[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
    Thu Sep 30 00:35:44 HKT 2021
I'll tag this as release 3.2.017 and roll it out directly to "eap" and
"main" now.
In case something's seriously wrong, we can still do a 3.2.018 release
afterwards.
Am 29.09.21 um 15:36 schrieb Michael Balzer:
> Everyone,
> I've added a build configuration so we can easily switch between
> mbedTLS and WolfSSL. Default is to use mbedTLS for now.
> I also included removing the almost expired DST root certificate (no
> point in including that anymore) and the changes to avoid using
> xTimerIsTimerActive() (have been testing that on both my modules
> during the last days without issues and with improved stability).
> I've pushed everything, please have a look at the changes and test the
> new build.
> I've already rolled this out into "edge" on my server
> (3.2.016-299-g3d9cf7f5), if you don't want to build yourself.
> This would now be release candidate 3.2.017. We need to get this
> rolled out in "main" ASAP, as module OTA updates will be distributed
> over 24 hours.
> Am 29.09.21 um 15:01 schrieb Michael Balzer:
>> Patch attached. Additionally I had set the boot debug level (early)
>> to info (may no longer be necessary as I later found that
>> LOG_LOCAL_LEVEL #define in esp32-crypt.h), and you need to disable
>> log monitoring in the USB console to prevent garbled output.
>> I tried WOLFSSL_ALT_CERT_CHAINS but only got crashes with that.
>> Am 29.09.21 um 14:44 schrieb Mark Webb-Johnson:
>>> Can you send me the patch to enable debugging, and I will try with
>>> 3.3 branch. I agree that rolling back 3.2 to mbedtls seems sensible
>>> for the short term.
>>> Regards, Mark
>>> P.S. I managed to fix this on another project running an old OpenSSL
>>> by removing the X3 trusted ca (it had both x1 and x3 trusted).
>>> Behavior is highly dependent on the library treatment of multiple
>>> verification paths and trusted ca vs cert chain conflicts.
>>>> On 29 Sep 2021, at 8:11 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>  I managed to get wolfSSL debug logs, but don't know how to
>>>> interpret them. See files attached.
>>>> The final error seems to be…
>>>> I (597167) wolfssl: wolfSSL Leaving DoCertificate, return -188
>>>> I (597177) wolfssl: wolfSSL Leaving DoHandShakeMsgType(), return -188
>>>> I (597187) wolfssl: wolfSSL Leaving DoHandShakeMsg(), return -188
>>>> E (597187) wolfssl: wolfSSL error occurred, error = 188 line:15818
>>>> file:/home/balzer/esp/Open-Vehic
>>>> E (597197) wolfssl: wolfSSL error occurred, error = 188 line:12507
>>>> which is
>>>>     ASN_NO_SIGNER_E     = -188,  /* ASN no signer to confirm failure */
>>>> I've had a look at the code, I don't see a chance to find the bug
>>>> within the remaining time.
>>>> We're 24 hours from expiration. I'll try reverting the
>>>> Mongoose-WolfSSL commits now. Steve, if you already prepared
>>>> something in that direction, tell me.
>>>> Regards,
>>>> Michael
>>>> Am 29.09.21 um 09:56 schrieb Mark Webb-Johnson:
>>>>> The cross-signing bit seems to be on the X1 cert provided in the
>>>>> certificate chain by the server. The one provided there is signed
>>>>> by X3. The problem comes because a different X1 certificate may be
>>>>> provided as a trusted CA (and that X1 is self-signed with a long
>>>>> expiration date - 2035). So the verification process has two
>>>>> possible paths to verify the cert, and the result depends on which
>>>>> one it chooses (and how it handles a trusted CA cert supplementing
>>>>> / replacing one provided by the server).
>>>>> Overall, a mess. I’m fighting this same issue now with a bunch of
>>>>> systems in my day job, and likely a large part of the Internet is
>>>>> going to start to fail tomorrow. Particularly a lot of small
>>>>> embedded devices.
>>>>> Regards, Mark.
