[Ovmsdev] Branch for-v3.3 network issues
Craig Leres leres at xse.com
Mon Sep 20 03:32:35 HKT 2021
On 9/19/21 12:53 AM, Michael Balzer wrote:
> The corrupt heap crashes might be something else, up to now I only saw
> them with the for-v3.3 branch. I'm currently trying to reproduce one of
> these on "master". Unfortunately gdb cannot handle them, the call stack
> also seems to be corrupted.
My overnight run with the for-v3.3 branch ran for about 6 hours and then
hit another CORRUPT HEAP.
> Here's a new version of the script that logs progress so you don't need
> to enable event logging:
> // Setup:
> script eval 'testcnt=0; PubSub.subscribe("usr.testev", function(ev) {
> var ms=Number(ev.substr(11))||10; if (++testcnt % (3*1000/ms) == 0)
> print(ev + ": " + testcnt); OvmsEvents.Raise("usr.testev."+ms, ms); })'
> // Start with 10 ms interval:
> script eval 'testcnt=0; OvmsEvents.Raise("usr.testev.10")'
> // Check status:
> script eval 'print("testcnt: " + testcnt + "\n")'
> // Stop:
> script eval 'PubSub.unsubscribe("usr.testev")'
> This version will log a loop counter every 3 seconds, and you can query
> the loop counter by the check command.
> Example:
>> I (2369414) script: [eval:1:] usr.testev.10: 37500
> I (2373244) script: [eval:1:] usr.testev.10: 37800
> I (2376884) script: [eval:1:] usr.testev.10: 38100
> E (2377694) script: [int/PubSub.js:1] TypeError: not object
> coercible|    at [anon] (duk_api_stack.c:3661) internal|    at hasKeys
> (int/PubSub.js:1) strict|    at messageHasSubscribers (int/PubSub.js:1)
> strict|    at publish (int/PubSub.js:1) strict|    at [anon]
> (int/PubSub.js:1) strict preventsyield
> OVMS# script eval 'print("testcnt: " + testcnt + "\n")'
> testcnt: 38155
> Please try this with "master" as well to see if you also only get the
> heap corruption with for-v3.3.
I've been running your new test script on for-v3.3 and main for 1 hour
(both v3 boxes), no issues so far.
		Craig
