[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
    Thu Sep 30 03:48:55 HKT 2021
Steve,
I find it strange this hasn't been detected by other WolfSSL users
before. May be a specific issue of the ESP32 integration or our build
configuration, as you said.
I thought about building WolfSSL on my PC to check that theory, but
dropped that idea due to our time constraint.
Am 29.09.21 um 16:56 schrieb Stephen Casner:
> Michael,
> No, I was sleeping at that hour.
> I can send a question about cross-signing support to WolfSSL support
> if you like.
>                                                          -- Steve
> On Wed, 29 Sep 2021, Michael Balzer wrote:
>> I managed to get wolfSSL debug logs, but don't know how to interpret them. See
>> files attached.
>> The final error seems to be...
>> I (597167) wolfssl: wolfSSL Leaving DoCertificate, return -188
>> I (597177) wolfssl: wolfSSL Leaving DoHandShakeMsgType(), return -188
>> I (597187) wolfssl: wolfSSL Leaving DoHandShakeMsg(), return -188
>> E (597187) wolfssl: wolfSSL error occurred, error = 188 line:15818
>> file:/home/balzer/esp/Open-Vehic
>> E (597197) wolfssl: wolfSSL error occurred, error = 188 line:12507
>> which is
>>      ASN_NO_SIGNER_E     = -188,  /* ASN no signer to confirm failure */
>> I've had a look at the code, I don't see a chance to find the bug within the
>> remaining time.
>> We're 24 hours from expiration. I'll try reverting the Mongoose-WolfSSL
>> commits now. Steve, if you already prepared something in that direction, tell
>> me.
>> Am 29.09.21 um 09:56 schrieb Mark Webb-Johnson:
>>> The cross-signing bit seems to be on the X1 cert provided in the certificate
>>> chain by the server. The one provided there is signed by X3. The problem
>>> comes because a different X1 certificate may be provided as a trusted CA
>>> (and that X1 is self-signed with a long expiration date - 2035). So the
>>> verification process has two possible paths to verify the cert, and the
>>> result depends on which one it chooses (and how it handles a trusted CA cert
>>> supplementing / replacing one provided by the server).
>>> Overall, a mess. I'm fighting this same issue now with a bunch of systems in
>>> my day job, and likely a large part of the Internet is going to start to
>>> fail tomorrow. Particularly a lot of small embedded devices.
>>>> On 29 Sep 2021, at 2:51 PM, Michael Balzer <dexter at expeedo.de
>>>> <mailto:dexter at expeedo.de>> wrote:
>>>> Signed PGP part
>>>> SNI was pretty much intact already, I took care of a remaining Mongoose
>>>> SNI bug in commit 9e4f31249856a67317f99920e47efa34f6734c73 / mongoose
>>>> 8dc9012b57b85e062974fbdec17db30a501bf68f (April 2020).
>>>> I understand the WolfSSL chain management uses a supplied root cert over
>>>> one delivered by the server:
>>>> https://www.wolfssl.com/docs/wolfssl-manual/ch7/ → section 7.3
>>>>> Our problem could be either the wolfssl not recognising the X1 cert, or
>>>>> not supporting the cross-signing arrangement (where there are two paths
>>>>> to verify - the expired X3 and the provided X1). I suspect the latter.
>>>>> In an ideal world, having both X1 and X3 trusted shouldn't be a problem.
>>>> Is cross signing supported at all by WolfSSL? The only place I've found it
>>>> mentioned on wolfssl is this page:
>>>> https://www.wolfssl.com/certificate-chain-chain-trust/
>>>> ...where they say "(We'll cover cross-signing below)" ... but I don't see
>>>> them doing that.
>>>> There is also no commit in their git history regarding cross-signed
>>>> certificates or multiple signatures, so I don't think updating to 4.8.1
>>>> would help.
>>>> The intermediate "R3" has issuer "C=US, O=Internet Security Research
>>>> Group, CN=ISRG Root X1", which should match the new ISRG certificate, but
>>>> not the DST certificate. Maybe that's identified by a fingerprint in the
>>>> signature though (?), and maybe the DST signature comes first and WolfSSL
>>>> just doesn't check further signatures if the first fails?
>>>> I'll look into the code later on, but need to take care of my daily job
>>>> duties first.
>>>> If we can't fix this today, I think our best option is to switch back to
>>>> mbedTLS for the final 3.2 release and try to fix this for the initial 3.3
>>>> release.
