[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
    Thu Sep 30 03:35:25 HKT 2021
Steve,
you're right, typo. I focused on getting it to build with mbedTLS, will
fix that.
Thanks,
Am 29.09.21 um 21:12 schrieb Stephen Casner:
> Michael,
> In 92ea05f4122e52b9c74e05f904c0c23eadbcbbb3 I think there may be
> inconsistencies between CONFIG_MG_SSL_IF_WOLFTLS and
> CONFIG_MG_SSL_IF_WOLFSSL.
>                                                          -- Steve
> On Wed, 29 Sep 2021, Michael Balzer wrote:
>> Everyone,
>> I've added a build configuration so we can easily switch between mbedTLS and
>> WolfSSL. Default is to use mbedTLS for now.
>> I also included removing the almost expired DST root certificate (no point in
>> including that anymore) and the changes to avoid using xTimerIsTimerActive()
>> (have been testing that on both my modules during the last days without issues
>> and with improved stability).
>> I've pushed everything, please have a look at the changes and test the new
>> build.
>> I've already rolled this out into "edge" on my server (3.2.016-299-g3d9cf7f5),
>> if you don't want to build yourself.
>> This would now be release candidate 3.2.017. We need to get this rolled out in
>> "main" ASAP, as module OTA updates will be distributed over 24 hours.
>> Am 29.09.21 um 15:01 schrieb Michael Balzer:
>>> Patch attached. Additionally I had set the boot debug level (early) to info
>>> (may no longer be necessary as I later found that LOG_LOCAL_LEVEL #define in
>>> esp32-crypt.h), and you need to disable log monitoring in the USB console to
>>> prevent garbled output.
>>> I tried WOLFSSL_ALT_CERT_CHAINS but only got crashes with that.
>>> Am 29.09.21 um 14:44 schrieb Mark Webb-Johnson:
>>>> Can you send me the patch to enable debugging, and I will try with 3.3
>>>> branch. I agree that rolling back 3.2 to mbedtls seems sensible for the
>>>> short term.
>>>> Regards, Mark
>>>> P.S. I managed to fix this on another project running an old OpenSSL by
>>>> removing the X3 trusted ca (it had both x1 and x3 trusted). Behavior is
>>>> highly dependent on the library treatment of multiple verification paths
>>>> and trusted ca vs cert chain conflicts.
>>>>> On 29 Sep 2021, at 8:11 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>   I managed to get wolfSSL debug logs, but don't know how to interpret
>>>>> them. See files attached.
>>>>> The final error seems to be...
>>>>> I (597167) wolfssl: wolfSSL Leaving DoCertificate, return -188
>>>>> I (597177) wolfssl: wolfSSL Leaving DoHandShakeMsgType(), return -188
>>>>> I (597187) wolfssl: wolfSSL Leaving DoHandShakeMsg(), return -188
>>>>> E (597187) wolfssl: wolfSSL error occurred, error = 188 line:15818
>>>>> file:/home/balzer/esp/Open-Vehic
>>>>> E (597197) wolfssl: wolfSSL error occurred, error = 188 line:12507
>>>>> which is
>>>>>      ASN_NO_SIGNER_E     = -188,  /* ASN no signer to confirm failure */
>>>>> I've had a look at the code, I don't see a chance to find the bug within
>>>>> the remaining time.
>>>>> We're 24 hours from expiration. I'll try reverting the Mongoose-WolfSSL
>>>>> commits now. Steve, if you already prepared something in that direction,
>>>>> tell me.
>>>>> Regards,
>>>>> Michael
>>>>> Am 29.09.21 um 09:56 schrieb Mark Webb-Johnson:
>>>>>> The cross-signing bit seems to be on the X1 cert provided in the
>>>>>> certificate chain by the server. The one provided there is signed by
>>>>>> X3. The problem comes because a different X1 certificate may be
>>>>>> provided as a trusted CA (and that X1 is self-signed with a long
>>>>>> expiration date - 2035). So the verification process has two possible
>>>>>> paths to verify the cert, and the result depends on which one it
>>>>>> chooses (and how it handles a trusted CA cert supplementing /
>>>>>> replacing one provided by the server).
>>>>>> Overall, a mess. I'm fighting this same issue now with a bunch of
>>>>>> systems in my day job, and likely a large part of the Internet is
>>>>>> going to start to fail tomorrow. Particularly a lot of small embedded
>>>>>> devices.