>>>>>> On 29 Sep 2021, at 2:51 PM, Michael Balzer <dexter at expeedo.de
>>>>>> <mailto:dexter at expeedo.de>> wrote:
>>>>>> Signed PGP part
>>>>>> SNI was pretty much intact already, I took care of a remaining
>>>>>> Mongoose SNI bug in commit
>>>>>> 9e4f31249856a67317f99920e47efa34f6734c73 / mongoose
>>>>>> 8dc9012b57b85e062974fbdec17db30a501bf68f (April 2020).
>>>>>> I understand the WolfSSL chain management uses a supplied root
>>>>>> cert over one delivered by the server:
>>>>>> https://www.wolfssl.com/docs/wolfssl-manual/ch7/ → section 7.3
>>>>>>> Our problem could be either the wolfssl not recognising the X1
>>>>>>> cert, or not supporting the cross-signing arrangement (where
>>>>>>> there are two paths to verify - the expired X3 and the provided
>>>>>>> X1). I suspect the latter. In an ideal world, having both X1 and
>>>>>>> X3 trusted shouldn’t be a problem.
>>>>>> Is cross signing supported at all by WolfSSL? The only place I've
>>>>>> found it mentioned on wolfssl is this page:
>>>>>> https://www.wolfssl.com/certificate-chain-chain-trust/
>>>>>> …where they say "(We’ll cover cross-signing below)" … but I don't
>>>>>> see them doing that.
>>>>>> There is also no commit in their git history regarding
>>>>>> cross-signed certificates or multiple signatures, so I don't
>>>>>> think updating to 4.8.1 would help.
>>>>>> The intermediate "R3" has issuer "C=US, O=Internet Security
>>>>>> Research Group, CN=ISRG Root X1", which should match the new ISRG
>>>>>> certificate, but not the DST certificate. Maybe that's identified
>>>>>> by a fingerprint in the signature though (?), and maybe the DST
>>>>>> signature comes first and WolfSSL just doesn't check further
>>>>>> signatures if the first fails?
>>>>>> I'll look into the code later on, but need to take care of my
>>>>>> daily job duties first.
>>>>>> If we can't fix this today, I think our best option is to switch
>>>>>> back to mbedTLS for the final 3.2 release and try to fix this for
>>>>>> the initial 3.3 release.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 29.09.21 um 03:40 schrieb Mark Webb-Johnson:
>>>>>>> It seems the dexter server returns different certificates
>>>>>>> depending on the presence of SNI extension in the TSL
>>>>>>> negotiation. That is pretty normal (where a single IP is serving
>>>>>>> multiple different websites), but I am not sure if our client
>>>>>>> library supports that?
>>>>>>> Without SNI, we get:
>>>>>>>     Serial Number:
>>>>>>>     04:ab:25:e5:50:75:49:7b:9f:1b:39:8f:ed:3e:53:44:b4:54
>>>>>>>     Subject: CN=ns34.expeedo.de <http://ns34.expeedo.de/>
>>>>>>>      X509v3 Subject Alternative Name:
>>>>>>>                     DNS:ns34.expeedo.de <http://ns34.expeedo.de/>
>>>>>>> With SNI dexters-web.de <http://dexters-web.de/>, we get:
>>>>>>>     Serial Number:
>>>>>>>     03:be:45:05:45:aa:e3:da:cb:4c:38:ae:f6:90:2f:65:65:e0
>>>>>>>     Subject: CN=dexter.shopdriver.de <http://dexter.shopdriver.de/>
>>>>>>>     DNS:dexter.shopdriver.de <http://dexter.shopdriver.de/>,
>>>>>>>     DNS:dexters-web.de <http://dexters-web.de/>,
>>>>>>>     DNS:ovms.dexters-web.de <http://ovms.dexters-web.de/>,
>>>>>>>     DNS:www.dexter.shopdriver.de