>>>> Regards,
>>>> Michael
>>>> Am 29.09.21 um 03:40 schrieb Mark Webb-Johnson:
>>>>> It seems the dexter server returns different certificates depending on
>>>>> the presence of SNI extension in the TSL negotiation. That is pretty
>>>>> normal (where a single IP is serving multiple different websites), but I
>>>>> am not sure if our client library supports that?
>>>>> Without SNI, we get:
>>>>>      Serial Number:
>>>>>      04:ab:25:e5:50:75:49:7b:9f:1b:39:8f:ed:3e:53:44:b4:54
>>>>>      Subject: CN=ns34.expeedo.de <http://ns34.expeedo.de/>
>>>>>       X509v3 Subject Alternative Name:
>>>>>                      DNS:ns34.expeedo.de <http://ns34.expeedo.de/>
>>>>> With SNI dexters-web.de <http://dexters-web.de/>, we get:
>>>>>      Serial Number:
>>>>>      03:be:45:05:45:aa:e3:da:cb:4c:38:ae:f6:90:2f:65:65:e0
>>>>>      Subject: CN=dexter.shopdriver.de <http://dexter.shopdriver.de/>
>>>>>                      DNS:dexter.shopdriver.de
>>>>>      <http://dexter.shopdriver.de/>, DNS:dexters-web.de
>>>>>      <http://dexters-web.de/>, DNS:ovms.dexters-web.de
>>>>>      <http://ovms.dexters-web.de/>, DNS:www.dexter.shopdriver.de
>>>>>      <http://www.dexter.shopdriver.de/>, DNS:www.dexters-web.de
>>>>>      <http://www.dexters-web.de/>
>>>>> Assuming the SNI is set correctly by our library, looking at the
>>>>> dexter.shopdriver.de <http://dexter.shopdriver.de/> chain, we have:
>>>>>      Issuer: C=US, O=Let's Encrypt, CN=R3
>>>>>      Subject: C=US, O=Let's Encrypt, CN=R3
>>>>>      Issuer: C=US, O=Internet Security Research Group, CN=ISRG Root X1
>>>>>      Subject: C=US, O=Internet Security Research Group, CN=ISRG Root X1
>>>>>      Issuer: O=Digital Signature Trust Co., CN=DST Root CA X3
>>>>>      and the components/ovms_tls/trustedca/dst.crt we have is:
>>>>>      Subject: O=Digital Signature Trust Co., CN=DST Root CA X3
>>>>>      (Which expires Sep 30 14:01:15 2021 GMT and was issued just a
>>>>>      year earlier - ridiculous for a root CA)
>>>>> The components/ovms_tls/trustedca/isrg_x1.crt is:
>>>>>      Validity
>>>>>                  Not Before: Jun  4 11:04:38 2015 GMT
>>>>>                  Not After : Jun  4 11:04:38 2035 GMT
>>>>>      sha256WithRSAEncryption 4096 bit
>>>>> There is a later 4.8.1 version of wolfssl (we seem to use 4.7.0 released
>>>>> February 2021). Perhaps we can try to update to that?
>>>>> Mark
>>>>>> On 29 Sep 2021, at 4:11 AM, Michael Balzer <dexter at expeedo.de
>>>>>> Signed PGP part
>>>>>> I can now confirm it's a WolfSSL issue :-(
>>>>>> I've switched back to release 3.2.016, i.e. before changing to
>>>>>> WolfSSL, and the ISRG Root X1 certificate works perfectly, just as it
>>>>>> should.
>>>>>> Steve, I remember you included a config option to enable using
>>>>>> WolfSSL, but cannot find it now. Can you give me a pointer, or did you
>>>>>> remove that option later on?
>>>>>> Am 28.09.21 um 21:53 schrieb Stephen Casner:
>>>>>>> I wonder if we are hitting a key size limit in the WolfSSL code.  I
>>>>>>> know there are configuration parameters in user_settings.h for
>>>>>>> different SHA sizes, but I don't recall one for RSA keys.
>>>>>>>                                                           -- Steve
>>>>>>> On Tue, 28 Sep 2021, Michael Balzer wrote:
>>>>>>>> Still no luck, and getting clueless... :-/
>>>>>>>> Let's Encrypt have a live test server:
>>>>>>>> https://valid-isrgrootx1.letsencrypt.org/
>>>>>>>> Here's a simple test script to access that server:
>>>>>>>> (function(){
>>>>>>>>       HTTP.request({
>>>>>>>>         url:"https://valid-isrgrootx1.letsencrypt.org/",
>>>>>>>>         always: function() { JSON.print(this); }
>>>>>>>> Just copy this into the editor and evaluate.