>>>>>> Regards, Mark.
>>>>>>> On 29 Sep 2021, at 2:51 PM, Michael Balzer <dexter at expeedo.de
>>>>>>> <mailto:dexter at expeedo.de>> wrote:
>>>>>>> Signed PGP part
>>>>>>> SNI was pretty much intact already, I took care of a remaining
>>>>>>> Mongoose SNI bug in commit 9e4f31249856a67317f99920e47efa34f6734c73
>>>>>>> / mongoose 8dc9012b57b85e062974fbdec17db30a501bf68f (April 2020).
>>>>>>> I understand the WolfSSL chain management uses a supplied root cert
>>>>>>> over one delivered by the server:
>>>>>>> https://www.wolfssl.com/docs/wolfssl-manual/ch7/ → section 7.3
>>>>>>>> Our problem could be either the wolfssl not recognising the X1
>>>>>>>> cert, or not supporting the cross-signing arrangement (where there
>>>>>>>> are two paths to verify - the expired X3 and the provided X1). I
>>>>>>>> suspect the latter. In an ideal world, having both X1 and X3
>>>>>>>> trusted shouldn't be a problem.
>>>>>>> Is cross signing supported at all by WolfSSL? The only place I've
>>>>>>> found it mentioned on wolfssl is this page:
>>>>>>> https://www.wolfssl.com/certificate-chain-chain-trust/
>>>>>>> ...where they say "(We'll cover cross-signing below)" ... but I
>>>>>>> don't see them doing that.
>>>>>>> There is also no commit in their git history regarding cross-signed
>>>>>>> certificates or multiple signatures, so I don't think updating to
>>>>>>> 4.8.1 would help.
>>>>>>> The intermediate "R3" has issuer "C=US, O=Internet Security Research
>>>>>>> Group, CN=ISRG Root X1", which should match the new ISRG
>>>>>>> certificate, but not the DST certificate. Maybe that's identified by
>>>>>>> a fingerprint in the signature though (?), and maybe the DST
>>>>>>> signature comes first and WolfSSL just doesn't check further
>>>>>>> signatures if the first fails?
>>>>>>> I'll look into the code later on, but need to take care of my daily
>>>>>>> job duties first.
>>>>>>> If we can't fix this today, I think our best option is to switch
>>>>>>> back to mbedTLS for the final 3.2 release and try to fix this for
>>>>>>> the initial 3.3 release.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 29.09.21 um 03:40 schrieb Mark Webb-Johnson:
>>>>>>>> It seems the dexter server returns different certificates
>>>>>>>> depending on the presence of SNI extension in the TSL negotiation.
>>>>>>>> That is pretty normal (where a single IP is serving multiple
>>>>>>>> different websites), but I am not sure if our client library
>>>>>>>> supports that?
>>>>>>>> Without SNI, we get:
>>>>>>>>      Serial Number:
>>>>>>>>      04:ab:25:e5:50:75:49:7b:9f:1b:39:8f:ed:3e:53:44:b4:54
>>>>>>>>      Subject: CN=ns34.expeedo.de <http://ns34.expeedo.de/>
>>>>>>>>       X509v3 Subject Alternative Name:
>>>>>>>>                      DNS:ns34.expeedo.de <http://ns34.expeedo.de/>
>>>>>>>> With SNI dexters-web.de <http://dexters-web.de/>, we get:
>>>>>>>>      Serial Number:
>>>>>>>>      03:be:45:05:45:aa:e3:da:cb:4c:38:ae:f6:90:2f:65:65:e0
>>>>>>>>      Subject: CN=dexter.shopdriver.de
>>>>>>>> <http://dexter.shopdriver.de/>
>>>>>>>>      DNS:dexter.shopdriver.de <http://dexter.shopdriver.de/>,
>>>>>>>>      DNS:dexters-web.de <http://dexters-web.de/>,
>>>>>>>>      DNS:ovms.dexters-web.de <http://ovms.dexters-web.de/>,
>>>>>>>>      DNS:www.dexter.shopdriver.de
>>>>>>>>      <http://www.dexter.shopdriver.de/>, DNS:www.dexters-web.de
>>>>>>>>      <http://www.dexters-web.de/>
>>>>>>>> Assuming the SNI is set correctly by our library, looking at the
