[Ovmsdev] OVMS firmware release 3.2.017
    Thu Sep 30 00:45:48 HKT 2021
We need to roll out this release directly to "main", "eap" and "edge",
see thread "Urgent TLS root certificate issue (Let's Encrypt)" for details.
I've just pushed the tag and rolled out the new build on dexters-web.de.
Mark, can you please do the same on openvehicles.com?
Changes:
2021-09-29 MB  3.2.017  OTA release
- Added VEHICLE_POLL_TYPE_ROUTINECONTROL to UDS (ISO 14229) service
identifiers list
- MG ZS EV:
   - Moved to 2 car variants architecture: MG EV A (✔ Zombie mode | ❌
GWM authentication | ❌ Poll BCM) and MG EV B (❌ Zombie mode | ✔ GWM
authentication | ✔ Poll BCM)
   - New commands:
       drl [on | off]            Turn on/off daytime running lights
       drlauth [on | off]        (Only for MG EV A) Do BCM
authentication then turn on/off daytime running lights
       auth [all | gwm | bcm]    Authenticate with specified ECU
   - New metrics:
       v.e.headlights
       v.e.cooling
       xmg.v.bat.voltage.vcu
       xmg.v.bat.coolant.temp
       xmg.v.bat.resistance
       xmg.v.bms.cell.voltage.max
       xmg.v.bms.cell.voltage.min
       xmg.v.bms.mainrelay.b
       xmg.v.bms.mainrelay.g
       xmg.v.bms.mainrelay.p
       xmg.v.bms.time
       xmg.v.bat.error
       xmg.v.radiator.fan
       xmg.v.dcdc.load
       xmg.v.vcu.dcdc.mode
       xmg.v.vcu.dcdc.input.current
       xmg.v.vcu.dcdc.input.voltage
       xmg.v.vcu.dcdc.output.current
       xmg.v.vcu.dcdc.output.voltage
       xmg.v.vcu.dcdc.temp
       xmg.v.m.coolant.temp
       xmg.v.m.torque
       xmg.v.ignition.state
   - Modified metrics calculation:
       v.e.charging12v
       v.e.on
       v.m.rpm
       v.m.temp
       v.b.temp
   - Decreased poll intervals for some PIDs for better performance
   - Fixed issue where Features page shows unchecked check box but value
is actually true
   - Added notifications when reaching SOC & Range Limit.
   - Display charge time to reach Full/SOC/Range limit.
   - Display CCS Charging on App.
   - Add new features page to select car's BMS firmware release to
adjust SOC display.
- Zoe: add Kangoo to Renault Zoe vehicle module.
- New vehicle: Maxus eDeliver 3 via OBD-II Port (MED3)
https://docs.openvehicles.com/en/latest/components/vehicle_maxus_edeliver3/docs/index.html
- Maxus eDeliver3: cell volts and temps added to metrics and polling update.
- Maxus eDeliver3: Web interface page added for charging and cell metrics
- Vehicle: emit standard events on changing v.c.timermode
   New events:
     vehicle.charge.timermode.off   -- Vehicle charge timer mode has
been switched off
     vehicle.charge.timermode.on    -- Vehicle charge timer mode has
been switched on
- VW e-Up/OBD: detect charge timer mode
   New metrics:
     xvu.c.limit.soc.max            -- Charge schedule maximum SOC [%]
     xvu.c.limit.soc.min            -- Charge schedule minimum SOC [%]
     xvu.c.timermode.def            -- Charge timer defined & default [bool]
- VW e-Up/OBD: optional BMS auto statistics reset between driving & charging
   New config:
     [xvu] bms.autoreset            -- yes = enable statistics reset,
default no
- VW e-Up/OBD: add MFD range estimation as SOH source, add config option
for SOH source
   New metrics:
     xvu.b.soh.charge               -- SOH based on charge energy sum [%]
     xvu.b.soh.range                -- SOH based on MFD range estimation [%]
   New configs:
     [xvu] bat.soh.source           -- 'charge' (default) or 'range'
[string]
- VW e-Up/OBD: charge time prediction while not charging & full charge
with limit
   New configs:
     [xvu] ctp.maxpower             -- in kW, 0 = unlimited except by
car, used when not charging
     [xvu] ctp.soclimit             -- in %, used as informative limit
w/o OBD connection
- VW e-Up/OBD: charge start notification delay configuration to
accomodate current ramp-up
   New configs:
     [xvu] notify.charge.start.delay       -- in seconds, default 24
- VW e-Up/OBD: polling control for diagnostic/adaptation sessions
   New command:
     xvu polling <status|pause|continue>   -- temporarily pause OBD2 polling
- VW e-Up: added SOC monitoring log
   New configs:
     [xvu] log.socmon.storetime            -- days, 0=off
- VW e-Up: add topping off charge phase support & timer mode change
notification
- VW e-Up/OBD: read ignition state from ECU, support v.e.gear &
v.e.drivemode
     (v.e.gear only on 2020 model)
- New vehicle: Hyundai Ioniq vFL (HIONVFL)
https://docs.openvehicles.com/en/latest/components/vehicle_hyundai_ioniqvfl/docs/index.html
- Webserver: support TLS (https, wss) using self-signed certificates
- New vehicle: Jaguar Ipace (JLRI)
- New commands:
     echo [<text>] […] -- output text
     sleep <seconds> -- pause script execution
- Scripting API: added OvmsVehicle.ObdRequest()
- Vehicle: provide momentary ideal range gain/loss speed as a metric,
     add charge speed to "stat" output, output "stat" charge ETRs in
hh:mm format
   New metric:
     v.b.range.speed                -- Momentary ideal range gain/loss
(charge/discharge) speed [kph]
- Vehicle: emit standard events on changing v.e.gear & v.e.drivemode
   New events:
     vehicle.drivemode.<n>          -- Vehicle drivemode has been set to
profile <n> (vehicle specific)
     vehicle.gear.forward           -- Vehicle has been put in forward gear
     vehicle.gear.neutral           -- Vehicle has been put in neutral gear
     vehicle.gear.reverse           -- Vehicle has been put in reverse gear
- Scripting/Duktape: new heap memory management using fixed amount of
system RAM
   New config:
     [module] duktape.heapsize    -- in KB, default 512, max 1024
   New commands:
     script meminfo               -- output heap memory status (JSON)
   New API calls:
     meminfo()                    -- return heap memory status
- TLS: removed expired DST root certificate, added new ISRG root certificate
     for Let's Encrypt
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210929/fbf7f0df/attachment.sig>