>>>>>>>> After commenting out the DST certificate from the TLS source, the
>>>>>>>> http request
>>>>>>>> terminates with an SSL error (-3) with installed...
>>>>>>>>    * self-signed ISRG certificate
>>>>>>>>    * cross-signed ISRG / DST root certificate
>>>>>>>>    * LE R3 certificate
>>>>>>>>    * any combination of these three.
>>>>>>>> But the access works immediately after reinstalling the old DST
>>>>>>>> root
>>>>>>>> certificate. There is no DST reference in the chain of that
>>>>>>>> server...
>>>>>>>> I found another ESP32 project -- not using WolfSSL but the esp-idf
>>>>>>>> SSL & MQTT
>>>>>>>> lib --; apparently all they needed to do was to add the very same
>>>>>>>> self-signed
>>>>>>>> ISRG X1 certificate I added:
>>>>>>>> https://github.com/LibreSolar/esp32-edge-firmware/commit/d6b6307cbdb60feb118355fda973eba11d52f8f5
>>>>>>>> So: why would WolfSSL not use the supplied ISRG certificate? Why
>>>>>>>> would it use
>>>>>>>> the DST cert without DST being present as an issuer?
>>>>>>>> The ISRG certificate is the only one having...
>>>>>>>>     signed using      : RSA with SHA-256
>>>>>>>>     RSA key size      : 4096 bits
>>>>>>>> But that would surely be supported by WolfSSL, wouldn't it?
>>>>>>>> I'm running out of ideas, and this really isn't my primary area.
>>>>>>>> Any help is
>>>>>>>> appreciated.
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 28.09.21 um 19:15 schrieb Stephen Casner:
>>>>>>>>> Michael,
>>>>>>>>> Certainly within our code as it stands there is not any
>>>>>>>>> mechanism to
>>>>>>>>> tell the WolfSSL code to adjust its certificate validation
>>>>>>>>> procedure.
>>>>>>>>> The browser certificate substitution that you hypothesize is not
>>>>>>>>> clear
>>>>>>>>> to me.  I would expect the validation to simply follow the
>>>>>>>>> chain.
>>>>>>>>> Steve
>>>>>>>>>> More info:
>>>>>>>>>> All my browsers already have a builtin ISRG X1 certificate
>>>>>>>>>> signed by ISRG
>>>>>>>>>> only, that's the new version:
>>>>>>>>>> https://crt.sh/?id=9314791
>>>>>>>>>> My server still sends the ISRG X1 certificate cross signed /
>>>>>>>>>> issued by DST
>>>>>>>>>> Root CA X3. That's the chain it got from Let's Encrypt (via
>>>>>>>>>> certbot) on
>>>>>>>>>> the
>>>>>>>>>> last renewal (last month!):
>>>>>>>>>> https://crt.sh/?id=3958242236
>>>>>>>>>> Without the DST root cert, WolfSSL then fails validating the
>>>>>>>>>> DST signed X1
>>>>>>>>>> root certificate (I assume):
>>>>>>>>>> My servers will continue sending that chain including the
>>>>>>>>>> outdated root
>>>>>>>>>> cert
>>>>>>>>>> probably until the next renewal, so it's possible having added
>>>>>>>>>> the new X1
>>>>>>>>>> root
>>>>>>>>>> certificate didn't solve the issue.
>>>>>>>>>> The browsers seem to know how to substitute the DST signed
>>>>>>>>>> certificate by
>>>>>>>>>> the
>>>>>>>>>> builtin self-signed (?). Is there a similar option in WolfSSL,
>>>>>>>>>> and do we
>>>>>>>>>> need
>>>>>>>>>> to enable that?
>>>>>>>>>> Steve, can you confirm this, do you know a solution?
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 28.09.21 um 15:34 schrieb Michael Balzer:
>>>>>>>>>>> I've tried adding the intermediate cert ("R3") and then also
>>>>>>>>>>> my site
>>>>>>>>>>> certificate, that didn't help.
>>>>>>>>>>> Only adding the DST cert again fixes the connection.
>>>>>>>>>>> Any ideas?
