[Ovmsdev] Update zlib to version 1.2.12
Sat Apr 2 21:16:22 HKT 2022
Everyone,
I've just updated our zlib clone (https://github.com/openvehicles/zlib)
to version 1.2.12, fixing a serious security issue (out of bounds access
by extracting malicious ZIP data).
To follow you need to do…
git submodule update --recursive
…after your next pull/fetch.
From https://www.zlib.net/:
> Version 1.2.12 has these key improvements over 1.2.11:
> * Fix a deflate bug when using theZ_FIXEDstrategy that can result in
> out-of-bound accesses.
> * Fix a deflate bug when the window is full indeflate_stored().
> * Speed up CRC-32 computations by a factor of 1.5 to 3.
> * Use the hardware CRC-32 instruction on ARMv8 processors.
> * Speed upcrc32_combine()with powers of/x/tables.
> * Addcrc32_combine_gen()andcrc32_combine_op()for fast combines.
> /Due to the bug fixes, any installations of 1.2.11 should be replaced
> with 1.2.12./
I suggest also checking your other projects for inclusions of zlib.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220402/606e95f8/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220402/606e95f8/attachment.sig>