>>>>>>>> dexter.shopdriver.de <http://dexter.shopdriver.de/> chain, we
>>>>>>>> have:
>>>>>>>>      Issuer: C=US, O=Let's Encrypt, CN=R3
>>>>>>>>      Subject: C=US, O=Let's Encrypt, CN=R3
>>>>>>>>      Issuer: C=US, O=Internet Security Research Group, CN=ISRG Root
>>>>>>>> X1
>>>>>>>>      Subject: C=US, O=Internet Security Research Group, CN=ISRG
>>>>>>>>      Root X1
>>>>>>>>      Issuer: O=Digital Signature Trust Co., CN=DST Root CA X3
>>>>>>>>      and the components/ovms_tls/trustedca/dst.crt we have is:
>>>>>>>>      Subject: O=Digital Signature Trust Co., CN=DST Root CA X3
>>>>>>>>      (Which expires Sep 30 14:01:15 2021 GMT and was issued just a
>>>>>>>>      year earlier - ridiculous for a root CA)
>>>>>>>> The components/ovms_tls/trustedca/isrg_x1.crt is:
>>>>>>>>      Root X1
>>>>>>>> X1
>>>>>>>>      Validity
>>>>>>>>                  Not Before: Jun  4 11:04:38 2015 GMT
>>>>>>>>                  Not After : Jun  4 11:04:38 2035 GMT
>>>>>>>>      sha256WithRSAEncryption 4096 bit
>>>>>>>> There is a later 4.8.1 version of wolfssl (we seem to use 4.7.0
>>>>>>>> released February 2021). Perhaps we can try to update to that?
>>>>>>>> Mark
>>>>>>>>> On 29 Sep 2021, at 4:11 AM, Michael Balzer <dexter at expeedo.de
>>>>>>>>> Signed PGP part
>>>>>>>>> I can now confirm it's a WolfSSL issue :-(
>>>>>>>>> I've switched back to release 3.2.016, i.e. before changing to
>>>>>>>>> WolfSSL, and the ISRG Root X1 certificate works perfectly, just
>>>>>>>>> as it should.
>>>>>>>>> Steve, I remember you included a config option to enable using
>>>>>>>>> WolfSSL, but cannot find it now. Can you give me a pointer, or
>>>>>>>>> did you remove that option later on?
>>>>>>>>> Am 28.09.21 um 21:53 schrieb Stephen Casner:
>>>>>>>>>> I wonder if we are hitting a key size limit in the WolfSSL
>>>>>>>>>> code.  I
>>>>>>>>>> know there are configuration parameters in user_settings.h for
>>>>>>>>>> different SHA sizes, but I don't recall one for RSA keys.
>>>>>>>>>> Steve
>>>>>>>>>> On Tue, 28 Sep 2021, Michael Balzer wrote:
>>>>>>>>>>> Still no luck, and getting clueless... :-/
>>>>>>>>>>> Let's Encrypt have a live test server:
>>>>>>>>>>> https://valid-isrgrootx1.letsencrypt.org/
>>>>>>>>>>> Here's a simple test script to access that server:
>>>>>>>>>>> (function(){
>>>>>>>>>>>       HTTP.request({
>>>>>>>>>>>         url:"https://valid-isrgrootx1.letsencrypt.org/",
>>>>>>>>>>>         always: function() { JSON.print(this); }
>>>>>>>>>>> Just copy this into the editor and evaluate.
>>>>>>>>>>> After commenting out the DST certificate from the TLS
>>>>>>>>>>> source, the http request
>>>>>>>>>>> terminates with an SSL error (-3) with installed...
>>>>>>>>>>>    * self-signed ISRG certificate
>>>>>>>>>>>    * cross-signed ISRG / DST root certificate
>>>>>>>>>>>    * LE R3 certificate
>>>>>>>>>>>    * any combination of these three.
>>>>>>>>>>> But the access works immediately after reinstalling the old
>>>>>>>>>>> DST root
>>>>>>>>>>> certificate. There is no DST reference in the chain of that
>>>>>>>>>>> server...
>>>>>>>>>>> I found another ESP32 project -- not using WolfSSL but the
>>>>>>>>>>> esp-idf SSL & MQTT
>>>>>>>>>>> lib --; apparently all they needed to do was to add the very
>>>>>>>>>>> same self-signed
>>>>>>>>>>> ISRG X1 certificate I added:
>>>>>>>>>>> https://github.com/LibreSolar/esp32-edge-firmware/commit/d6b6307cbdb60feb118355fda973eba11d52f8f5
>>>>>>>>>>> So: why would WolfSSL not use the supplied ISRG certificate?
