[Ovmsdev] 3.2.018 release
Sat Nov 20 23:24:43 HKT 2021
Mark,
why not introduce this for v3.2 as well?
If a v3.3 user accidentally installs a v3.2 build, that would not heal
automatically but stick until manually fixed.
I think it makes sense to have all builds automatically try to update to
the best build available for the hardware in use.
Am I missing somehing?
Am 19.11.21 um 02:44 schrieb Mark Webb-Johnson:
> Regarding the 3.2.018, I will handle it this afternoon (my time).
> Regarding OTA and support for rev3 ESP32, at the moment, the OTA URL
> is composed of:
> * <server> (default api.openvehicles.com/firmware/ota
> <http://api.openvehicles.com/firmware/ota>)
> * <base> (either /v3.0/ or /v3.1/ depending
> on CONFIG_OVMS_HW_BASE_3_0 or CONFIG_OVMS_HW_BASE_3_1
> * <tag> (default ‘main’)
> * /ovms3.ver
> My suggestion is to add the hardware platform (as detected by the code
> that provides metric m.hardware) in there. Perhaps replace <base> with
> something that detects /v3.0/, /v3.1/, or /v3.3/ based on a
> combination of CONFIG_OVMS_HW_BASE and m.hardware ESP32 revision? We
> should probably just implement that in the v3.3 code, so v3.2 and
> before keep using CONFIG_OVMS_HW_BASE.
>> On 19 Nov 2021, at 5:24 AM, Michael Balzer <dexter at expeedo.de
>> Signed PGP part
>> Sounds OK for me.
>> Regarding using the platform revision instead of
>> CONFIG_OVMS_HW_BASE_3_x config: so in case someone accidentally
>> installs the wrong firmware, the system would heal itself by a simple
>> OTA update? Sounds good and should be a simple change.
>> Am 18.11.21 um 08:06 schrieb Mark Webb-Johnson:
>>> We need to get the v3.3 release ready for release now, as the new
>>> v3.3 hardware is about to enter production and the factory needs the
>>> firmware.
>>> Accordingly, I suggest:
>>> 1. I have already updated the for-v3.3 branch with all the recent
>>> changes from v3.2.
>>> 2. We now (today/tomorrow) release the current v3.2 branch as tag
>>> 3.2.018, OTA release. This would be the (hopefully) last v3.2
>>> release.
>>> 3. After release of that, we branch off master to a v3.2 branch,
>>> for historical purposes (and if we need it for anything).
>>> 4. We then merge back for-v3.3 into the master branch and start
>>> working through the usual daily builds for that to get it ready
>>> for production. I think there is still some work to do on
>>> pouring the plugins, but the core code (and in particular new
>>> modem support) should be ok now.
>>> I think we will need to investigate an approach for dual builds for
>>> v3.3-or-later and pre-v3.3 hardware, to take advantage of the new
>>> ESP32 rev3 chips. I think those will require a different sdkconfig.
>>> We can do that automatically in the OTA system, by building the URL
>>> based on the ESP32 platform revision. Should we do that with the
>>> v3.3 release (even if the builds are for the moment the same), or at
>>> a later date?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211120/2705abc9/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20211120/2705abc9/attachment.sig>