>>>>>>>>>>> OVMS# tls trust list
>>>>>>>>>>> ISRG Root X1 length 1939 bytes
>>>>>>>>>>> 1939 byte certificate: ISRG Root X1
>>>>>>>>>>>      cert. version     : 3
>>>>>>>>>>>      serial number     :
>>>>>>>>>>> 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00
>>>>>>>>>>>      issuer name       : C=US, O=Internet Security Research
>>>>>>>>>>> Group, CN=ISRG
>>>>>>>>>>> Root
>>>>>>>>>>> X1
>>>>>>>>>>>      subject name      : C=US, O=Internet Security Research
>>>>>>>>>>> Group, CN=ISRG
>>>>>>>>>>> Root
>>>>>>>>>>> X1
>>>>>>>>>>>      issued  on        : 2015-06-04 11:04:38
>>>>>>>>>>>      expires on        : 2035-06-04 11:04:38
>>>>>>>>>>>      basic constraints : CA=true
>>>>>>>>>>>      key usage         : Key Cert Sign, CRL Sign
>>>>>>>>>>> dexter length 1972 bytes
>>>>>>>>>>> 1972 byte certificate: dexter
>>>>>>>>>>>      cert. version     : 3
>>>>>>>>>>>      serial number     :
>>>>>>>>>>> 04:55:1D:F4:27:A3:7D:E9:E4:A8:5C:37:F6:A1:61:87:3C:E5
>>>>>>>>>>>      issuer name       : C=US, O=Let's Encrypt, CN=R3
>>>>>>>>>>>      subject name      : CN=dexter.shopdriver.de
>>>>>>>>>>>      issued  on        : 2021-08-07 05:47:57
>>>>>>>>>>>      expires on        : 2021-11-05 05:47:55
>>>>>>>>>>>      RSA key size      : 2048 bits
>>>>>>>>>>>      basic constraints : CA=false
>>>>>>>>>>>      subject alt name  :dexter.shopdriver.de
>>>>>>>>>>> <http://dexter.shopdriver.de/>,dexters-web.de
>>>>>>>>>>> ovms.dexters-web.de
>>>>>>>>>>> <http://ovms.dexters-web.de/>,www.dexter.shopdriver.de,www.dexters-web.de
>>>>>>>>>>>      key usage         : Digital Signature, Key Encipherment
>>>>>>>>>>>      ext key usage     : TLS Web Server Authentication, TLS
>>>>>>>>>>> Web Client
>>>>>>>>>>> Authentication
>>>>>>>>>>> r3 length 1826 bytes
>>>>>>>>>>> 1826 byte certificate: r3
>>>>>>>>>>>      cert. version     : 3
>>>>>>>>>>>      serial number     :
>>>>>>>>>>> 91:2B:08:4A:CF:0C:18:A7:53:F6:D6:2E:25:A7:5F:5A
>>>>>>>>>>> Group, CN=ISRG
>>>>>>>>>>> Root
>>>>>>>>>>> X1
>>>>>>>>>>>      subject name      : C=US, O=Let's Encrypt, CN=R3
>>>>>>>>>>>      issued  on        : 2020-09-04 00:00:00
>>>>>>>>>>>      expires on        : 2025-09-15 16:00:00
>>>>>>>>>>>      basic constraints : CA=true, max_pathlen=0
>>>>>>>>>>>      key usage         : Digital Signature, Key Cert Sign,
>>>>>>>>>>> CRL Sign
>>>>>>>>>>>      ext key usage     : TLS Web Client Authentication, TLS
>>>>>>>>>>> Web Server
>>>>>>>>>>> Authentication
>>>>>>>>>>> Am 28.09.21 um 15:07 schrieb Michael Balzer:
>>>>>>>>>>>> We would need to bypass / shortcut the "eap" test phase.
>>>>>>>>>>>> But I agree, "master" is stable, I haven't had any issues
>>>>>>>>>>>> or reports,
>>>>>>>>>>>> so I
>>>>>>>>>>>> think we could do that. The FreeRTOS timer issue I'm
>>>>>>>>>>>> working on only
>>>>>>>>>>>> affects very specific conditions, so not necessary to wait
>>>>>>>>>>>> for that.
>>>>>>>>>>>> Should we remove the expiring DST certificate in that
>>>>>>>>>>>> release then?
>>>>>>>>>>>> ...uh oh: just tried removing the DST certificate: the
>>>>>>>>>>>> module cannot
>>>>>>>>>>>> connect to my server anymore...!?