>>>>>>>>>>> Why would it use
>>>>>>>>>>> the DST cert without DST being present as an issuer?
>>>>>>>>>>> The ISRG certificate is the only one having...
>>>>>>>>>>>     signed using      : RSA with SHA-256
>>>>>>>>>>>     RSA key size      : 4096 bits
>>>>>>>>>>> But that would surely be supported by WolfSSL, wouldn't it?
>>>>>>>>>>> I'm running out of ideas, and this really isn't my primary
>>>>>>>>>>> area. Any help is
>>>>>>>>>>> appreciated.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>>>>> Am 28.09.21 um 19:15 schrieb Stephen Casner:
>>>>>>>>>>>> Michael,
>>>>>>>>>>>> Certainly within our code as it stands there is not any
>>>>>>>>>>>> mechanism to
>>>>>>>>>>>> tell the WolfSSL code to adjust its certificate validation
>>>>>>>>>>>> procedure.
>>>>>>>>>>>> The browser certificate substitution that you hypothesize
>>>>>>>>>>>> is not clear
>>>>>>>>>>>> to me.  I would expect the validation to simply follow the
>>>>>>>>>>>> chain.
>>>>>>>>>>>> Steve
>>>>>>>>>>>>> More info:
>>>>>>>>>>>>> All my browsers already have a builtin ISRG X1
>>>>>>>>>>>>> certificate signed by ISRG
>>>>>>>>>>>>> only, that's the new version:
>>>>>>>>>>>>> https://crt.sh/?id=9314791
>>>>>>>>>>>>> My server still sends the ISRG X1 certificate cross
>>>>>>>>>>>>> signed / issued by DST
>>>>>>>>>>>>> Root CA X3. That's the chain it got from Let's Encrypt
>>>>>>>>>>>>> (via certbot) on
>>>>>>>>>>>>> the
>>>>>>>>>>>>> last renewal (last month!):
>>>>>>>>>>>>> https://crt.sh/?id=3958242236
>>>>>>>>>>>>> Without the DST root cert, WolfSSL then fails validating
>>>>>>>>>>>>> the DST signed X1
>>>>>>>>>>>>> root certificate (I assume):
>>>>>>>>>>>>> My servers will continue sending that chain including
>>>>>>>>>>>>> the outdated root
>>>>>>>>>>>>> cert
>>>>>>>>>>>>> probably until the next renewal, so it's possible having
>>>>>>>>>>>>> added the new X1
>>>>>>>>>>>>> root
>>>>>>>>>>>>> certificate didn't solve the issue.
>>>>>>>>>>>>> The browsers seem to know how to substitute the DST
>>>>>>>>>>>>> signed certificate by
>>>>>>>>>>>>> the
>>>>>>>>>>>>> builtin self-signed (?). Is there a similar option in
>>>>>>>>>>>>> WolfSSL, and do we
>>>>>>>>>>>>> need
>>>>>>>>>>>>> to enable that?
>>>>>>>>>>>>> Steve, can you confirm this, do you know a solution?
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Michael
>>>>>>>>>>>>> Am 28.09.21 um 15:34 schrieb Michael Balzer:
>>>>>>>>>>>>>> I've tried adding the intermediate cert ("R3") and
>>>>>>>>>>>>>> then also my site
>>>>>>>>>>>>>> certificate, that didn't help.
>>>>>>>>>>>>>> Only adding the DST cert again fixes the connection.
>>>>>>>>>>>>>> Any ideas?