>>>>>>>     <http://www.dexter.shopdriver.de/>, DNS:www.dexters-web.de
>>>>>>>     <http://www.dexters-web.de/>
>>>>>>> Assuming the SNI is set correctly by our library, looking at the
>>>>>>> dexter.shopdriver.de <http://dexter.shopdriver.de/> chain, we have:
>>>>>>>     Issuer: C=US, O=Let's Encrypt, CN=R3
>>>>>>>     Subject: C=US, O=Let's Encrypt, CN=R3
>>>>>>>     Issuer: C=US, O=Internet Security Research Group, CN=ISRG
>>>>>>>     Root X1
>>>>>>>     Subject: C=US, O=Internet Security Research Group, CN=ISRG
>>>>>>>     Root X1
>>>>>>>     Issuer: O=Digital Signature Trust Co., CN=DST Root CA X3
>>>>>>>     and the components/ovms_tls/trustedca/dst.crt we have is:
>>>>>>>     Subject: O=Digital Signature Trust Co., CN=DST Root CA X3
>>>>>>>     (Which expires Sep 30 14:01:15 2021 GMT and was issued just
>>>>>>>     a year earlier - ridiculous for a root CA)
>>>>>>> The components/ovms_tls/trustedca/isrg_x1.crt is:
>>>>>>>     Root X1
>>>>>>>     Root X1
>>>>>>>     Validity
>>>>>>>                 Not Before: Jun  4 11:04:38 2015 GMT
>>>>>>>                 Not After : Jun  4 11:04:38 2035 GMT
>>>>>>>     sha256WithRSAEncryption 4096 bit
>>>>>>> There is a later 4.8.1 version of wolfssl (we seem to use 4.7.0
>>>>>>> released February 2021). Perhaps we can try to update to that?
>>>>>>> Mark
>>>>>>>> On 29 Sep 2021, at 4:11 AM, Michael Balzer <dexter at expeedo.de
>>>>>>>> Signed PGP part
>>>>>>>> I can now confirm it's a WolfSSL issue :-(
>>>>>>>> I've switched back to release 3.2.016, i.e. before changing to
>>>>>>>> WolfSSL, and the ISRG Root X1 certificate works perfectly, just
>>>>>>>> as it should.
>>>>>>>> Steve, I remember you included a config option to enable using
>>>>>>>> WolfSSL, but cannot find it now. Can you give me a pointer, or
>>>>>>>> did you remove that option later on?
>>>>>>>> Am 28.09.21 um 21:53 schrieb Stephen Casner:
>>>>>>>>> I wonder if we are hitting a key size limit in the WolfSSL code.  I
>>>>>>>>> know there are configuration parameters in user_settings.h for
>>>>>>>>> different SHA sizes, but I don't recall one for RSA keys.
>>>>>>>>>                                                          -- Steve
>>>>>>>>> On Tue, 28 Sep 2021, Michael Balzer wrote:
>>>>>>>>>> Still no luck, and getting clueless... :-/
>>>>>>>>>> Let's Encrypt have a live test server:
>>>>>>>>>> https://valid-isrgrootx1.letsencrypt.org/
>>>>>>>>>> Here's a simple test script to access that server:
>>>>>>>>>> (function(){
>>>>>>>>>>      HTTP.request({
>>>>>>>>>>        url:"https://valid-isrgrootx1.letsencrypt.org/",
>>>>>>>>>>        always: function() { JSON.print(this); }
>>>>>>>>>> Just copy this into the editor and evaluate.
>>>>>>>>>> After commenting out the DST certificate from the TLS source, the http request
>>>>>>>>>> terminates with an SSL error (-3) with installed...
>>>>>>>>>>   * self-signed ISRG certificate
>>>>>>>>>>   * cross-signed ISRG / DST root certificate
>>>>>>>>>>   * LE R3 certificate
>>>>>>>>>>   * any combination of these three.
>>>>>>>>>> But the access works immediately after reinstalling the old DST root
>>>>>>>>>> certificate. There is no DST reference in the chain of that server...
