[Ovmsdev] Not processing canbus frames anymore
    Simon Ehlen
    ovms at highteq.de
    Tue Apr  5 13:45:07 HKT 2022
On 4/4/22 23:05, Craig Leres wrote:
> Which vehicle type are you using?
My vehicle type is a Ford Focus electric, the module is still in the early stages of development.
> What I see is that any version I boot works for a little while.
> But after some length of time, the canbus stops working and
> I get flatbed  alerts because the module does not detect that the car is running.
That's how it is for me, too. I have read-only access to the CAN buses without additional polling. After some time I notice that the values are no longer updated, if I then look at the bus with 'can can2 status', I see that neither interrupts nor packets come in, although the bus is definitely still active. Either a module reset or a restart of the bus let the messages flow again.
 On which bus do you have the problem? So far I could only observe this on CAN2 and CAN3. CAN1 was not stalled as far as I can tell.
 Kind regards,
Simon
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220405/31180e5c/attachment.htm>
