[Ovmsdev] OVMS v3.3 hardware
Tue Sep 7 14:28:25 HKT 2021
Craig,
Am 07.09.21 um 01:13 schrieb Craig Leres:
> On 8/17/21 12:31 AM, Michael Balzer wrote:
> > 2. Any chance to fix the missing HW flow control on the modem UART
> > connection?
> (Is this the source of the "W (541151) cellular: UART hw fifo
> overflow" I see periodically?)
Yes, and you'll often see "gsm-mux: Frame error: EOF mismatch" log lines
in combination with these.
I also added counters for these, you can query them with the "simcom
status debug" command:
> OVMS# sim stat deb
> Network Registration: RegisteredHome
> Provider: congstar
> Signal: -97 dBm
> State: NetMode
> Ticker: 73099
> User Data: 0
> *** HW FIFO overflows: 21*
> Buffer overflows: 0
> Mux
> Status: up
> Open Channels: 4
> *** Framing Errors: 24*
> Last RX frame: 1 sec(s) ago
> RX frames: 151452
> TX frames: 5472
> PPP: Connected on channel: #2
> GPS: Connected on channel: #1
> Status: enabled
> Time: enabled
See also:
* https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/274
* https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/350
* http://lists.openvehicles.com/pipermail/ovmsdev/2019-October/013744.html
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210907/cbb83a6a/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210907/cbb83a6a/attachment.sig>