>>>>>>>>>> I found another ESP32 project -- not using WolfSSL but the esp-idf SSL & MQTT
>>>>>>>>>> lib --; apparently all they needed to do was to add the very same self-signed
>>>>>>>>>> ISRG X1 certificate I added:
>>>>>>>>>> https://github.com/LibreSolar/esp32-edge-firmware/commit/d6b6307cbdb60feb118355fda973eba11d52f8f5
>>>>>>>>>> So: why would WolfSSL not use the supplied ISRG certificate? Why would it use
>>>>>>>>>> the DST cert without DST being present as an issuer?
>>>>>>>>>> The ISRG certificate is the only one having...
>>>>>>>>>>    signed using      : RSA with SHA-256
>>>>>>>>>>    RSA key size      : 4096 bits
>>>>>>>>>> But that would surely be supported by WolfSSL, wouldn't it?
>>>>>>>>>> I'm running out of ideas, and this really isn't my primary area. Any help is
>>>>>>>>>> appreciated.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 28.09.21 um 19:15 schrieb Stephen Casner:
>>>>>>>>>>> Michael,
>>>>>>>>>>> Certainly within our code as it stands there is not any mechanism to
>>>>>>>>>>> tell the WolfSSL code to adjust its certificate validation procedure.
>>>>>>>>>>> The browser certificate substitution that you hypothesize is not clear
>>>>>>>>>>> to me.  I would expect the validation to simply follow the chain.
>>>>>>>>>>>                                                           -- Steve
>>>>>>>>>>>> More info:
>>>>>>>>>>>> All my browsers already have a builtin ISRG X1 certificate signed by ISRG
>>>>>>>>>>>> only, that's the new version:
>>>>>>>>>>>> https://crt.sh/?id=9314791
>>>>>>>>>>>> My server still sends the ISRG X1 certificate cross signed / issued by DST
>>>>>>>>>>>> Root CA X3. That's the chain it got from Let's Encrypt (via certbot) on
>>>>>>>>>>>> the
>>>>>>>>>>>> last renewal (last month!):
>>>>>>>>>>>> https://crt.sh/?id=3958242236
>>>>>>>>>>>> Without the DST root cert, WolfSSL then fails validating the DST signed X1
>>>>>>>>>>>> root certificate (I assume):
>>>>>>>>>>>> My servers will continue sending that chain including the outdated root
>>>>>>>>>>>> cert
>>>>>>>>>>>> probably until the next renewal, so it's possible having added the new X1
>>>>>>>>>>>> root
>>>>>>>>>>>> certificate didn't solve the issue.
>>>>>>>>>>>> The browsers seem to know how to substitute the DST signed certificate by
>>>>>>>>>>>> the
>>>>>>>>>>>> builtin self-signed (?). Is there a similar option in WolfSSL, and do we
>>>>>>>>>>>> need
>>>>>>>>>>>> to enable that?
>>>>>>>>>>>> Steve, can you confirm this, do you know a solution?
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Michael
>>>>>>>>>>>> Am 28.09.21 um 15:34 schrieb Michael Balzer:
>>>>>>>>>>>>> I've tried adding the intermediate cert ("R3") and then also my site
>>>>>>>>>>>>> certificate, that didn't help.
>>>>>>>>>>>>> Only adding the DST cert again fixes the connection.
>>>>>>>>>>>>> Any ideas?
