[Ovmsdev] 3.2.018 release
Craig Leres
leres at xse.com
Fri Nov 19 06:19:10 HKT 2021
On 11/18/21 13:32, Michael Balzer wrote:
> there was no change to the RTC or IRAM sections lately. Maybe somehow
> your linker definition got messed up?
"git status" doesn't show any modified files in my copy of the tree. And
I don't see any changes to my toolchain, looks like the last time I
updated it was in July.
The only shared libraries the toolchain ld uses are libz and libc from
the base os (not updated in more than a year).
The amount of overflow seems unreasonably large?
/usr/local/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld:
RTC_SLOW segment data does not fit.
region `iram0_0_seg' overflowed by 2172504 bytes
region `rtc_slow_seg' overflowed by 33681 bytes
2172504 bytes is over 2MB?!?!
I tried reverting to ~Oct 29th but I get the same errors so clearly
something is recently wrong with my build environment.
I found this:
https://github.com/espressif/esp-idf/issues/6914
And tried running idf_size.py:
ice 34 % python $IDF_PATH/tools/idf_size.py build/ovms3.map
load: 0.09 cmd: python3.8 85307 [running] 3.59r 3.57u 0.00s 29% 13616k
load: 0.45 cmd: python3.8 85307 [running] 12.20r 12.18u 0.00s 73%
19824k
Total sizes:
DRAM .data size: 0 bytes
DRAM .bss size: 0 bytes
Used static DRAM: 0 bytes ( 180736 available, 0.0% used)
Used static IRAM: 16775 bytes ( 114297 available, 12.8% used)
Flash code: 0 bytes
Flash rodata: 64388 bytes
Total image size:~ 81163 bytes (.bin may be padded larger)
The end of that github issue points to changes in idf_size, could this
be a python issue? Maybe python packages have been updated on this box
since my last build at the end of October.
Another seemingly related thread:
https://githubmemory.com/repo/aws/amazon-freertos/issues/3356
"I check the components size. And you can see in the log, program
uses the 0.8% of IRAM then how should the IRAM memory region
overflow?"
This feels like broken math somewhere.
Craig
