a NULL payload, which is
>>> also impossible as the allocation result is checked in the producer.
>>> I've had no luck reproducing this in a reduced test project, even
>>> with multiple auto reload timers and distribution over both cores,
>>> but I still see no other explanation than a bug in the FreeRTOS
>>> timer service (or the Espressif FreeRTOS multi core adaption). Ah,
>>> and yes, this occurs on the ESP32/r3 as well.
>>> You should be able to reproduce the effect using the same event test
>>> loop as for the Duktape TypeError issue:
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/474#issuecomment-1002687055
>>> My workaround prevents crashes and outputs a log entry when the NULL
>>> payload is detected.
>>> Example log excerpt:
>>> script eval 'testcnt=0; PubSub.subscribe("usr.testev", function(ev)
>>> { var ms=Number(ev.substr(11))||10; if (++testcnt % (3*1000/ms) ==
>>> 0) print(ev + ": " + testcnt); OvmsEvents.Raise("usr.testev."+ms,
>>> ms); })'
>>> script eval 'testcnt=0; OvmsEvents.Raise("usr.testev.10")'
>>> I (13493019) events: ScheduleEvent: creating new timer
>>> *W (13495919) events: SignalScheduledEvent: duplicate callback
>>> invocation detected*
>>> I (13497029) ovms-duk-util: [eval:1:] usr.testev.10: 300
>>> I (13501109) housekeeping: 2021-12-30 18:12:35 CET (RAM:
>>> 8b=64448-67004 32b=6472)
>>> I (13521779) ovms-duk-util: [eval:1:] usr.testev.10: 2100
>>> I (13525809) ovms-duk-util: [eval:1:] usr.testev.10: 2400
>>> *W (13527579) events: SignalScheduledEvent: duplicate callback
>>> invocation detected**
>>> **W (13527629) events: SignalScheduledEvent: duplicate callback
>>> I (13529839) ovms-duk-util: [eval:1:] usr.testev.10: 2700
>>> I (13533329) ovms-server-v2: Incoming Msg: MP-0 AFA
>>> I (13579149) ovms-duk-util: [eval:1:] usr.testev.10: 6300
>>> I (13583319) ovms-duk-util: [eval:1:] usr.testev.10: 6600
>>> *W (13584679) events: SignalScheduledEvent: duplicate callback
>>> I (13587439) ovms-duk-util: [eval:1:] usr.testev.10: 6900
>>> I (13591589) ovms-duk-util: [eval:1:] usr.testev.10: 7200
>>> I (13714299) ovms-duk-util: [eval:1:] usr.testev.10: 16200
>>> I (13718339) ovms-duk-util: [eval:1:] usr.testev.10: 16500
>>> *W (13718719) events: SignalScheduledEvent: duplicate callback
>>> I (13722459) ovms-duk-util: [eval:1:] usr.testev.10: 16800
>>> I (13726509) ovms-duk-util: [eval:1:] usr.testev.10: 17100
>>> I (13743149) ovms-duk-util: [eval:1:] usr.testev.10: 18300
>>> I (13747129) ovms-duk-util: [eval:1:] usr.testev.10: 18600
>>> *W (13748979) events: SignalScheduledEvent: duplicate callback
>>> I (13751299) ovms-duk-util: [eval:1:] usr.testev.10: 18900
>>> I (13755349) ovms-duk-util: [eval:1:] usr.testev.10: 19200
>>> I (13784029) ovms-duk-util: [eval:1:] usr.testev.10: 21300
>>> I (13788059) ovms-duk-util: [eval:1:] usr.testev.10: 21600
>>> *W (13791409) events: SignalScheduledEvent: duplicate callback
>>> I (13792179) ovms-duk-util: [eval:1:] usr.testev.10: 21900
>>> I (13796239) ovms-duk-util: [eval:1:] usr.testev.10: 22200
>>> The bug frequency differs from boot to boot, but as you can see can
>>> be very high. I've had runs with ~ 1 occurrence every 300.000
>>> callbacks, and runs like the above with ~ 1 every 3.000 callbacks.
>>> If this is a common effect with timer callbacks, that may cause some
>>> of the remaining issues. It's possible this only happens with single
>>> shot timers, haven't checked our periodic timers yet.
>>> Any additional input on this is welcome.
>> <test-timer-dupecall.zip>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220114/32ff42e1/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220114/32ff42e1/attachment-0001.sig>
