[Ovmsdev] Branch for-v3.3 network issues
    Craig Leres
    leres at xse.com
    Mon Sep 27 01:51:26 HKT 2021
On 9/26/21 10:28 AM, Michael Balzer wrote:
> just to be sure: you refitted both your modules with an ESP32 rev 3,
> only difference is, the production module is running "master", sim7600
> module "for-v3.3"?
That's right:
     OVMS# mod sum
     OVMS MODULE SUMMARY
     Module
       Version:  3.2.016-292-g61cde63a/ota_1/main (build idf
v3.3.4-848-g1ff5e24b1 Sep 17 2021 09:44:13)
       Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3
> If so, my conclusions so far would be:
> a) we've got a real heap corruption issue that sometimes gets triggered
> by the test. I've had it twice around the same place, i.e. within the
> scheduled event processing. I'll check my code.
That's what it looks like to me. I think my sim7600 module hits the bug
less often because it's not doing anything (especially when the modem
goes offline). The production module is posting v2/v3 data giving it
more chances to hit the bug.
> b) more important: only ESP32 rev 3 really solves the SPIRAM bug. It's
> not completely solved by the workaround, the workaround just reduces the
> frequency.
Is it possible the spiram workarounds are more complete in the newest
version of the idf? Does the newer compiler toolchain it uses factor in
at all?
		Craig