>>>>>>>>>>>>> OVMS# tls trust list
>>>>>>>>>>>>> ISRG Root X1 length 1939 bytes
>>>>>>>>>>>>> 1939 byte certificate: ISRG Root X1
>>>>>>>>>>>>>     cert. version     : 3
>>>>>>>>>>>>>     serial number     : 82:10:CF:B0:D2:40:E3:59:44:63:E0:BB:63:82:8B:00
>>>>>>>>>>>>>     issuer name       : C=US, O=Internet Security Research Group, CN=ISRG
>>>>>>>>>>>>> Root
>>>>>>>>>>>>> X1
>>>>>>>>>>>>>     subject name      : C=US, O=Internet Security Research Group, CN=ISRG
>>>>>>>>>>>>> Root
>>>>>>>>>>>>> X1
>>>>>>>>>>>>>     issued  on        : 2015-06-04 11:04:38
>>>>>>>>>>>>>     expires on        : 2035-06-04 11:04:38
>>>>>>>>>>>>>     basic constraints : CA=true
>>>>>>>>>>>>>     key usage         : Key Cert Sign, CRL Sign
>>>>>>>>>>>>> dexter length 1972 bytes
>>>>>>>>>>>>> 1972 byte certificate: dexter
>>>>>>>>>>>>>     cert. version     : 3
>>>>>>>>>>>>>     serial number     :
>>>>>>>>>>>>> 04:55:1D:F4:27:A3:7D:E9:E4:A8:5C:37:F6:A1:61:87:3C:E5
>>>>>>>>>>>>>     issuer name       : C=US, O=Let's Encrypt, CN=R3
>>>>>>>>>>>>>     subject name      : CN=dexter.shopdriver.de  <http://dexter.shopdriver.de/>
>>>>>>>>>>>>>     issued  on        : 2021-08-07 05:47:57
>>>>>>>>>>>>>     expires on        : 2021-11-05 05:47:55
>>>>>>>>>>>>>     RSA key size      : 2048 bits
>>>>>>>>>>>>>     basic constraints : CA=false
>>>>>>>>>>>>>     subject alt name  :dexter.shopdriver.de  <http://dexter.shopdriver.de/>,dexters-web.de  <http://dexters-web.de/>,
>>>>>>>>>>>>> ovms.dexters-web.de  <http://ovms.dexters-web.de/>,www.dexter.shopdriver.de,www.dexters-web.de
>>>>>>>>>>>>>     key usage         : Digital Signature, Key Encipherment
>>>>>>>>>>>>>     ext key usage     : TLS Web Server Authentication, TLS Web Client
>>>>>>>>>>>>> Authentication
>>>>>>>>>>>>> r3 length 1826 bytes
>>>>>>>>>>>>> 1826 byte certificate: r3
>>>>>>>>>>>>>     cert. version     : 3
>>>>>>>>>>>>>     serial number     : 91:2B:08:4A:CF:0C:18:A7:53:F6:D6:2E:25:A7:5F:5A
>>>>>>>>>>>>> Root
>>>>>>>>>>>>> X1
>>>>>>>>>>>>>     subject name      : C=US, O=Let's Encrypt, CN=R3
>>>>>>>>>>>>>     issued  on        : 2020-09-04 00:00:00
>>>>>>>>>>>>>     expires on        : 2025-09-15 16:00:00
>>>>>>>>>>>>>     basic constraints : CA=true, max_pathlen=0
>>>>>>>>>>>>>     key usage         : Digital Signature, Key Cert Sign, CRL Sign
>>>>>>>>>>>>>     ext key usage     : TLS Web Client Authentication, TLS Web Server
>>>>>>>>>>>>> Authentication
>>>>>>>>>>>>> Am 28.09.21 um 15:07 schrieb Michael Balzer:
>>>>>>>>>>>>>> We would need to bypass / shortcut the "eap" test phase.
>>>>>>>>>>>>>> But I agree, "master" is stable, I haven't had any issues or reports,
>>>>>>>>>>>>>> so I
>>>>>>>>>>>>>> think we could do that. The FreeRTOS timer issue I'm working on only
>>>>>>>>>>>>>> affects very specific conditions, so not necessary to wait for that.
>>>>>>>>>>>>>> Should we remove the expiring DST certificate in that release then?
>>>>>>>>>>>>>> ...uh oh: just tried removing the DST certificate: the module cannot
>>>>>>>>>>>>>> connect to my server anymore...!?
>>>>>>>>>>>>>> I (490213) ovms-server-v2: Connection isovms.dexters-web.de:6870  <http://ovms.dexters-web.de:6870/>
>>>>>>>>>>>>>> TEST1
>>>>>>>>>>>>>> I (490213) ovms-server-v2: Status: Connecting...
