[Ovmsdev] Urgent TLS root certificate issue (Let's Encrypt)
Wed Sep 29 05:45:45 HKT 2021
On Tue, 28 Sep 2021, Michael Balzer wrote:
> I can now confirm it's a WolfSSL issue :-(
> I've switched back to release 3.2.016, i.e. before changing to WolfSSL, and
> the ISRG Root X1 certificate works perfectly, just as it should.
I thought perhaps it was due to missing SHA256 since that symbol is
not in user_settings.h whereas 224, 384 and 512 are.  But that's not
it since there is no macro WOLFSSL_SHA256 (it must be the default).
> Steve, I remember you included a config option to enable using WolfSSL, but
> cannot find it now. Can you give me a pointer, or did you remove that option
> later on?
The control of whether TLS goes through MBEDTLS or wolfssl is
controlled by changes in mongoose.  See commit
b050c434142077989433d8ae5c8597b08f57eb13.
p.s. I'll be offline now for an hour or two.