>>>>>>>>>>>> I (490213) ovms-server-v2: Connection
>>>>>>>>>>>> isovms.dexters-web.de:6870
>>>>>>>>>>>> <http://ovms.dexters-web.de:6870/>
>>>>>>>>>>>> TEST1
>>>>>>>>>>>> I (490213) ovms-server-v2: Status: Connecting...
>>>>>>>>>>>> V (490723) ovms-server-v2:
>>>>>>>>>>>> OvmsServerV2MongooseCallback(MG_EV_CONNECT=-3)
>>>>>>>>>>>> W (490723) ovms-server-v2: Connection failed
>>>>>>>>>>>> E (490723) ovms-server-v2: Status: Error: Connection
>>>>>>>>>>>> failed
>>>>>>>>>>>> OvmsServerV2MongooseCallback(MG_EV_CLOSE)
>>>>>>>>>>>> I (490723) ovms-server-v2: Status: Disconnected
>>>>>>>>>>>> Am 28.09.21 um 14:32 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>> Shall we release a full update? The last 3.2?
>>>>>>>>>>>>> What we have now in master seems stable.
>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>> On 28 Sep 2021, at 5:39 PM, Michael
>>>>>>>>>>>>>> Balzer<dexter at expeedo.de>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>     Everyone,
>>>>>>>>>>>>>> the DST root certificate we include (DST Root CA X3)
>>>>>>>>>>>>>> expires on
>>>>>>>>>>>>>> September 30, i.e. in two days.
>>>>>>>>>>>>>> DST Root CA X3 length 1200 bytes
>>>>>>>>>>>>>> 1200 byte certificate: DST Root CA X3
>>>>>>>>>>>>>>      cert. version     : 3
>>>>>>>>>>>>>>      serial number     :
>>>>>>>>>>>>>> 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
>>>>>>>>>>>>>>      issuer name       : O=Digital Signature Trust Co.,
>>>>>>>>>>>>>> CN=DST Root
>>>>>>>>>>>>>> CA X3
>>>>>>>>>>>>>>      subject name      : O=Digital Signature Trust Co.,
>>>>>>>>>>>>>> CN=DST Root
>>>>>>>>>>>>>> CA X3
>>>>>>>>>>>>>>      issued  on        : 2000-09-30 21:12:19
>>>>>>>>>>>>>> *  expires on        : 2021-09-30 14:01:15*
>>>>>>>>>>>>>>      signed using      : RSA with SHA1
>>>>>>>>>>>>>> AFAICT, this root certificate is currently used by the
>>>>>>>>>>>>>> OVMS to
>>>>>>>>>>>>>> validate Let's Encrypt certificates.
>>>>>>>>>>>>>> https://letsencrypt.org/docs/dst-root-ca-x3-expiration-september-2021/
>>>>>>>>>>>>>>      *https://letsencrypt.org/docs/certificate-compatibility/
>>>>>>>>>>>>>> Unfortunately, we missed adding the followup LE root
>>>>>>>>>>>>>> certificate
>>>>>>>>>>>>>> "ISRG
>>>>>>>>>>>>>> Root X1" in time.
>>>>>>>>>>>>>> I've just added that certificate to our builtin
>>>>>>>>>>>>>> certificate
>>>>>>>>>>>>>> repository, but it's too late now to roll out a "main"
>>>>>>>>>>>>>> update in
>>>>>>>>>>>>>> time
>>>>>>>>>>>>>> (isn't it?).
>>>>>>>>>>>>>> So, to prevent losing TLS connectivity with LE
>>>>>>>>>>>>>> servers, users need
>>>>>>>>>>>>>> to
>>>>>>>>>>>>>> manually add the ISRG Root X1 certificate to their TLS
>>>>>>>>>>>>>> repositories.
>>>>>>>>>>>>>> I've added a section on this to our user manual:
>>>>>>>>>>>>>>      *https://docs.openvehicles.com/en/latest/userguide/ssltls.html
>>>>>>>>>>>>>> If users contact you, point them to that page.
>>>>>>>>>>>>>> We probably should also remove the expired DST root
>>>>>>>>>>>>>> certificate
>>>>>>>>>>>>>> after
>>>>>>>>>>>>>> September 30.
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256
>>>>>>>>>>>>>> Ennepetal
>>>>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210929/e2307108/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210929/e2307108/attachment-0001.sig>