>>>>>>>>>>>>>> V (490723) ovms-server-v2:
>>>>>>>>>>>>>> OvmsServerV2MongooseCallback(MG_EV_CONNECT=-3)
>>>>>>>>>>>>>> W (490723) ovms-server-v2: Connection failed
>>>>>>>>>>>>>> E (490723) ovms-server-v2: Status: Error: Connection failed
>>>>>>>>>>>>>> V (490723) ovms-server-v2: OvmsServerV2MongooseCallback(MG_EV_CLOSE)
>>>>>>>>>>>>>> I (490723) ovms-server-v2: Status: Disconnected
>>>>>>>>>>>>>> Am 28.09.21 um 14:32 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>>> Shall we release a full update? The last 3.2?
>>>>>>>>>>>>>>> What we have now in master seems stable.
>>>>>>>>>>>>>>> Mark
>>>>>>>>>>>>>>>> On 28 Sep 2021, at 5:39 PM, Michael Balzer<dexter at expeedo.de>
>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>    Everyone,
>>>>>>>>>>>>>>>> the DST root certificate we include (DST Root CA X3) expires on
>>>>>>>>>>>>>>>> September 30, i.e. in two days.
>>>>>>>>>>>>>>>> DST Root CA X3 length 1200 bytes
>>>>>>>>>>>>>>>> 1200 byte certificate: DST Root CA X3
>>>>>>>>>>>>>>>>     cert. version     : 3
>>>>>>>>>>>>>>>>     serial number     :
>>>>>>>>>>>>>>>> 44:AF:B0:80:D6:A3:27:BA:89:30:39:86:2E:F8:40:6B
>>>>>>>>>>>>>>>>     issuer name       : O=Digital Signature Trust Co., CN=DST Root
>>>>>>>>>>>>>>>> CA X3
>>>>>>>>>>>>>>>>     subject name      : O=Digital Signature Trust Co., CN=DST Root
>>>>>>>>>>>>>>>> CA X3
>>>>>>>>>>>>>>>>     issued  on        : 2000-09-30 21:12:19
>>>>>>>>>>>>>>>> *  expires on        : 2021-09-30 14:01:15*
>>>>>>>>>>>>>>>>     signed using      : RSA with SHA1
>>>>>>>>>>>>>>>> AFAICT, this root certificate is currently used by the OVMS to
>>>>>>>>>>>>>>>> validate Let's Encrypt certificates.
>>>>>>>>>>>>>>>> https://letsencrypt.org/docs/dst-root-ca-x3-expiration-september-2021/
>>>>>>>>>>>>>>>>     *https://letsencrypt.org/docs/certificate-compatibility/
>>>>>>>>>>>>>>>> Unfortunately, we missed adding the followup LE root certificate
>>>>>>>>>>>>>>>> "ISRG
>>>>>>>>>>>>>>>> Root X1" in time.
>>>>>>>>>>>>>>>> I've just added that certificate to our builtin certificate
>>>>>>>>>>>>>>>> repository, but it's too late now to roll out a "main" update in
>>>>>>>>>>>>>>>> time
>>>>>>>>>>>>>>>> (isn't it?).
>>>>>>>>>>>>>>>> So, to prevent losing TLS connectivity with LE servers, users need
>>>>>>>>>>>>>>>> to
>>>>>>>>>>>>>>>> manually add the ISRG Root X1 certificate to their TLS
>>>>>>>>>>>>>>>> repositories.
>>>>>>>>>>>>>>>> I've added a section on this to our user manual:
>>>>>>>>>>>>>>>>     *https://docs.openvehicles.com/en/latest/userguide/ssltls.html
>>>>>>>>>>>>>>>> If users contact you, point them to that page.
>>>>>>>>>>>>>>>> We probably should also remove the expired DST root certificate
>>>>>>>>>>>>>>>> after
>>>>>>>>>>>>>>>> September 30.
>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>> Michael
>>>>>>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210929/56114eba/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210929/56114eba/attachment-0001.sig>