>>>>>>>>>>>>>> OVMS# tls trust list
>>>>>>>>>>>>>> ISRG Root X1 length 1939 bytes
>>>>>>>>>>>>>> 1939 byte certificate: ISRG Root X1
>>>>>>>>>>>>>>      cert. version     : 3
>>>>>>>>>>>>>>      serial number     :
>>>>>>>>>>>>>> 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00
>>>>>>>>>>>>>>      issuer name       : C=US, O=Internet Security
>>>>>>>>>>>>>> Root
>>>>>>>>>>>>>> X1
>>>>>>>>>>>>>>      subject name      : C=US, O=Internet Security
>>>>>>>>>>>>>> Root
>>>>>>>>>>>>>> X1
>>>>>>>>>>>>>>      issued  on        : 2015-06-04 11:04:38
>>>>>>>>>>>>>>      expires on        : 2035-06-04 11:04:38
>>>>>>>>>>>>>>      basic constraints : CA=true
>>>>>>>>>>>>>>      key usage         : Key Cert Sign, CRL Sign
>>>>>>>>>>>>>> dexter length 1972 bytes
>>>>>>>>>>>>>> 1972 byte certificate: dexter
>>>>>>>>>>>>>>      cert. version     : 3
>>>>>>>>>>>>>>      serial number     :
>>>>>>>>>>>>>> 04:55:1D:F4:27:A3:7D:E9:E4:A8:5C:37:F6:A1:61:87:3C:E5
>>>>>>>>>>>>>>      issuer name       : C=US, O=Let's Encrypt, CN=R3
>>>>>>>>>>>>>>      subject name      : CN=dexter.shopdriver.de
>>>>>>>>>>>>>>      issued  on        : 2021-08-07 05:47:57
>>>>>>>>>>>>>>      expires on        : 2021-11-05 05:47:55
>>>>>>>>>>>>>>      RSA key size      : 2048 bits
>>>>>>>>>>>>>>      basic constraints : CA=false
>>>>>>>>>>>>>>      subject alt name  :dexter.shopdriver.de
>>>>>>>>>>>>>> <http://dexter.shopdriver.de/>,dexters-web.de
>>>>>>>>>>>>>> ovms.dexters-web.de
>>>>>>>>>>>>>> <http://ovms.dexters-web.de/>,www.dexter.shopdriver.de,www.dexters-web.de
>>>>>>>>>>>>>>      key usage         : Digital Signature, Key
>>>>>>>>>>>>>> Encipherment
>>>>>>>>>>>>>>      ext key usage     : TLS Web Server Authentication,
>>>>>>>>>>>>>> TLS Web Client
>>>>>>>>>>>>>> Authentication
>>>>>>>>>>>>>> r3 length 1826 bytes
>>>>>>>>>>>>>> 1826 byte certificate: r3
>>>>>>>>>>>>>>      cert. version     : 3
>>>>>>>>>>>>>>      serial number     :
>>>>>>>>>>>>>> 91:2B:08:4A:CF:0C:18:A7:53:F6:D6:2E:25:A7:5F:5A
>>>>>>>>>>>>>> Root
>>>>>>>>>>>>>> X1
>>>>>>>>>>>>>>      subject name      : C=US, O=Let's Encrypt, CN=R3
>>>>>>>>>>>>>>      issued  on        : 2020-09-04 00:00:00
>>>>>>>>>>>>>>      expires on        : 2025-09-15 16:00:00
>>>>>>>>>>>>>>      basic constraints : CA=true, max_pathlen=0
>>>>>>>>>>>>>>      key usage         : Digital Signature, Key Cert
>>>>>>>>>>>>>> Sign, CRL Sign
>>>>>>>>>>>>>>      ext key usage     : TLS Web Client Authentication,
>>>>>>>>>>>>>> TLS Web Server
>>>>>>>>>>>>>> Authentication
>>>>>>>>>>>>>> Am 28.09.21 um 15:07 schrieb Michael Balzer:
>>>>>>>>>>>>>>> We would need to bypass / shortcut the "eap" test
>>>>>>>>>>>>>>> phase.
>>>>>>>>>>>>>>> But I agree, "master" is stable, I haven't had any
>>>>>>>>>>>>>>> issues or reports,
>>>>>>>>>>>>>>> so I
>>>>>>>>>>>>>>> think we could do that. The FreeRTOS timer issue I'm
>>>>>>>>>>>>>>> working on only
>>>>>>>>>>>>>>> affects very specific conditions, so not necessary
>>>>>>>>>>>>>>> to wait for that.
>>>>>>>>>>>>>>> Should we remove the expiring DST certificate in
>>>>>>>>>>>>>>> that release then?
>>>>>>>>>>>>>>> ...uh oh: just tried removing the DST certificate:
>>>>>>>>>>>>>>> the module cannot
>>>>>>>>>>>>>>> connect to my server anymore...!?
>>>>>>>>>>>>>>> I (490213) ovms-server-v2: Connection
>>>>>>>>>>>>>>> isovms.dexters-web.de:6870
>>>>>>>>>>>>>>> <http://ovms.dexters-web.de:6870/>
>>>>>>>>>>>>>>> TEST1
>>>>>>>>>>>>>>> I (490213) ovms-server-v2: Status: Connecting...
