[Ovmsdev] Branch for-v3.3 network issues
    Mon Sep 27 02:57:07 HKT 2021
Am 26.09.21 um 19:28 schrieb Michael Balzer:
> a) we've got a real heap corruption issue that sometimes gets
> triggered by the test. I've had it twice around the same place, i.e.
> within the scheduled event processing. I'll check my code.
I think I've found a multicore race condition in FreeRTOS.
For the scheduled events, I keep a list of timers. Walking through the
list, I call xTimerIsTimerActive() to check if a timer is available.
When a timer is due, prvProcessExpiredTimer() takes care of calling the
callback. Here's the issue: before it does that, it removes the timer
from the active list.
xTimerIsTimerActive() checks if the timer is in the "active" list of the
timer service. So xTimerIsTimerActive() will return false on a timer
before the callback actually has begun.
The current FreeRTOS version solves this by introducing a timer status
flag instead of checking the list association, but esp-idf 3.3 includes
the outdated version 8.2.0.
I currently test a workaround for this regarding the events system
(introducing my own status map), which seems to fix the issue -- 180.000
events & counting.
I've used xTimerIsTimerActive() in the websocket handler and in the
OvmsTimer class as well, so need to check if these need similar workarounds.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210926/48e4a5c1/attachment-0001.sig>
