[Ovmsdev] setting up toolchain :-/
Wed Aug 17 23:37:31 HKT 2022
Heiko,
check if you've copied the sdkconfig template
(support/sdkconfig.default.hw31), it seems your config lacks
CONFIG_ESP32_PANIC_CALLBACK=y, possibly more.
Am 17.08.22 um 15:06 schrieb sharkcow:
> Hi all,
> I have been trying to set up the OVMS toolchain on a new Ubuntu PC and
> can't seem to get working (for what it's worth, it's still running on my
> old PC..)
> So what I have done is (following the OVMS v3 Developer Guide):
> * followed the instructions for installation esp-idf v3.3
> * cloned the OVMS esp-idf
> * checked that esp toolchain compiles examples
> * cloned OVMS
> On the first compile, I get the following error:
> Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_boot.cpp: In
> constructor 'Boot::Boot()':
> Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_boot.cpp:313:46:
> error: 'xt_set_error_handler_callback' was not declared in this scope
> xt_set_error_handler_callback(ErrorCallback);
> static member function 'static void Boot::ErrorCallback(XtExcFrame*,
> int, bool)':
> Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_boot.cpp:499:94:
> error: 'esp_task_wdt_get_trigger_tasknames' was not declared in this
> scope
> et_trigger_tasknames(boot_data.wdt_tasknames,
> sizeof(boot_data.wdt_tasknames));
> make[1]: *** [/esp/esp-idf/make/component_wrapper.mk:290: ovms_boot.o]
> Error 1
> make: *** [/esp/esp-idf/make/project.mk:552: component-main-build]
> Error 2
> Any help, please?
> Thanks!
> Heiko
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220817/36c23800/attachment.sig>