>>>>>>>>>>>>>>> V (490723) ovms-server-v2:
>>>>>>>>>>>>>>> OvmsServerV2MongooseCallback(MG_EV_CONNECT=-3)
>>>>>>>>>>>>>>> W (490723) ovms-server-v2: Connection failed
>>>>>>>>>>>>>>> E (490723) ovms-server-v2: Status: Error: Connection
>>>>>>>>>>>>>>> failed
>>>>>>>>>>>>>>> OvmsServerV2MongooseCallback(MG_EV_CLOSE)
>>>>>>>>>>>>>>> I (490723) ovms-server-v2: Status: Disconnected
>>>>>>>>>>>>>>> Am 28.09.21 um 14:32 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>>>> Shall we release a full update? The last 3.2?
>>>>>>>>>>>>>>>> What we have now in master seems stable.
>>>>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>>>>> On 28 Sep 2021, at 5:39 PM, Michael
>>>>>>>>>>>>>>>>> Balzer<dexter at expeedo.de>
>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>     Everyone,
>>>>>>>>>>>>>>>>> the DST root certificate we include (DST Root CA
>>>>>>>>>>>>>>>>> X3) expires on
>>>>>>>>>>>>>>>>> September 30, i.e. in two days.
>>>>>>>>>>>>>>>>> DST Root CA X3 length 1200 bytes
>>>>>>>>>>>>>>>>> 1200 byte certificate: DST Root CA X3
>>>>>>>>>>>>>>>>>      cert. version     : 3
>>>>>>>>>>>>>>>>>      serial number     :
>>>>>>>>>>>>>>>>> 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
>>>>>>>>>>>>>>>>>      issuer name       : O=Digital Signature
>>>>>>>>>>>>>>>>> CA X3
>>>>>>>>>>>>>>>>>      subject name      : O=Digital Signature
>>>>>>>>>>>>>>>>> CA X3
>>>>>>>>>>>>>>>>>      issued  on        : 2000-09-30 21:12:19
>>>>>>>>>>>>>>>>> *  expires on        : 2021-09-30 14:01:15*
>>>>>>>>>>>>>>>>>      signed using      : RSA with SHA1
>>>>>>>>>>>>>>>>> AFAICT, this root certificate is currently used
>>>>>>>>>>>>>>>>> by the OVMS to
>>>>>>>>>>>>>>>>> validate Let's Encrypt certificates.
>>>>>>>>>>>>>>>>> https://letsencrypt.org/docs/dst-root-ca-x3-expiration-september-2021/
>>>>>>>>>>>>>>>>>      *https://letsencrypt.org/docs/certificate-compatibility/
>>>>>>>>>>>>>>>>> Unfortunately, we missed adding the followup LE
>>>>>>>>>>>>>>>>> root certificate
>>>>>>>>>>>>>>>>> "ISRG
>>>>>>>>>>>>>>>>> Root X1" in time.
>>>>>>>>>>>>>>>>> I've just added that certificate to our builtin
>>>>>>>>>>>>>>>>> certificate
>>>>>>>>>>>>>>>>> repository, but it's too late now to roll out a
>>>>>>>>>>>>>>>>> "main" update in
>>>>>>>>>>>>>>>>> time
>>>>>>>>>>>>>>>>> (isn't it?).
>>>>>>>>>>>>>>>>> So, to prevent losing TLS connectivity with LE
>>>>>>>>>>>>>>>>> servers, users need
>>>>>>>>>>>>>>>>> to
>>>>>>>>>>>>>>>>> manually add the ISRG Root X1 certificate to
>>>>>>>>>>>>>>>>> their TLS
>>>>>>>>>>>>>>>>> repositories.
>>>>>>>>>>>>>>>>> I've added a section on this to our user manual:
>>>>>>>>>>>>>>>>>      *https://docs.openvehicles.com/en/latest/userguide/ssltls.html
>>>>>>>>>>>>>>>>> If users contact you, point them to that page.
>>>>>>>>>>>>>>>>> We probably should also remove the expired DST
>>>>>>>>>>>>>>>>> root certificate
>>>>>>>>>>>>>>>>> after
>>>>>>>>>>>>>>>>> September 30.
>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256
>>>>>>>>>>>>>>>>> Ennepetal
>>>>>>>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>>>>>>> Ennepetal
>>>>>>>>>>>>>> Ennepetal
>>>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210929/8c657f50/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210929/8c657f50/attachment-0001.sig>
