[Ovmsdev] Not processing canbus frames anymore
Fri Apr 15 15:15:03 HKT 2022
That looks like RX was working normally, but all TX was just queued.
Just a thought: is it possible the ESP32CAN TX buffer is sometimes
unavailable on the first frame transmission (or appears to be), not due
to an actual frame blocking the buffer, but due to some kind of init
race condition?
That would lead to esp32can::WriteFrame() returning FAIL causing the
frame to be queued in m_txqueue, but as there is no real TX going on at
that moment, there never will be a TX callback, so the m_txqueue will
grow indefinitely from there on.
Am 14.04.22 um 00:51 schrieb Craig Leres:
> Here is can bus status for my Corvette after 4 run cycles in which it
> was never able to transmit frames on can1.
> Craig
> OVMS# can can1 status
> CAN: can1
> Mode: Active
> Speed: 500000
> DBC: none
> Interrupts: 5115225
> Rx pkt: 4236787
> Rx ovrflw: 0
> Tx pkt: 0
> Tx delays: 30
> Tx ovrflw: 28916
> Tx fails: 840
> Err flags: 0x00000000
> Rx err: 0
> Tx err: 0
> Rx invalid: 0
> Wdg Resets: 0
> Wdg Timer: 3 sec(s)
> Err Resets: 0
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220415/cbf9381e/attachment.sig>
